Question about Garden
020293 Troy Bilt pressue washer operating instruction
I need the operating instructions for a 02029 Troy Bilt pressure washer
  • 4090 Answers
SOURCE: pressure washer not working
sketchy info here....
Remove the hose and gun to see if water is flowing....
if it is that means there is no blockage in the hose or gun. When its connected if it runs at the same rate as without the hose and you have set it into pressure clean mode, then the pressure valve and seal have collapsed. Estimated repair cost is $200 and about $100 of that is labor. It is not a DIY unless you know your way around and have the right tools. Having it repaired professionally gives you 3 months warranty as well. Do it yourself and you could end up losing some of the small screws and other nylon components that tend to drop out and get lost when you open it up!
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Posted on Sep 13, 2009
Testimonial: "Very quick reply,very informative,very helpful. Thank you."
  • 174 Answers
SOURCE: Soap will not siphon on my Troy Bilt pressure
Are you using the soap on low pressure. This is the only way it will work
Posted on Sep 20, 2009
SOURCE: oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
Posted on Apr 18, 2010
SOURCE: troy-bilt 2200 psi pressure washer
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Posted on Jun 08, 2010
SOURCE: Need to know where oil
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Posted on Sep 26, 2010
I have a troy-bilt model 020296 power washer. what type of replacement spark plug does it take?
Tom, NGK BRP6ES ,Champion RN9YC,Torch F6RTC are replacement sparkplugs for Honda GCV 160 pressure washer engine. This info should be in your pressure washer engine manual. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.bsppwebtools.com/data/manuals/020296_0esAw.pdf
Troy Bilt 020296 Pressure Washer Relacement Parts
Spark plug cross reference
Jul 02, 2016 | Troy-Bilt Garden
Need instructions on the use of the soap dispenser on a 2700 psi B&S power sprayer
Dear Audience,
Please go to the link provided and view the on line PDF manual. On pages 16 and 17 you will find the directive to apply detergent into the system and maintaining successfully.
http://www.ppe-pressure-washer-parts.com/files/1961581/uploaded/020292%20man.pdf .
If you are having any difficulty , please check out this direct source Troy bilt Pressure Washer Support ManualsOnline com .
Fare. Well.
Sep 24, 2014 | Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure...
Power washer wont pump
Call us when you can be at the washer so we can trouble shoot it with you over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
Mar 20, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
How do I change oil in my Troy Bilt Model 020245 pressure washer
if its a vertical engine it;s underneath the base of motor look for a plug with a square slot in it i usually use a 3/8 " extension
Aug 21, 2013 | Troy-Bilt Troy - Bilt 020245 Pressure...
Change oil in Troy Bilt 020245 pressure washer pump
underneath base of motor look for a plug wuth a square slot,i normally use a 3/8" extension with ratchet.
Aug 20, 2013 | Troy-Bilt Troy - Bilt 020245 Pressure...
Troy Bilt power washer 020293- Oil in air filter
that is incorrect. if the oil has been over filled, it will saturate the filter element by way of the crankcase breather tube. it is the small plastic pipe that connects to the bottom of the filter housing. check the oil level. these machines take very little oil. approx 20 oz. if overfilled, it will leak out filter.
May 10, 2009 | Briggs & Stratton Pressure Washer...
Troy bilt pressure washer
You need to replace parts 37 thru 41 on the pump breakdown.
Click this link for the breakdown.
Mar 17, 2009 | Garden
Turn Black cone shaped valve clockwise to increase pressure there will be a small +/- plus will increase and give you pressure.
TK U
Mar 17, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
