Question about Fitbit One Wireless Activity & Sleep Tracker, Burgundy
Sleep monitor is no longer showing under More
Monitor goes to sleep immediately after turning on the computer. How can I fix that?
go to start,then pc settings,then monitor or power options the to power and sleep and change on plug to 4 hours and on battery to 10 minutes
Jun 11, 2015 | Computers & Internet
When i supply power in my hp 1502 desktop and connect it with cpu than my desktop scree only show its going to sleep
1.check with a other monitor.
2.check the cabels should be seated tight.also the videocard should be seated tight.
3.the videocard or the monitor can be brooken check with a new or other monitor first.
Apr 17, 2013 | HP 1502 LCD Monitor
Monitor lights orange
If the monitor gets no signal it will show orange. or ,It's hibernating or sleeping. Shut down computer, reboot, open Control Panel, Power settings, change to High Performance, change Hibernate to never or disable, change sleep to never or disable. Shut down the computer and monitor when not in use. It will last longer and reset the computer every day when turned on.
Dec 23, 2012 | Dell Dimension C521 PC Desktop
MY MONITOR SHOWS: VGA No signal DVI No signal then shows: Check Video Cable Then: Monitor going to sleep
Try another cable, borrow one, then try monitor in another PC / laptop, if it works then either the software settings for the sleep mode are on or it may be a faulty video card.
Oct 15, 2010 | HP Compaq WF1907 Monitor
My HPw1707 monitor keeps going to sleep and I have to turn off the computer to get the programs to open when I want to work on anything.
Are you saying that the monitor is going to sleep or the computer? If the computer goes to sleep I can understand not being able to get to your programs. This is a simple matter of turning off hybirnate in the power supply icon of your control panel. If the monitor is going to sleep there should be a menu with a timer for sleep time. Just change it to a much longer time or turn it off.
Feb 25, 2010 | HP Computers & Internet
After 30 mins the screen goes to sleep how can you change the time duration to a longer sleep cycle
If you are running Vista, go to control panel, power options, then on the left side you will see the display options.
Feb 19, 2010 | Dell SE198WFP LCD Monitor
My Computer boots and montitor says Going to sleep and flashes VGA : NO signal and goes off
Check under "Power Options" of the control panel of Windows that "Turn off Monitor" is set to "Never" Also check under the advanced tab of "Power options" that "When I press the sleep button on my computer" its set to "Do Nothing"
This will most likely solve your problem. the sleep button may be stuck on the keyboard causing the pc to quickly go into sleep mode
Nov 22, 2009 | HP Vs17 17" LCD Flat Panel Monitor
MAG 780 lcd Monitor
It's risky... But try reinstalling your, Graphics Driver, Sleep mode is used occasionly if you use it too often your screen will eventualy wear away. If that still don't work. Try reinstalling Windows.
Jul 14, 2009 | Computers & Internet
I keep resetting my pc because my monitor just keeps blinking showing nothing on the screen. I need help
Your monitor MAY have a built in sleep timer. You can usually find it in the Monitor's Menu, under the category " MANAGEMENT " Disable the sleep timer and you shouldn't be having that problem anymore.
Jul 05, 2009 | Hanns.G Corporation HW173D Monitor
Monitor goes to sleep and never wakes up
I have called HP Technical Support 6 times about this issue and have logged at least 14 hours into the issue. The things they have done are turn all sleep settings in the "Power Options" in the control panel to "never". The problem persisted. Today, they sent my problem to the complaints department, so maybe they will have the authority to do something for my 5 week old setup.
For me, the monitor was in the "other devices" part on the device manager (go to start menu and type device, and the device manager will show up). I went to HP's website to the support and drivers spot and found a patch for the My Display program. This will allow you to uninstall your monitor, just right click the monitor under "other devices" and click uninstall. After you uninstall, restart and your computer will recognize the and put it under "monitors" in the device manager with the updated drivers. After I did this, the monitor hasn't gone to sleep.
Jan 24, 2009 | HP w2207 Monitor
Fitbit One Wireless Activity & Sleep Tracker, Burgundy Logo
64 people viewed this question
Top Fitbit Home Security Experts
Steve Schafenberg
Steve Schafenberg
Level 1 Expert
Andrew Taylor
Andrew Taylor
robert
Are you a Fitbit Home Security Expert? Answer questions, earn points and help others
