Maytag washer epic z model # MHWZ400TQ00
Not getting power to the pump
  • 409 Answers
SOURCE: maytag epic
hi there,
the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible.
Posted on Oct 03, 2008
sivaranjini
  • 241 Answers
SOURCE: Maytag Epic giving F11 error code!
ths.gardenweb.com/forums/load/.../msg1012004912002.html
Posted on Jun 22, 2009
SOURCE: MAYTAG EPIC FRONTLOAD WASHER NOT DRAINING
The filter is in the front on this one. Under the door, there is another panel. There are 3 screws that a 1/4" nut driver takes off pretty easily. Get a bowl and bucket. There is a white screw cap that you should easily see. Open it slowly with the bowl underneath. Close it again when the bowl is filled and dump the bowl into the bucket. Repeat until no more water comes out then unscrew it completely. Clean out the trap and replace. There is a stop that prevents you from overtightening. See if that works. A six dollar nutdriver is easier and cheaper than any repairman.
Posted on Jul 20, 2009
jsrock516
  • 5911 Answers
SOURCE: Torn Bellow on Maytag Epic Z
The following link explains step-by-step how to replace the door bellow:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
I know the link I provided is for a Whirpool Duet. The newer model Maytags (such as yours) are manufactured by Whirlpool now and have Whirpool parts. These instructions should work for you.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Aug 14, 2009
BIKER T
  • 909 Answers
SOURCE: Maytag Epic Z front loading washer spin cycle very loud
your bearings and seal need to be replaced.
Posted on Sep 21, 2009
My Maytag washer has a flashing F 15. What does that mean?
The following list of codes indicates an electronics communication problem with the washer: * EpicĀ® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
* Epic ZTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Hope this helps.
Jun 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
Can u change the door direction on a maytag washer
It is possible with little drilling work on the body. But it requires skill and patience. Wirings to the door lock has to be re-routed etc. It is not worth the trouble!!
Apr 05, 2010 | Maytag EPIC MFW9700S Front Load Washer
F 21 error code? Maytag epic z washer
The F21 code on the Maytag EPIC is indicative of a pump problem. The pump impellers should be checked, there should be four of them. Sometimes the impeller blades can be broken by coins, or other items. Make sure that the pump is clear of debris, then remove the discharge hose, and blow through it.
If after clearing the initial slug of water, the hose doesn't blow free and clear, you have something stuck in there.
Nov 28, 2009 | Maytag EPICz Electric Dryer
I need to change the bellow on my maytag front loader. Do you have any instructions?
The following link explains how to change the bellow on a Maytag Epic:
Later models of Maytag washers are manufactured by Whirlpool, so these instructions should apply. If you have any questions, please let me know. I hope this helps you.
Sep 02, 2009 | Maytag EPIC MFW9700S Front Load Washer
Aug 13, 2009 | Maytag EPIC MFW9700S Front Load Washer
Jun 22, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag epic frontload dryer won't unlock
Hello, unplug the washer remove the lower front access panel, get to the switch and pull downward on the circullar shaped release tab. Now drain the machine manually, take the filter out of the pump and clean out. reassemble and test. good luck
Dec 09, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic
the control board has loose solder connections around the relays.
see this
diff model same issue with new boards as they make them all.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
being it is in warranty its too early for you to fix it yourself.
you will have to wait for them to come out and say the parts are on backorder.
Feb 04, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
