How to setup sony s master dav s800
What do i have to do to be able to have my sky and tv on suround sound
5 Suggested Answers
  • 13 Answers
SOURCE: connection/sound issues!
the best thing to do is if ur lcd has a phono in/out is to connect ur theatre system through phono straight to the tv as then everything that comes up on the tv comes throught the theatre system
Posted on Feb 10, 2008
  • 16 Answers
SOURCE: sound not loud Sony DAV-IS10
I think its the fact that the speakers are pretty tiny, even tho BOSE has proved that size doesnt matter. i will agree i have a descent size home and i have to max it out all the time to watch a movie
just a design flaw IMHO.
Posted on May 09, 2008
tech48
  • 624 Answers
SOURCE: Sony Trinirton TV and DAV-HDX 275 System
Here are a couple of the most common reasons for your problem:
Make sure you have selected the right input source on the DAV-HDX275 that your TV station source (cable, satellite, direct TV or whatever you get TV stations from) is connected to on the DAV-HDX275.
Also make sure that if you are using a digital input (HDMI, optical, or coaxial) from the TV station source, that the DAV-HDX275 in set for a digital input and on the right source.
If you are using an analog source (red and white RCA jacks) for the TV stations , make sure you do not have the digital input activated for that source on the DAV-HD275. You need to select the analog option.
You must also be sure that you have a cable, whether it is analog or digital, connected from the cable box to the DAV-HD275.
I hope this was helpful to you, it is always very important to double check all the connections and make sure the stereo is set to the right type of input (digital or analog).
If you have found this to be helpful, a good rating is always appreciated. Thanks and let me know if you need any more help.
Posted on Jun 22, 2008
SOURCE: Surround sound to work with sky+
hi yes it is....
wot u need to do is.....our red and white audio leads go from sky box to dvd box...we then put our dvd player onto video 1 using function button on remote
hope this helps
Posted on Mar 26, 2009
Hi, i have a DAV-DZ330/DZ730 and i cant get sound from the tv/sky. TV is a bravia KDL 40NX503. Its HDMI connected and ive been through the sync process and made sure the hdmi settings are ON on the amp. No...
i had the same problem with my dz330. simply attach you sky box via scart to the back of your sony box and hey presto you should have sound when selecting tv mode from the sony remote
Aug 14, 2010 | Sony DAV-DZ100 System
I tried to plug Sony DAV-HDX279W into my tv with simply plugging yellow white and red into each unit but I get no sound.
common fault make sure the red and white are in the correct plugs as most units have 5.1 suround there are 3 sets of sound outputs use LF & RF
BEST OF LUCK
Aug 03, 2010 | Sony BRAVIA® DAV-HDX279W Theater System...
Hissing and Humming when trying to use the speakers for the tv
The sony manual tells you how to connect to a TV however most of us now watch TV connected to a SKY box. The Scart lead needs to be connected to the Sky box for the sound to work correctly. Ignore the Manual and connect the Scart lead from the DVD Unit directly into you're sky box. It works fine.
Apr 04, 2010 | Sony Audio Players & Recorders
How do i connect to sky hd and sony kdl 40w 4710 and dav-is10 i have hdmi from skyhd to tv and hdmi from home cinema to tv what else is required as i cant get surround sound from tv
you need a Optical audio cable, run this from the back of your Sky HD box to the Surround sound. Not all Broadcast are transmitted in DD so press your i button on the sky remote and you will see this on the yellow bar above the program information if it is..
Might be worth running a set of White and Red audio cable from the HD box to the Surround sound as well that way you can just mute your telly and have the lot coming through the surround sound system.
Hope this clears things up for you
Little Dish Fitter
Jun 05, 2009 | Sony DAV-IS10 System
No suround when watching tv with sky + box,
You will need a DVD player with an optical output, as the sky engineer said. A Co-axial S/PDIF output could also work if your surround sound has that input, however not all units transmit surround encoded sound through the Co-Axial output. Only option really is to upgrade if that doesn't work
Mar 05, 2009 | Televison & Video
hi yes it is....
hope this helps
Feb 20, 2009 | Sony DAV-S300 System
I have just bought a Sony DAV-dz260 home theatre system. I connected it viz HDMI to my 1080p tv and it works fine. I also have a Sony PS3 connected via HDMI to my TV and this works fine too. I have...
i have the same dav dz260 and all my stuff works on mine. this is how i set it up i have conected y dz to the tv via scart and my sky and ps3 via hdmi cable. to get sound from sky and ps3 i conected a optical cable from the dz260 to the tv and when i want sound for sky or ps3 all i did was change the function on the dz260 to tv and the tv setting to the hdmi im using and hey presto sound hope it helps
Nov 11, 2008 | Televison & Video
Can't wire up to LG plasma HELP
Ah, I assume you have put rca's from the TV audio out to the Audio in of the Theatre System! Then put the Audio System to Aux 1 / 2 and you should have sound through your Theatre System!
Feb 20, 2008 | Sony DAV-S500 System
Connection/sound issues!
Feb 10, 2008 | Sony DAV-IS10 System
19 people viewed this question
 Grubhead
Grubhead
