Question about Dyson DC25 All Floors Bagless Upright Vacuum
How to put the wand back in a dyson dc 25
Dc25
  • 83 Answers
SOURCE: Dyson DC-07 Hose Wand Spring Came Out. How to put back in?
You'll see that there is a round piece with a cross shape on the inside of the button wand release button - place the end of the spring over the cross - you'll see the same cross on the collar of the machine...it'll take some doing, but line the other end of the spring up with the cross and pop the button back into place - be sure to click it onto those two gray circular/oval shaped divets at the bottom where the release button connects to so that the button stays in place.
Posted on Jul 30, 2009
  • 83 Answers
SOURCE: dyson dc25 animal: cannot remove the telescope
The hose is getting twisted on the machine and so the wand gets stuck in the hose.
1) Pull the wand out as far as you can - if you can pull it out completely, separate it from the hose and apply baby powder to the
metal rod. Stretch out the hose and unwind it. In the future, separate the wand and unwind/stretch the hose after use.
2) If you can't pull the wand out all the way, remove the canister/dirt bin from the front. Look for a gray button with 7 vertical
lines/grooves on it (it'll be just above the ball on the opposite side of the bottom hook that you wind the cable around).
3) Push the button and at the same time pull the hose out from the bottom by pulling on the hook - this will release the gray hose
from the machine. Take it off of the machine if possible (the bottom of the wand may stop you from doing so - if it does, try to pull
the wand out until you can release the hose from the bottom)
4) Pull and stretch the hose out and pull the wand at the same time - separate the wand from the hose and unwind the gray hose and
stretch it out. Rub baby powder on the metal rod of the wand and in future, disconnect the wand from the hose and stretch/unwind the
hose after every time you use the wand.
tvservice306
  • 458 Answers
SOURCE: extendable wand difficult to entend
try USE WD-40 (http://www.uline.com/images/en-us/transparent.gif ) to spray ....Wand Assy and Hose Assy.....
Posted on Jan 02, 2010
SOURCE: can't get Dyson DC25 to stand up
Can't get Dyson 25 to stand up anymore. It is only a few months old.
Posted on Sep 05, 2010
DysonInfo
  • 107 Answers
SOURCE: Dyson DC25 rotating brush doesnt work
There is a reset button on the side of the brush bar head. Press it.
Posted on Dec 20, 2010
How do you get the extension off then its raised all the way to the top?
Hi there, it's Jack at Dyson.
DC25's instant-release hose and wand are designed to detach quickly and easily when you need them. There are no fiddly clips or buttons to press - when you extend the wand upwards to it's fullest extend and pull it firmly, it should separate from the main body of the vacuum:
If the wand seems jammed, or you continue to have difficulty removing it, our experts are on hand to take some further details and provide assistance. You can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 16, 2015 | Dyson Dc 25 Animal
DYSON DC 25 SHUTS DOWN UNEXPECTEDLY?
clean all access ports up the handle. plugged somewhere.
Aug 04, 2014 | Dyson DC25 Vacuum
Cannot get the hose from the uprightdc25
If you're unable to remove the hose and wand from your DC25, it's likely the hose was twisted when the wand was last replaced on the machine after use - this can prevent the wand from extending correctly. It's easily resolved by following the steps shown in the video attached.
I hope this helps, but if you'd like further advice after you've given this a try, please give the Dyson customer Helpline a call on 0800 298 0298 (UK), 01-475-7109 (IE), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Jan 28, 2014 | Dyson Dc 25 Animal Upright Bagless Vacuum...
Dyson dc25 animal retractable wand won't go back
Did you try to release the extension by clicking on the red button on the back of the wand? This may allow you to see what is obstructing the pathway for the wand..
You may also find Dyson's site useful: http://www.dyson.com/support.aspx
I hope that helps.
Boulder Epoxy Garage Floors
Sep 18, 2013 | Vacuums
My dyson animal 25 wand will not go back down
I'm sorry to hear you're having difficulty replacing the wand on your DC25. This is likely to be because the hose has become twisted during use. Try removing the wand from the machine and allowing the hose to straighten itself out before replacing it again.
This should resolve the issue, but if you'd like any further assistance or advice, please call us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
Mar 27, 2012 | Dyson DC25 Animal Bagless Upright Vacuum
How to use Dyson DC 25
Information on how to use the wand can be found in the user guide supplied with your machine - in case you don't have this hand, you can download a copy here:
http://support.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/dc25_uk_manual_alf_120710%20pdf.ashx
You may also find the video below helpful.If you need any further advice on using or maintaining your machine, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US) so we can help.
Best wishes,
Jack
Jan 15, 2012 | Dyson DC25 All Floors Bagless Upright...
Hose attachment
Your wand is getting stuck in the hose because the hose is twisted - you need to unwind it:
1) Pull the wand up as far as you can, all the way if possible
2) Stretch the hose out and unwind it, use some babypowder on the metal part of the wand and in the future, unwind and stretch the hose out after you use it
3) If you can't get the wand all the way out, remove the canister from the front, push the button where you see the 7 vertical grooves (on the opposite side of the hook that you wind the cable around) - then pull on the hook and pull the hose up and off of the machine - stretch the hose out from the bottom and pull the wand out - now apply baby powder to the metal rod and disconnect and stretch and unwind the hose every time after you used the wand to clean.
Jun 25, 2009 | Dyson DC25 All Floors Bagless Upright...
Dyson DC25 All Floors Bagless Upright Vacuum Logo
110 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
