Question about Cat5e Computers & Internet
Lag switch cut the solid orange cable of a cat5e cable, added a switch. switch is in on position, connected. off position disconnected. when switch is off needs to present a lag in connection not a complete disconnect
    Problem Solver:
  • 30 Answers
Hey, you are dealing with high frequency - what a strange idea is this? Do you have a 100Mb/s- or 1Gb/s-network? What do you want to achieve?
Posted on Nov 27, 2014
osborne382
  • 306 Answers
SOURCE: Cat5e to RJ11
You wont be able to....You need another NIC...you can Pick one up at Circuit city of best buy for about 10 to 15 bucks.
Posted on Nov 10, 2007
  • 55 Answers
SOURCE: Connecting Cat5e cable to BT 78A junction box
You can get this device to help you.
http://www.run-it-direct.co.uk/run-IT-direct%20Price%20List.pdf
I believe it is on the 8th page.
Posted on Oct 17, 2008
cnavarro
  • 2460 Answers
SOURCE: CAT 5E DISTANCE
Considering what you started with, it should be slow :-)
If this were my installation I would run HUGESNET>Router>BRIDGE>BRIDGE>ROUTER/AP>PC
The first router is the 150N. The Bridges are two Wireless Access points in bridge mode designed for distance. A nice unit for this application is a TP-Link WA-601G with antennas (ANT2408) found here:
http://www.tplink.com/products/wlan.asp
It will cost you an extra $100-150 depending on antenna, but it should get you good results, considering the SAT is probably 300 down and 128 up :-)
Carl
Posted on Apr 10, 2009
SOURCE: switch to switch connection
sir mujhe 2 swich add karna hai me kya karu kaisi cable banana hai ple aap bataiye
Posted on May 25, 2010
SOURCE: how to connect RJ45 cat5
how i can punch cat 5 cable in cat 5 io box
Posted on Mar 11, 2011
Am having to log in and out or refreshing my pages slow speed freezing lagging
Michael, are you running wired, or wireless connection? With a wireless connection, if other people are accessing the same router, it allocates a percentage of the bandwidth to each device. For example; If your max speed is 100mbps, and you have your smart phone accessing the router, than about 1/2 of the internet is going to the phone connection, and the rest to your system. The more devices attached to the router, the slower it will become. If you are having problems like this and running it "Hard wired" then the issue could be a bad connection between your router and the system. Try swapping out the cat5 line with a new one. These have become really inexpensive now, and I would suggest have 2 or 3 for backups.
10 ft feet Cat5 Cable CAT5E RJ45 LAN Network Ethernet Router Switch Patch...
Nov 02, 2015 | Sony Playstation 3 (PS3) Console
What is the difference between, Flex, Shielded & Solid Cable?
http://www.ebay.com/gds/What-are-the-Different-Types-of-Ethernet-Cables-/10000000177629325/g.html
Oct 23, 2013 | Computers & Internet
GE Network & Coax Wall Plate has 8 wires of solid colors. My CAT5E cable has 8 wires, only 4 of which are solid and correspond to 4 of the solid colors on the wall plate. The other 4 wires on the CAT5E...
Hello
Your cat5 will make up 4 pair. org/org/wht being one pair and so on.
So as long as you keep them in pairs you will be ok.
Meaning. Pair one from cat5 org and org/wht to wall plate wht and brn.This would be one complete pair.So the wall plate colors are different from cat5 but as long as you stay in pairs and go from left to right on your conections you should be ok.
Jun 05, 2011 | Computers & Internet
Game speed very slow and system lags behind, when pressing selections during game. I have a wireless router, don't know if that could be the problem.
Wireless routers can be "ok" for gaming but for any REAL gaming you need to be hardwired (cat 5, ethernet cable)
Cat 5 is twive the speed of wireless and if yours is an older wireless then it can be up to 8 times faster using cat5
You need a good solid 5 bar signal to even consider any heavy games. Any less or intermittant connections cause a lot of lag.
Some older routers have soecific settings for gaming so you may want to investigate those.
You neglected to give the router make and model so I cannot advise much more than this.
Sep 25, 2010 | Computers & Internet
Tell me the color coding of wall jack to connect cat6 cable to the switch
You can use either T 568 A or B providing that both ends of the cable are wired in the same format. If one side is allready ended thenI would try T568 B standard first.
Pin T568A Pair T568B Pair Wire T568A Color T568B Color Pins on plug face (socket is reversed) 1 3 2 tip 60px-wire_white_green_stripe.svg.png
white/green stripe 60px-wire_white_orange_stripe.svg.png
white/orange stripe rj45plug-8p8c.png 2 3 2 ring 60px-wire_green.svg.png
white/orange stripe 60px-wire_white_green_stripe.svg.png
white/green stripe 4 1 1 ring 60px-wire_blue.svg.png
white/blue stripe 60px-wire_white_blue_stripe.svg.png
white/blue stripe 6 2 3 ring 60px-wire_orange.svg.png
white/brown stripe 60px-wire_white_brown_stripe.svg.png
white/brown stripe 8 4 4 ring 60px-wire_brown.svg.png
Sep 09, 2010 | Leviton (102-5G108-RW5)
Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Apr 11, 2009 | Computers & Internet
Switch to switch connection
in the 1st end of your cat5 cable the color codes are: white orange, orange,white green,blue,white blue,green,white brown,brown and in other end codes are: white green, green, white orange, blue, white blue,orange,white brown,brown....gud luck
Jan 16, 2009 | PC Connection Cross-Over Cable (363003X)
Cat5e 350mhz wire
What you can do with the cat5 cables is plug the wire into the PS3 and the other end into your home router or switch. This might be a problem if your router or switch is in another room or so but it will most likely give you less lag.
Hope this helps, let me know if ya have problems connecting if you decide to use the cat5 wire but it should be about the same setup as using wireless.
Aug 14, 2008 | Cat5e 10ft White 350MHz Stranded Snagless...
3 netopia 2247 routers daisychained
How far are you running the CAT5 cables from house to house?   CAT5e only has a solid range of about 150ft, and anything near 100ft is pushing it.  You may also need to use CROSSOVER cables when plugging routers into other routers.
Also, who has the actual internet connection?  I'm assuming House 2 does.  One big problem is a router is your Gateway address.  And, if house 2 is the only one with a valid Internet connection (via DSL or Cable, etc), then the router in house 2 is the only "true gateway".  And, all 3 houses need to be in the same physical network (i.e. 192.168.1.0 range or whatever), and all computers should have the same Gateway address...which would be the IP address of the router in House 2.
What you really need in this situation is 1 router and 2 switches.  Put the router in House 2 and put switches in House 1 and 3.  That would be the best way to handle this problem.  It would also end your connectivity problems.
Cheers!
Jul 11, 2008 | Netopia 2247NWG-VGx Wireless Router...
Networking
This site will give you directions on how to make a CAT5 cable. http://www.computerhope.com/issues/ch000639.htm
Sep 17, 2007 | Computers & Internet
Computers & Internet Logo
175 people viewed this question
Top Cat5e Computers & Internet Experts
KG John Justin
KG John Justin
Vuk B
Rishi Solutions
Rishi Solutions
Are you a Cat5e Computer and Internet Expert? Answer questions, earn points and help others
