Question about HP DeskJet 920c InkJet Printer
DOCUMENT IS CROOKED WHEN PRINTED
Both my HP Deskjet 920c and my HP Officejet 4215v are printing my labels crooked. This has never happened until now - when I'm in a hurry to get things completed.
  • 1 more comment
  • Labels Sep 01, 2007
    Yes, I had aligned the print cartridges and the problem persists.
    I've tried to get through this project - due MONDAY, 2 days. As a result, I've wasted 4 complete packages of labels not to mention all kinds of time & ink.
  • Anonymous Sep 17, 2008
    I have a HP Officejet 4315v all in one and it wont align the label correctly when it prints. It aligns perfectly when you print a plain piece of paper and hold it up to the labels. It's so frustrating and HP offers no assistance!
  • 3 Answers
You need to align the cartridges
Posted on Aug 29, 2007
SOURCE:
My paper feeding is crooked
check the paper tray, make sure the paper guides are snug up to the edges of the paper. Even a small gap will cause miss alignment of the printing.
May 15, 2016 | HP OfficeJet 7310 All-In-One InkJet...
HP deskjet 920 c crooked feed
there should be a rear panel to remove and check to see if there is any small peices of paper caught in the rollers or obstructing one side, if not the grip on the the roller is worn or the paper aligning bar is open too wide and allowing the paper to tilt. This is a more common problem with shiny surfaced paper, so try a more matt rougher quality paper.
Jun 04, 2007 | HP DeskJet 920c InkJet Printer
When pages come out of the copier the image is printed crooked. The paper comes out straight, so feed is correct. Image is just crooked? Why?
Does this happen when you using the document feeder?? Try placing the original document on the big glass see what happens might be you document feeder needs to be adjusted or the original document is hitting a obstruction in the path as it is being scanned. Does it print OK? Vise copy?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 25, 2016 | Ricoh Aficio 2018D All-In-One Laser...
How do I align the HP Laserjet 1020 to print straight? Its printing crooked every time. No two sheets are in the same position
Most likely to be a page feed problem, look online to clean page feeder rubber rollers.
Try here for the pdf manual which covers problem with jams and skewing
http://www.hp.com/ctg/Manual/c00264334.pdf
Mar 05, 2015 | HP LaserJet 1020 Printer
Printing envelopes it prints crooked
HP OfficeJet Pro K8600 Printer
Printing envelopes
Mar 19, 2014 | HP OfficeJet Pro K8600 Printer
When I print out something, like a self-made label (basically with a box around the text), the box comes out crooked every time I print. Help!
check the manuall to re align the printer head, or search google how to re align hp deskjet d1341 printer head. hope this helps
Dec 04, 2009 | HP Deskjet D1341 InkJet Printer
Hp deskjet 5550 is grabing the paper but paper prints crooked
You may have a paper jam (small paper cut) in the feeder ytry to check it and see if you can clean it...or you may bent the feeder...open it and let me know
Sep 13, 2009 | Office Equipment & Supplies
My d145 officejet prints document page crooked
your adf assy is out-of-alignmnt or feed'g rollers/sep-pad are filthy/bad. +possible that rollers in ppr-feed(lower unit) need cleaning also. good luck... [email protected]
Jun 14, 2009 | HP OfficeJet d145 InkJet Printer
Crooked Excel Spreadsheet
I also had this problem, through trial and error I found that if you go into File, Page setup in excel then the Page tab, make sure the print quality is set to 600 dpi. Once I did that it printed correctly.
Jan 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP DeskJet 920c InkJet Printer Logo
206 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
