Hack linksys clone mac address befcmu10 ver. 4
Doesnt appear to have MAC cloning... is there a hack?
  • 196 Answers
SOURCE: Finding the MAC Address of a Macintosh
Please follow the instructions which fits the Mac OS that is being run: OSX 1. Click on the Apple menu and select the System Preferences option. 2. In the "System Preferences" window, Select Network. 3. When the "Network" Window opens, select Built-in Ethernet and/or Airport from the "Show" Menu. 4. Once you do this, look near the bottom and you will see the Ethernet Address or Aiport ID. This is the MAC Address, make note of it. OS9 and below 1. Click on the Apple menu option. 2. Go to the Utilities folder 3. Open the program called Apple System Profiler 4. Select the System Profile tab 5. Under Network Overview > Appletalk> 6. Once there you will find the Hardware address, this is the MAC Address, make note of it.
Posted on Feb 16, 2006
  • 196 Answers
  • 217 Answers
SOURCE: actiontex gt704wg mac cloning
Go here:
http://www.actiontec.com/support/broadband/gt704-wg.html
If Actiontec doesn't have your answer, then you'll want to get a separate hub or router to connect both computers.
Posted on Jan 29, 2008
oldnovii
  • 667 Answers
SOURCE: MAC address cloning
Hi killer - MAC (Media Access Control) cloning is used to clone your MAC address.
Some ISPs (most notably MediaOne) use your NIC's MAC address to authenticate your service. When you change the computer that you have connected to your cable modem service, you usually have to call up Tech Support and give them the MAC address of the NIC in the new machine. Since hardware routers have the equivalent of a NIC on their WAN port in order to connect to your cable modem, you would have to do the same thing if you're installing a router.
Recently, however, some ISPs have started to recognize the MAC addresses of popular routers and disconnect service if a router is detected. Fortunately, many router manufacturers are including the capability to either set the router WAN port MAC address to anything you want, or copy it from a computer connected to the router LAN side. You can check the Router comparison chart under "Mac addr. clone" to see which routers support this feature. Then consult the router's documentation for directions on using the feature.
So basically, it's used to fool ISPs into thinking there isn't a router. If the router has the same MAC address as either your NIC card or your modem the ISP won't detect and service won't be interrupted. Most ISPs don't do this so iy's rarely needed.
If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
Posted on May 22, 2008
  • 1214 Answers
SOURCE: MAC address
Why do you want to clone the router's MAC address?
If you want the router's MAC address, go to the Admin (I believe it is) page.
That button is for cloning your Desktop or Laptop computer's MAC address, and unless you are being instructed to, there is no need to.
Posted on Jan 19, 2009
I want to connect a Scientific-Atlanta WebSTAR 2000 series Cable Modem to a Linksys Wireless-G WRT54G wireless router but the linksys doesnt detect the modem and the computer wont let the setup program for...
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer that's registered with the ISP.
To setup a Linksys router with Cable connection you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting Devices Together
iii. Checking the Router's LEDs
iv. Configuring a Linksys Router for a Cable Internet Connection
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 19, 2010 | Linksys Wireless-G WRT54G Router
My linksys w/2phone ports cannot hook up with the ethernet
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
ii. Connecting the Devices Together
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Need to mate my rotor with my cable internet
You need to get to the web configuration page of your router and clone the MAC address of your modem. It's because cable internet providers uses MAC address of a device to be able to connect to their server.
You can follow this manual to access the web configuration tool and look for the topic MAC Cloning Address.
http://downloads.linksysbycisco.com/downloads/WRT54GL-EU_11_UG_A-WEB.pdf
If in some case, your internet didn't work after connecting the router and after cloning the MAC address of your modem. Try to turn off your modem and disconnect everything from there, turn off your router as well and disconnect everything. Wait for 1 minute and plug the power cord back to your cable modem and plug the ethernet cable. Wait for 1 minute, turn reconnect everything to your router to the modem, and Clone the MAC address again.
Hope this helps.
Jan 13, 2010 | Linksys Wireless-G WRT54G Router
Can connect to internet with linksys WRT310N
If you are on Cable Internet, you need to do MAC Cloning. Open the router's Setup Page through http://192.168.1.1 then look for Mac Address Clone sub-tab under the the SETUP tab. Enable it and click on Clone My PC's MAC then click on Save Settings. You need to power cycle the device now. Unplug the power to the router and the modem. Wait for 30 seconds. Power on the modem first and wait for the lights to go solid, then power on the router. You should be good to go.
Jun 23, 2009 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Router not seeing internet connection
If you are on cable internet, you need to perform MAC Address Cloning. Access the router's setup page using your main PC, under SETUP tab, there's a sub-tab called MAC Address Clone. Enable that and click on "Clone My PC's MAC" then click on Save Settings. Power cycle the router and the modem. You should be online after that.
Jun 09, 2009 | Linksys Wireless-G WRT54G Router
MAC address
Jan 19, 2009 | Linksys Wireless-G Broadband Router
How do i connect a linksys wag200 to cable
Most cable Internet Service Providers (ISP) use a Media Access Control (MAC) Authentication to establish Internet connections for end-users. A MAC address is assigned a unique 48-bit (6-byte) integer that is attached to an Ethernet NIC for each computer. To set-up your Linksys gateway to a Cable ISP, you have to do MAC Cloning. MAC Cloning is a procedure which enables a gateway to copy the MAC Address of the PC that’s registered with the ISP.
To setup a Linksys gateway with Cable connection you need to perform five steps:
  1. Verifying Internet Connection
  2. Connecting Devices Together
  3. Checking the Gateway’s LEDs
  4. Configuring a Linksys Gateway for a Cable Connection
  5. Power Cycling
More detailed information can be found from the Linksys website
Sep 13, 2008 | Computers & Internet
Can not get on internet with ether pc after conecting all cables
With most DSL modems, make sure that the modem is in the "Bridge" mode. As your ISP, or consult the instructions manual about the Bridge mode.
With some IPS services, they are looking a particular MAC address for the registered computer. This is part of their security. You can call your ISP for details. If it is a particular MAC address that they are looking for, there are ways that you may be able clone the MAC address in the router.
If this is the case and you want to learn more, do some searches for MAC Address router cloning.
Jerry G.
Apr 19, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Router MAC address
You cant change the mac addresses they are like our ss#'. You can how ever clone your pc's mac to your router. I have several differant routers that I use. one at a time to change my mac addresses.
Dec 31, 2007 | Linksys Wireless-G WRT54G Router
Setting up the BEFVP41 Router with a Cable Modem and a Dynamic IP Address
Connecting the Router and the Modem 1. Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. 2. Shut down the computer, and unplug the power cables to both the router and the Broadband modem. 3. Disconnect the Ethernet cable from the computer and plug it into the Internet or WAN port of the router. 4. Take the Ethernet cable that came with the router (or any another available cable) and connect it to the computer. Then, take the other end of that same cable and connect it to Port 2 on the back of the router. 5. Plug in the Broadband modem's power cable and wait for all of its lights to stop blinking. 6. After the lights on the Broadband modem stop blinking, plug in the router's power cable. 7. Start up the computer. Obtaining the PC's MAC Address Windows 98SE/ME 1. Click on the Start menu, then click on the Run option. 2. When the ?Run? window opens, input winipcfg into the ?Open? field, then click on the OK button. 3. The ?IP Configuration? window should appear, select the Ethernet Adapter that the PC is using from the drop down list. 4. Make note of the ?Adapter Address? which is the MAC Address. Windows XP/2000 1. Click on the Start menu, then click on the Run option. 2. When the ?Run? window opens, input cmd into the ?Open? field, then click on the OK button. 3. When the ?MS DOS Prompt? appears, input ipconfig /all then click on the [Enter] key. 4. Make note of the ?Physical Address? of the Ethernet Adapter (normally ?Local Area Connection?). Accessing the Setup Page 1. Open a web browser such as Internet Explorer or Netscape. 2. When the browser window opens, go to the Address bar and type in the router's IP Address and click on the Go button (192.168.1.1 is the default IP address of Linksys Routers). 3. A window will appear prompting for a ?User Name? and a ?Password?. Leave the ?User Name? field blank, and type in the router's password and click on the OK button to login (admin is the default password). 4. The router's web-based ?Setup? utility should then load. Cloning the MAC Address The steps for configuring the MAC Address Cloning feature of a Linksys router vary depending on the firmware version the router is currently using. From the router?s ?Setup? page, locate the Linksys logo in the upper left-hand corner of the page. Follow the instructions below depending on which logo matches your specific screen: If the logo matches the image above ("Linksys - A Division of Cisco Systems, Inc."), follow these steps. If not, skip to the next logo version. 1. From the ?Setup? page, click on the MAC Address Clone sub-tab. 2. In the ?MAC Clone? section, set the option to Enable. 3. Click on the Clone Your PC?s MAC button. Once this is done, the ?User Defined Entry? will show MAC Address of the Ethernet Adapter of the computer you are using. Verify this address with the ?Adapter Address? or ?Physical Address? observed in earlier steps. 4. Click on the Save Settings button. Then, click the Continue button if prompted. If the logo matches the image above ("Linksys"), follow these steps: 1. From the ?Setup? page, click on the Advanced tab. 2. When the ?Filters? page loads, click on the MAC Addr. Clone tab. 3. When the ?MAC Address Clone? page loads, enter the the ?Adapter Address? or ?Physical Address? that was observed in earlier steps. 4. Click on the Apply button. Then, click the Continue button if prompted. Power Cycling 1. Shut down the computer. 2. Unplug the router?s power cable. 3. Unplug the Broadband modem?s power cable. 4. Wait for 30 seconds. 5. Plug in the Broadband modem?s power cable and wait for its lights to stop blinking. 6. Plug in the router's power cable once the modem?s lights stop blinking. 7. Finally, start up the computer and test the Internet connection.
Feb 16, 2006 | Linksys EtherFast Cable/DSL VPN Router...
Computers & Internet Logo
132 people viewed this question
David Payne
David Payne
