Fa4bnf048 What size filter does this unit have?
Why wont the professionals I hired clean my evaporator coil?
no they are lazy and did not want to tear into it because it takes some effort to clean the coil. Get a new tech!!!! you can clean them without them leaking I do it all the time.
Sep 04, 2014 | Heating & Cooling
What size air filter fits model #UBHC14J06SFD? I was told by a tech that the original filter that came with the unit needs to be replaced. This was purchased back in 2004. The sizes that are sold in the...
Recommend a washable lifetime filter that can be custom fitted for your unit. There are many different brands of cut to fit and custom sized filters available.
The original filters supplied with the unit are usually washable as well although the manufactures are not including it all the time anymore.
Aug 21, 2011 | Ruud UBHC Air Conditioner
I need to replace the air filter on this unit and I can't find the right size filter. What size do I need? I ave an Armstrong model # 64HWC303a-2B Serial # 8401H12194
If it's a plastic mesh filter, you can buy an uncut kit at most home centers and hardware stores. That you can cut to fit your unit.You'll probably have enough left over to make 2 filters.
Jul 06, 2011 | Heating & Cooling
Filters for a rudd model # rkkb-a120cm22e
get a tape measure and measure it. lets say the size is 20" x 24". the filter size will be 23 1/2" x 19 1/2" why they do this i dont know.
if it is a real old unit just go to publix or walmart (publix is only in florida) and get one of those crappy blue filters that you hose out. you can cut it with sicsors and it fits underneath that crappy metal u wire.
if you have the unit i think you should just run the old blue "hog's hair filter" it sucks but so does your old unit.....
Oct 09, 2009 | Heating & Cooling
Changing Air Filter
In general terms an electric unit uses a 20 x 20 x 1 filter and a gas system uses a 20 x 25 x 1 filter. If the return filter is somewhere other than at the unit, it will very greatly in size. Its the descretion of the installer as to what size filter they choose to install.
Apr 07, 2009 | Intertherm P3RA-030K Air Conditioner
How do I find the filter on a lennox G8Q3904 furnace?
If you don't have a filter "rack" installed then you have to remove the blower housing door. Usually the filter is there if it is not located in the house where the return air supply is. Some units have a filter in what is called a return air filter grill. If there isn't a filter already installed in the unit then you will have to measure the inside dimensions and then use one that is similar in size. It's not imperative that you use the exact same size. You just want to cover the opening of the unit. If you don't have central air conditioning, then it's not necessary to use a filter.
Mar 30, 2009 | Heating & Cooling
Air conditionig
If it is a digital thermostat check the batteries and replace. If you remove the thermostat cover so you can see the wires, check between R & W and you should read a voltage differential. Same for R to Y and R to G. Your problem may be only related to the batteries.
Sep 05, 2008 | Air Tools & Compressors
Weather King Air Conditioner
The best way to find the size of the filter is to use a tape measure to find the size of the filter cavity. Remmeber, most filters come in even numbered inches, and you can buy a "cut to fit" at The Home Depot. Ask for "Hogshair".
Jul 26, 2008 | Heating & Cooling
Filter size
Thats an A/C, what is the indoor unit model #? Does it have a filter box? If so what size? If not do how does your filters sit in the unit?
Jun 23, 2008 | Weather King 12AJA4801AH Air Conditioner
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
