Question about Radio Communications
EP12 bluetooth headset won't synch with LG Optimus Pro
My Plantronics Voyager+ EP12 will not show as discoverable to my LG Optimus Pro, the headset worked with my iPhone 4S perfectly but I can't get it to show up on this phone. Help.
SOURCE: Motorola H550 Bluetooth Headset
Here is the user manual for the bluetooth headset.
User Manual
Pairing with the LG will be similar, your bluetooth settings will be under settings and tools, and either under "bluetooth" or "connections".
Posted on Jan 21, 2008
  • 5 Answers
SOURCE: Plantronics Voyager 510 & Blackberry Curve
 Plantronics Support Phone Number: 1-800-544-4660
Do not use the power button to sync.
To sync device, Press + button (volume) and Silver button (on boom) at simultaneously. LED Light will blink RED & BLUE.  Device ID should appear on your screen.
Posted on Mar 12, 2008
PyroPCMan
  • 405 Answers
SOURCE: pairing motorola h500 with an lg voyager phone
Good Day,
Passcode is "0000"
Hope this helps
Posted on Jul 02, 2008
  • 239 Answers
SOURCE: bluetooth code Plantronics 330 to LG AX300
try these codes
1234
4321
9876
6789
9999
0000
one of them will work
best of luck
please remember to rate me.
Posted on Mar 06, 2009
SOURCE: LG HBS-200 Headset w/Bluetooth. Phone works. Music does not.
iphone works well with LG HBS 200, I am listening to music in iphone though LG HBS 200 right now..it works like charm
Posted on Oct 05, 2009
How I can listen music through headset
Your Plantronics Voyager Pro Plus is equipped with A2DP which makes the streaming of music in the headset possible. However if the phone you have does not have that application it won't happen.
Good luck from Headsets Direct!
May 26, 2011 | Plantronics Voyager PRO Bluetooth Headset
I connected my plantronics voyager pro to my blackberry bold and they connected fine (never asked for passcode) but there is a continual beep in the back round that makes the sound of the other call be...
Try to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Once you make your Blackberry discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
May 02, 2011 | Plantronics Voyager PRO Bluetooth Headset
Plantronics voyager pro plus is connected and paired with blackberry tour. when a call is coming in, I cannot answer or hang up the phone from the bluetooth headset.
Make sure that your Blackberry's headset mode is activated. If the headset mode is turned on in the Blackberry menu and settings, you may also need to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Mar 09, 2011 | Plantronics Voyager PRO Bluetooth Headset
The handset lifter works, but no sound can be heard or received by either party
If you have a 510a base, then purchased a Plantronics Voyager Pro headset to replace your old headset, it won't work. Those are two different headsets. The Voyager Pro is not meant to work with the 510a base. The correct headset is this:
Plantronics Voyager 510 Replacement Headset
Jan 27, 2011 | Plantronics Voyager 500A Deskphone Adapter...
I cannot connect my Plantronics Voyager Pro to my iPhone 4.
Once you make your iPhone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Jan 25, 2011 | Plantronics Voyager PRO Bluetooth Headset
I am geting really bad staic in my plantronics voyager pro. I have the HTC EVO. Is there any way to get rid of the static?
Once you make your cell phone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Jan 08, 2011 | Plantronics Voyager PRO Bluetooth Headset
I have a samsung rogue and I all I hear is mostly static with the Plantronics Voyager PRO
Make sure that it has a good connection, try to re-pair the headset to your phone. Before running through the pairing process, be sure to totally delete the headset from the phone's menu. You may want the headset turned off for this process.
Dec 25, 2010 | Plantronics Voyager PRO Bluetooth Headset
Cant set to my phone
Dec 13, 2010 | Plantronics Voyager PRO Bluetooth Headset
Cutting in and out. best described as sounds like i am talking into a fan.
Once you make your cell phone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions:
Plantronics Voyager Pro User's Guide
http://www.headsetsdirect.com/plantronics-voyager-pro-bluetooth-pairing-instructions
Also if you have a different phone available just to test, see if it does the same thing.
Sep 15, 2010 | Plantronics Voyager PRO Bluetooth Headset
Radio Communications Logo
47 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
