My lg wm2240cw has a error code of te found that a connector on bottom was broke the wire came out. And I need a new connector. Can't find manual. To find part #.
2 Suggested Answers
  • 5 Answers
SOURCE: LG Tromm washer WM2688HWM tE error code. Very easy
LG Tromm Washing machine te error. The manual says to call for service. Not much help there. The reason for the error is the thermistor circuit (resistive element that becomes less resistive as it increases in temperature). The thermistor acts as a heat sensor. In many cases, the error occurs because the wireing harness is too tight at the bottom of the drum and one of the wires in this circuit becomes disconnected with all of the movement of the drum (unbalanced load, normal cylcing etc).
1. Unplug the washing machine from the wall. The thermistor circuit is at line voltage (110 in the U.S.) and it will bite! So do this first before proceeding.
2. Move the washer out so you can get access to the back of it.
3. Remove the stainless panel (the one that is not painted, it is large (aprox. 16x18 inches). It is held in place by 4 phillips screws.
4. Locate the thermistor connection block near the bottom of the machine, at the center of the wash drum. It is the small white connector that has two wires running to it. One wire is dark blue, the other is light blue. Insure that neither wire has pulled out of the connector. If either of them have, repair the connector and provide enough extra wire ( aprox. 2") to provide cable relief.
5. If the cable connector and wires are ok, there are other solutions here that recommend either cleaning or replacing the thermistor.
Good luck to you.
Posted on Aug 04, 2009
Need Thermister replacement connector
Cut the wires and wire nut them together. That will work.
Mar 24, 2017 | LG 6322FR2046C Thermistor
I have a Maytag Neptune MAH8700AWW with error code tE, lower case t and upper case E. What causes it. I finally got it in diagnostic mode and it says U133 but wont go any further.
"te" error code is caused by a faulty thermistor; likey cause is:
a. Loose wiring at the control panel (directly behind the cycle selector knob)
b. Broken wire at the thermistor (located at the bottom/front of the tub)
To access the wire plug connectors at the control pannel, remove the top cover of the washer. Stand in front of the washer and look for the plug connectors behind the control panel. Pull apart the plugs and re-install.
Test the washer. If the "te" error still occurs it will be neccesary to remove the front panel as well (two sets of special plier-type tools are needed).
Inspect the thermistor closely, with good lighting. If there's a break in the wire it will be at or near the black sheathing / heat shrink material.
Just like a reference guide, this service manual could helpful: MAH9700AW
Hope this helps.
Oct 07, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune mah8700aww has an error tE, lower case t and upper case E.
Hope this helps.
LG dishwasher LDF modle 7811st error code tE just gives erroe code will not start.
TE error code means Thermistor Fault or Inlet Water Temp too High.
Check the resistance of the thermistor (located on the bottom of the unit in between 2 orange wires with single spade connectors which is the heating element) and it was good 11.7K ohms at 71 degrees room temp. Take the front door off and trace wiring. There is a white plastic wire loom and approx.6" up check the wiring being melted in the black mastic. The thermistor wiring is red and dark blue.
Generally, some lose or broken wires cause this. Keep us updated.
Jun 27, 2011 | LG LDF6810ST Stainless Steel Built-in...
I have an washe - LG Tromm model # WM2277HB - and I am getting the error code te. What part do i need to repair this problem?
'te' on LG's normally means Temperature Error- a heating element problem. Sorry but I suggest you need to call out a service engineer to attend to it ;-0(
Good luck,
John C
Mar 05, 2011 | Washing Machines
Getting a "te" error code -- a heating issue?
I had the tE or te error (an L with a line through it) error on my LG front loader and my local appliance store sold me the thermistor for $7. I layed the unit on its side and accessed the thermistor through the bottom. It plugs into the bottom of the tank. Blue and white wires. No screws and 1 tie-wrap. (Leave the rubber grommet in - just pull the thermistor rod out.) Works like a champ!
Jan 05, 2011 | LG WM2487H Front Load Washer
We think the code te is coming across the screen
Could that be maybe an LE code?
Problem:
An occasional LE error but always a slow or no spin.
Solution:
A Red wire going to the Hall sensor was intermittent. You can test this from the main board connector down to the connector on the hall sensor by checking continuity. There is an intermediate connector down by the motor/hall sensor so you can isolate the problem even more. Problem was in the short wire harness that connects directly to the motor and hall sensor. Could not find the open point of the wire so added a new red wire and integrated it into the harness.
More LG info and your service manual is HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 16, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Malfunction code tE
TE error code stands for thermistor error. You have to remove the front panel and ohm out the heating element. If you have continuity most likely it will be fine. There is a thermistor located next to the heating element that will probably need to be replaced. LG's are the only machine besides GE ref's that I have ever seen thermistors go bad on. There is probably an ohm reading you should get through the thermistor but unless you have an analog meter or a fluke most standard digitals wont read into mega-ohms. Removing the front panel is model specific. But i can tell you the spring around the front boot (drum gasket) needs to be removed and there will be some hidden screws at the bottom by the pump where the access panel is located.
Hope this helps _MJ_
Jan 31, 2010 | LG WM-2277HW Front Load Washer
LG Tromm washer WM2688HWM tE error code. Very easy to remove and replaced the thermistor, BUT still, it's not working, tE error code still there. ????????????
Good luck to you.
Jul 17, 2009 | LG WM2688HWM TROMM SteamWasher
Thermistor for LG WM2688H
Thanks so much for the tip regarding flipping the machine on its side. I was about do the lengthy process of disassembling the front and I tipped the machine over instead. Lo and behold, there was the problem in plain sight right away -- the wire to the thermistor had simply come off the connector! I restripped the tip of the wire and crimped it back on the connector, problem solved. Didn't even need a new part!
Jul 07, 2008 | LG WM2688HWM TROMM SteamWasher
Washing Machines Logo
160 people viewed this question
Top Washing Machines Experts
