Question about HP Media Center m7640n home PC - RF243AA 19" LCD Flat Panel Monitor
NO POST OR SIGNAL TO MONITOR. ON MY MEDIA CENTER HP A8M2N-LA REV 1.06 MOTHERBOARD
3 Suggested Answers
  • 8 Answers
SOURCE: HP f1903 LCD Monitor mild flickering & color variance
I would bet it is the cable or connection. Have you tried connecting the monitor to a different PC?
Posted on Feb 18, 2007
  • 477 Answers
SOURCE: I need bios version 3.0 for motherboard A8M2N-LA,GL-6
Hello, go here this is the only place I found the 3.0 version. scroll down on the website fill in your mail address and get a download link to your email.
"You can create a new account for free. Members have unlimited access to all files.
If you want to download only this one file, we will send a download link to your e-mail."
Posted on Aug 17, 2009
A8M2N-LA m/b audio connector explanation?
It's for use with Front Panel Audio sockets.
"One 9-pin audio header for headphone-out and microphone-in"
Your Manual is here:-
http://h10010.www1.hp.com/ewfrf/wc/document?cc=uk&lc=en&dlc=en&docname=c00714578
Feb 26, 2014 | HP Nodus3 Motherboard Asus A8m2n-la 45...
Connecting cdrom &dvdrom to A8M2N-LA m/b?
You may have to use the front Line Input connector F_LINE_IN1 in the corner. There doesn't appear to be a dedicated DVD audio input listed on the internal connector listing in the manual:-
Hp pavilion a1610n post beep no video
Remove your ram clean it clean the slots reinsert ram and retry..
Jan 02, 2013 | HP Pavilion a1610n PC Desktop
Front panel pinout connections for ASUS A8M2N-LA (NodusM3
The Asus A8M2N-LA motherboard was made SPECIAL for HP.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00757531&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3339286
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00820191&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3339286
As such Asus has no info on it.
Looking at the second link posted (Motherboard Specifications), scroll down to the bottom, and click right on - Motherboard Layout
Motherboard layout shown (Direction), is the same as is installed in your computer; Processor to the Top, white PCI slots to the Bottom, Ram Memory to the Right.
The plastic front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the cables (Wires) go to from the Front Panel, is the Front Panel header.
Abbreviated F_PANEL 1, at the bottom right corner of the motherboard, is the Front Panel header.
There are 9 contact pins. Two rows.
Across the Top row they are numbered ODD.
Across the Bottom row they are numbered EVEN.
Coming from the Left side of the motherboard towards the right side, on the Top row;
Pins 1, 3, 5, and 7
Coming from the Left side of the motherboard towards the right side, on the Bottom row;
Pins 2, 4, 6, 8, and 10.
A) Pins 1 and 3 are for the HarDDrive activity LED light.
Pin 1 is for the Positive wire. ( + )
If the HDD LED is dim when operating, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pins 2 and 4 are for the Power On LED light.
Pin 2 is for the Positive wire.
D) Pins 6 and 8 are for the Power On switch.
Regards,
joecoolvette
Apr 10, 2012 | Gigabyte Computers & Internet
I would like to install a second HD on my HP Pabilion a1540n desktop. What are the specs so I can buy it.
HP Pavilion Media Center a1540n Desktop PC Product Specifications
Hardware Base processor Athlon 64 X2 (W) 4200+ 2.0 GHz
  • 2000 MT/s (mega transfers/second)
  • Socket AM2
Chipset GeForce 6150 LE Motherboard
  • Manufacturer: Asus
  • Motherboard Name: A8M2N-LA
  • HP/Compaq motherboard name: NodusM-GL8E
Memory Component Attributes Memory Installed 2 GB Maximum allowed 4 GB* (4 x 1 GB)
*Actual available memory may be less Speed supported PC2-4200 MB/sec Type 240 pin, DDR2 SDRAM Hard drive
  • 250 GB SATA
  • 7200 rpm
16X DVD(+/-)R/RW (+/-)R DL LightScribe drive
  • Must use Double-Layer media discs in order to take advantage of the DL technology
  • Must use LightScribe-enabled media discs and supporting software in order to take advantage of the LightScribe technology
Sep 04, 2011 | HP Pavilion a1540n PC Desktop
Trying to upgrade a Compaq SR1020NX computer. The HP website still has old info, likely based on the original bios. The motherboard is an Asus A8M2N-LA. What CPU upgrades will run on that board? Is there...
The ASUS A8M2N-LA is the motherboard used by HP for the new D4500e AMD AM2 PC.
Here are the details:
Motherboard manufacturer's name: ASUS A8M2N-LA
HP/Compaq name: Nodus-GL8E
CPU/Processor  Socket: AM2 Supports AMD Athlon 64, Athlon 64 X2, and Sempron processors
Front-side bus (FSB)  2000 MegaTransfers/second
Chipset  GeForce 6150 LE chipset
BIOS features  Award brand system BIOS Keyboard combination to used to enter BIOS: F1
Form factor  Micro-ATX: 9.6 in X 9.6 in
Memory  Four 240-pin DDR2 DIMM sockets, Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs, non-ECC memory only, unbuffered Maximum HP/Compaq approved memory is 4 GB*
PS - as you can see the rangeis 533 - 667 MHz. I would suggest you call HP support and ask if it will support 800 MHz,
Feb 15, 2010 | AMD Athlon 64 X2 5400+ Processor...
Aug 17, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Asus A8M2N-LA MOBO fans spin but no beeps or anything else
try by switching on the comp.without ram ,check weather the motherboard gives any beep
If No then take out motherboard from chassis ,and try to power on the comp. with some barrier bet chassis and mother board
Mar 15, 2009 | Computers & Internet
Ram Upgrade
Max speed supported for your mobo is: DDR2-533
You will have to buy (4) 1gb sticks (2gb sticks not supported)
To use all four gigs of ram you need a 64 bit os.32 bit only supports 3gb of ram. Hope this helps!
Here is the specs :
ASUS A8M2N-LA (NODUS-GL8E) (DDR2-533MHz) Memory Maximum Memory 4GB Memory Slots 4 (4 banks of 1) non-removable base memory 0MB Machine name: ASUS A8M2N-LA (Nodus-GL8E) Motherboard
CPU options: Supports AMD Athlon 64, Athlon 64 X2 and Sempron processors.
Chipset: Nvidia GeForce 6150 LE Chipset
HD Bus:
Front Side Bus options:
Memory Speed options: PC2-4200 DDR2-533 240pin SDRAM DIMM
Special notes:
- Motherboard manufacturer's name: ASUS A8M2N-LA
- HP/Compaq name: Nodus-GL8E
NOTE: *Actual available memory may be less w/o 64 bit os
Dec 24, 2008 | Computers & Internet
HP Media Center m7640n home PC - RF243AA 19" LCD Flat Panel Monitor Logo
14 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
