Question about Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready LCD Television
No power We went away for a few weeks and when we returned our 15" LCD will not turn on. The power light is out also. I checked the wall plug and its fine...any idea's?
  • Deb1959 Mar 19, 2008
    We have a Sharp LCD 19" with no power. The light on the front panel is off. We have tried a different outlets. The power cord in the back is removeable and we have unplugged it from the back and replugged it in. Nothing has worked. The TV is about 15 months old.
  • 979 Answers
Does this model have a removable power cord? Check to make sure that the cord is inserted fully if it this type. Also, Have you tried to turn on the set using the front panel control?...accordianman
Posted on Nov 26, 2007
SOURCE:
Went to turn on sewing machine Memory Craft 10000 and it acts like it has no power have moved plug in and still no power
is it plugged into the wall outlet and - if you plug in a light to same outlet does the lamp light when turned on ?
Sep 15, 2018 | Cars & Trucks
My Acer TCO03- power button is just blinking but no picture display
Blow hot air into the back with a hair dryer before trying to start it.
(not kidding)
if that works, one of the capacitors on the power board went bad.
even if that does NOT work, one of the capacitors on the power board went bad.
It is ALWAYS one of the capacitors on the power supply gone bad.
Being unplugged for a few weeks - as you stated - drained it of "juice", and it just cr*pped out. It was going to fail soon, in any event.
Fixing it can cost you less than a dollar, if you Google for information.
Best of luck!
Mar 03, 2015 | Acer Monitor Lcd 19in Al1923 0.29mm...
TV will not turn on
Check the wall outlet, make sure there is power at the wall. If not, check the breaker panel. If there is power at the wall, check the TV for a manual on/off switch. If you have a power switch on the TV, turn it off, wait 10 seconds, then turn it on. If no power switch on the TV, unplug the TV for 10 seconds, then plug in again. Use the remote to turn the TV on. Check for a fuse or circuit breaker on the TV, usually near where the power cord enters the TV.
Make sure you have good batteries in the remote. If all this fails, then something may be damaged inside your TV, as a result of a power spike before the power went out, or when it came back on.
Take it to a repair shop.
Apr 07, 2014 | Magnavox 19me601b/f7 19-inch 720p Lcd Tv
Vizio TV wont turn on after three weeks no use
My vizio recently did the same exact thing. Vizio sent an HDTV tech out to fix it and it was the power board. He put a new board in (took 15 min) and the tv works like new.
Jan 05, 2010 | Vizio L32 32 in. LCD HDTV
The compyter has no power at all.
please replace your battery and try it again ....... and if it does not work, return it to the shop where you bought it ....... i believe you can have this solved
May 18, 2009 | Toshiba Satellite A215-S7422 Notebook
Sudden power failure
my swisstec tv had exactly the same problem this week march 30th and the 12 month warranty expired.....i went to skymediauk online and extended my warranty ..free for 3 months they collected it,fixed it and returned it in 46 hours
Jan 29, 2009 | LG 42LC2D 42 in. LCD HDTV
Tv wont turn on
disconnect the tv from the wall first for a few minutes,like 15 or 20 and then plug it back,lets see what happen
good luck
[email protected]
Oct 31, 2008 | Samsung HP-T4264 42 in. Plasma HDTV
Dell Minitors has lost power
small cable to button/control lights may be disconnected
Sep 18, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready LCD Television Logo
74 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
