Question about Ricoh Aficio MP-C6000
Ricoh mpc6000 smudge problem
I am printing on letter paper and I get blurred line thru text running from top to bottem of paper any have any idea on what is causing this
Inky
  • 691 Answers
SOURCE: ricoh aficio 1515f printing dark line down left side
If the print can be rubbed off then this suggests the fuser unit is not working correctly. It could be that the thermistor is covered with toner and making the machine think the fuser is hot enough when it's not.
The black line could also be caused by the fuser if one of the pick off fingers is coated with toner or has worn into the Teflon of the roller.
Does the machine show the lines when you print a page from memory - such as a counter or config page? If not, this would suggest the optical path is dirty. Try cleaning the glass and look at the mirrors inside the scanner to see if they are dirty/dusty.
Posted on Feb 18, 2008
  • 82 Answers
SOURCE: black smudgy streak in middle of printed page
if you need any parts for that machine a have 4of them
Thank You,
Mikey
Posted on Apr 06, 2008
SOURCE: ricoh Aficio SP C411DN printouts can be rubbed off of paper or lables
Fuser pressure roller is worn. Fuser is sold as part of the "maintenance kit"
Posted on Apr 17, 2009
smt24
  • 54 Answers
SOURCE: lines in printed copy on Ricoh CL3500N
Depending on the age of the model, it could be a couple of things. ***Never touch the drum or expose it to bright light*** The drum unit is bad. It's the shiny brightly-colored large roller in the center of the machine. On most recent smaller machines like this on it's integrated into the toner cartridge. Check it out. If it has toner build up on the ends, it's bad. or The corona wires need cleaning. Some machines have a small slide that moves from one side of the printer to the other which cleans the hidden corona wires. It's usually brightly colored. The corona wires are also integrated into the toner cartridge in many smaller machines
Posted on Jun 05, 2009
  • 8 Answers
SOURCE: A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
Posted on Mar 31, 2010
It is printing but the lettered is fuzzy
Best practice is to indicate device, brand, and model when querying about printers. Solutions vary by such often.
The blurring could be caused by the type of paper being used. Or, too much paper being in the printer. It can also be caused by substances adhering to the ribbon (where one is part of the setup). Then there is a potential problem with a fuser in a laserjet.
For example:
Printed documents print ghosted blurry grainy doubled or with smudges What...
How to Solve Common Printer Problems
Fuzzy Print HP Laserjet 4240 4250 and 4350 Printers
Aug 28, 2017 | The Office Equipment & Supplies
Why is my printer 7310 all-in-one omitting last line of text when printing
mabe you are printing on the wrong paper size: Your text is set on A4 and you are priting on a letter sized paper.
May 19, 2015 | HP OfficeJet 7310 All-In-One InkJet...
Paper always jams even without starting,,,,specially when im going to print cardstock, it never works
Jams from where? Need more info. Cardstock must be printed from the Bypass Tray ONLY. Make sure you select the proper paper type from the Printer Properties tab in the driver.
Oct 13, 2014 | Ricoh Genuine Aficio Mpc6000, Mpc7500...
Canon Printer - Pixma 5000 Trying to print out pages of text. The text is coming out with a line printing normally - then a block of text / lines missing completely - then tops of line or bottom of line...
pull out the black cartridge then get a tissue paper try pressing the nozzle again the tissue paper but not so hard then release look for the straight line that appear on the tissue paper if it is not change it
Aug 07, 2011 | Canon Office Equipment & Supplies
HP4-smudged copies of printed text are appearing lower on the page...Any ideas on the fix
Run a 1/2 test.
Put paper in the manual feed tray(tray 1).
print something. And watch the paper. As the paper gets
about 1/2 way into the printer, open the top cover, remove the toner.
Look down at the paper. If you don't see smudged text, the fuser is probably bad.
If you see the smudging, replace the toner.
Dec 02, 2010 | HP : HP4 Laserjet Printer
Hp4000n sporadic line of text will have ink missing in single line of text, causing distorted lettering. No pattern to it; random
90% or better chance the problem is in the toner cartridge. I would swap it out with another cartridge and see if the problem goes away. I am sure it will. The only other possibility would be a fusing unit/drive problem but that would only tend to cause blur lines or missing lines that would be on the bottom 1/2 of the page only. It would not affect the top half.
Good Luck and Thank You for using Fixya.
Aug 18, 2010 | HP LaserJet 4000n Printer
Blur about one inch from trail edge 2270
Do you hear any kind of a thump thump noise when the machine is running? These machines flat spot the fuser rollers easily and this will cause a blur line towards the trail edge of the copy. This is because the trail edge of the paper is still having toner applied to it when the paper is going thru the fuser. When the flat spot "lops" over itself it puts a quick yank on the paper and creates the blur. If you are hearing any kind of thumping noise this is the cause and you will need a service person out to replace the pressure roller in the fuser.
Mar 16, 2010 | Canon imageRUNNER 2270 Copier
Fine line running from left to right across page but fades about half across page to nothing, if you print from memory no line, if you run origional thru adf no line, What is causing this line when...
if it is copied on long or legal size of paper are the fine lines on top to bottom or left to right? if it id from top to bottom check for the charge roller, clean an dry it with a cloth, wet with alcohol or water. if from left to right on a legal size of paper check for any vibration coming from the developing unit, like loose gears.
Mar 05, 2010 | Ricoh Aficio 450 Copier
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Ricoh Aficio MP-C6000 Logo
90 people viewed this question
Top Ricoh Computers & Internet Experts
Chris Braid
Level 1 Expert
Are you a Ricoh Computer and Internet Expert? Answer questions, earn points and help others
