Question about GPS
Garmin nuvi 1930
Can I buy a marine sd card
SOURCE: Garmin Nuvi 650 660 680 6XX SD Card PNY 4GB SDHC Works
Wow! I just went out and bought a PNY SDHC 4gb memory card. Loaded it into my NUVI 680 and hooked it to laptop with USB cable. Saw the 4mb G drive right away. Havent synced music to it yet but cant see any problem. Thank you.
Posted on Mar 25, 2008
  • 26 Answers
SOURCE: SD Card slot Garmin nuvii 260
I have found that waypoints, routes and directions work only when I load it on the unit itself as opposed to the SD card. The SD card works more like an expansion slot for pictures or maps.
When you open up Mapsource you'll see the map on the right and the pane on the left, above the pane there are 4 tabs (Maps, Waypoints, Routes and Tracks). As you select a map or create a waypoint, route or track. It will put a number in parenthesis which will increase in numbers as you add an item corresponding to each category, for example if you create a waypoint. So once you have done that, click on the TRANSFER tab in the Menu selection bar and choose SEND TO DEVICE. A window will pop up that will say...Device: with a drop down menu if your Garmin unit has an SD card in it, if not it will just show the Garmin unit. Then right below that there will be a section that says WHAT TO SEND with 4 check boxes that will say Maps, Waypoints, Routes and Tracks. Make sure that you have selected the Garmin unit, not the SD, and the waypoints, routes or tracks you want to send. I hope this solves your problem or at least points you in the right direction...
Posted on Jun 25, 2008
SOURCE: Garmin nuvi 260
Re: Not sayinstreet names.
After you turn on your unit touch the wrench icon in the bottom right of the screen, this will take you to a menu which features "Settings" in the upper left of the screen. Touch "settings" and scroll down to "language" by using the up and down buttons in the lower right of the screen (down 1 should do it). Touch "Language" and in the voice category find and select "American English - Jill (TTS)". This is the voice that will give you Text To Speech (TTS) speaking the street names in English. If you prefer Spanish or French, find the appropriate catergories with "(TTS)" beside them - "Espanol Americas - Paulina (TTS)" and "Francais Canadien - Julie (TTS)" respectively. Any other selection will only give directional instructions such as "turn left in XXX".
After you have selected your voice press "OK" and back out to your main menu showing "Where to?" and View Map".
Now, when you navigate, you should hear an American female voice giving you directions by street name - assuming your volume is high enough to hear it.
RE: The computer icon displaying when you try to use your unit in the car with the 12 VDC cord.
You probably have a problem with the cord. The pin length in the USB style connector is critical and if it doesn't match up just right the GPS thinks it is hooked up to a computer. If you know someone who has a Garmin NUVI try using their cord and see if you have the same problem. Either way, call Garmin and see if they will send you a replacement cord or otherwise help fix the problem.
Posted on Nov 03, 2008
SOURCE: Nuvi 200w map download and sd card
Guys and or ladies... I know that you have to create a folder named "GARMIN" in the sd card so the maps can be recognize. Maybe this solves your problem. Let me know if it works.
BR from Spain,
Carla
Posted on Apr 01, 2009
SOURCE: garmin Nuvi 760 memory card
Does the Garmin Nuvi 760 require an additional memory card for normal use?
The simple answer is : no it does not need and SD card to work
Posted on May 22, 2009
How do i install an sd card in my garmin nuvi 1370T
I have a Nuvi 680. I bought a 4G SD card for more storage. Yesterday Garmin sent me a new map to install and now the Nuvi is telling me there is not enough space. Can't be! Nothing was ever installed onto the SD card since I only put it into the Nuvi today. Help, what am I doing wrong?
Apr 05, 2012 | Garmin nuvi 1370T Car GPS Receiver
Garmin nuvi 780 says no data found and no maps
Sounds like the data on your SD card is corrupt. If you know somebody else with the same unit and model try their SD card. If not them you are most like going to have to buy a new SD card and install the maps and operating system onto the new card. Should be instructions on you install Cd assuming you have them.
Apr 26, 2010 | Garmin nuvi 780 GPS
How do youcess your sd card on the garmin nuvi 200w series please
i lost my card for my garmin nuvi 200w series do i really need it
Mar 21, 2009 | Garmin nuvi 200W GPS Receiver
Unocking Garmin SD maps
it is in the box it came with, on the back of the instruction book.
If you did not buy it 'new in the box', you will have to refer to the 'activation' code sent to you email.
The Garmin Nuvi 760 does not require SD card maps if you are using it in the US, btw...
-d
Feb 15, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin nuvi 610
500Mb internL MEMORY ONLY- LOAD MAPS TO SD CARD TILL 4 gB WORKING
Oct 27, 2008 | Garmin Nuvi 610 GPS Receiver
Data card for nuvi 660
No, you do not require an additional SD card for your unit in order for it to operate. Also, you can purchase ANY SD card and it will work with additional maps and POIs. They are upselling you.
It doesn't sound like you're buying from a reputable Garmin dealer. Make sure they're a Garmin dealer in case you have any problems.
Apr 10, 2008 | Garmin Nuvi 660 GPS Receiver
Audiobooks on a Garmin Nuvi 650 GPS
I just read on the Garmin website that only regular MP3 files will work -- not books or music purchased through iTunes.
Dec 29, 2007 | Garmin Nuvi 660 GPS Receiver
USA MAPS
You need to buy a preloaded SD card, purchase maps from Garmin and download them to a blank SD card.
Dec 10, 2007 | Garmin nuvi 350 GPS Receiver
GPS Logo
21 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
