Question about Electrical Supplies
I have a ETQ model TG7000 generator. It has new gas & fresh oil and a new spark plug. Itry pull starting it over and over and it doesnt seem to be getting any gas. there is a needle in the bottom of the carburetor that has two wires to it. is this a shut off of some sort ??
SOURCE: Just won't start
check the spark plug after a failed attempt to start. If dry, then no fuel is entering engine.
Did you leave old fuel in carb? if so, your carb probably is dirty: old gasoline deposits varnish, gum, and you will need to dissassemble carb and clean it.
Posted on Dec 01, 2008
  • 62 Answers
SOURCE: Kipor 3000ti generator, doesn't start, i checked
Drain carb bowl it could have water in the gas
Posted on Apr 07, 2009
SOURCE: Coleman6250 Generator PM0545007 - Won't start/run.
Most gasoline engines need three basic things to run: proper air/fuel mixture, sufficient compression, and a properly timed spark. Check the easiest, cheapest things first, then check the "Gee, I forgot to turn on the gas" kind of things next, then work your way onwards from there.
Compression can be guesstimated with the proverbial thumb-over-the-empty-spark-plug-hole routine as you turn it over casually to check compression. If it doesn't blow your thumb out of position, you could have a hole in the piston (overheating response) or a stuck or damaged intake or exhaust valve.
Check for fuel flow by carefully disconnecting the fuel line to the carburetor and letting some run into a tin can (no styrofoam coffee cups, please). It should dribble freely. If not, you have to back-track the line and find out where the blockage is.
Spark is one that sounds like you've already tested (spark plug out of the cylinder head, hooked up and laying on the metal engine as you turn it over?) so check timing. You will probably need a manual for this test, although a good estimate is that the plug should fire just a wee bit before Top Dead Center position of the piston. Like I said, a manual comes in handy here.
From what you've mentioned, though, I'd start trouble-shooting at the fuel flow part first.
Good luck,
GRB
Posted on Jun 08, 2009
bozcro
  • 867 Answers
SOURCE: Coleman 6250 Generator won't turn over
try removing the air filter and try starting if it dirty or to oily , no vacuum is created to pull the fuel into the carb
Posted on Jul 30, 2009
Testimonial: "I removed the air filter,then put air filter back on,it started for 2 mintes.I shut it off, but then allot of gas just spewed out of the air filter?"
kel1guy2002
  • 3740 Answers
SOURCE: Regards to ETQ TG1200 Generator Generator
Hi and welcome to FixYa, I am Kelly
I read spce sheets for this generator and several of the spec sheets say it requires 0.16 L of oil. If generator has a low oil level sensor that will kill the spark if the oil level is low.
Here is a copy of the Owners manual:
http://theportablegenerators.org/manuals/ETQ/Generator-TG1200-manual.pdf
I went through the manual reading every detail about the generator and could find nothing about an low oil level sensor.
The wiring diagram on page 27 only shows the ignition switch, with a Brown wire to the ignition controller and then an orange wire to the high voltage coil in the circuit.
The parts diagram throws a wrench n the game as it mentions an ignitor... (item 2)
I see the switch, (item 4 page 24)
The magneto (Item 16 page 22)
The High voltage coil / set (Item 28 page 22) as the only 3 things in the circuit.
Disconnect the brown wire at the ignition controller and switch the run switch to ON. Check for a ground (none allowed)
Then check the Orange wire at the ignition controller to the high voltage set / coil. You may read resistance of the coil but is should NOT read ZERO ohms. IF you read ZERO you need to locate the short.
Inspect the wiring connections especially around the ignition controller. For a unit with 1 hr of run time it has to be something simple like a disconnected terminal unless rodents chewed on the wiring.
Thanks for choosing FixYa,
Kelly
Posted on Jun 04, 2011
Etq tg3000 portable generator is leaking gas from carburetor into air filter. Any suggestions
PDF]Manual - Northern Tool + Equipment
www.northerntool.com/images/.../166020.pd...
Northern Tool + EquipmentThe ETQ air-cooled gasoline generators are widely used when electrical power is scarce. Our generators provide a portable mobile solution in supplying power for field ... 5.5 Hours. Fuel Type. Premix 50 cups of Gasoline to one cup of 2 stroke oil ......Leaking carburetor, clogged fuel pipes, sticking valves, or other damage, ...
[PDF]Owner's Manual Model TG4000
Dec 08, 2015 | Electrical Supplies
Seems my Poulan Chainsaw P3314 is flooding.
Ron, the excessive gas could be the result of continued start attempts with a weak spark or a bad plug or a carboned plug. If none of the carb adjustments have not been turned or twisted prior, I'd suggest obtaining a fresh spark plug. Make sure the gap is correct. Blow out the cylinder with compressed air to vent all the residual gas/oil within. Ground the new plug against the engine and pull the cord. You should observe a fairly bright spark at the plug. If no spark you could have a faulty coil/ignition module. If a bright spark is present, install the plug and give it full choke and attempt to start. It should attempt to start within a few pulls....when it does, go immediately to HALF-choke and pull again and it should start.
Nov 11, 2015 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Further to my question about a weak spark on my etq 1200 ,would one of these be the problem, magneto,igniter ir capacitor?
A lot small ignition spark appears to be weak when they are not.
A couple things to check. make sure your spark arrestor is clean and your ignition timing is correct; otherwords, that the flywheel key is not sheared.
Nov 25, 2014 | Eastern Tools & Equipment ETQ Tg1200 1200...
I have a Champion generator 6000 starting watts modle number 41115 starts and runs for a few minutes then shuts down , has fresh gas and new spark plug.
Is the oil level good, does the low-oil cutoff switch work properly? Try bypassing the aforementioned switch to see if it fixes your woe.
Nov 05, 2013 | Electrical Supplies
I have a TROY-BILT Tiller/Edger model 12216. I installed a brand new spark plug, fresh gas and new oil. It started and I even used it to break up a small portion of my yard. By small I mean probably 5...
check gas/oil, if all is good the pull the spark plug, hook the spark plug back up and pull the cord while observing the spark plug for spark, may be the coil. Hope this helps Tim
May 02, 2011 | Garden
11 hp 5700 watt generator wont fire
If you could not start in spite of oil and gas change, checked gas supply, spark plug, ignition cables and coils (magnetos) and so on whitout success, then try this:
Your generator has a low oil level protection, which stops the ignition of the motor.
After "a couple of years" sitting without or with old oil, the level switch may have got lazy or stuck down.
If your oil level seems to be good, while measured, find the oil switch and try to shorten or disconnect it.
If you succeed in running the generator change or repair the oil switch.
I hope that this will be helpful, because I don't have your device in front of me, but some people rank such an answer with 2 thumbs, which means useless. Better dont rank.
Jul 22, 2010 | McCulloch FG6000MK 5700Watt 13 HP 338CC...
It started but when i pluged in ti it it quit. has not started since. checked plug and it was loaded with gas. install new plug and tried. check spark and it appears eratic. pulled air filter off and it is...
sounds like the float is stuck, how long has it ben setting around? try some carburetor cleaner. spray the carburetor down. empty the fuel tank put fresh fuel with fuel treatment. you may have to remove the spark plug, pull starter string a couple of times to clear out cylinder make sure spark plug is dry put back in and try to start the generator.
Dec 10, 2009 | Briggs Stratton H7159 & StrattonĀ® 5500,...
Just won't start
Nov 14, 2008 | McCulloch 13HP 338 Cc Portable Generator #...
Electrical Supplies Logo
575 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
