Question about Milennia Mr60 AM - FM - USB Stereo 42234 MILMR60
Screen indicates USB error when trying to play mp3 device
Hi. i am tryinmg to charge my nieces mp3 that she has got. she lost the original chatger (lead) so i am using a spare one that i have found.. its coming up on the screen connected but its not showing the...
Hi, why it's not charging yet ,i think its not yet recognizing the mp3 player yet. You will need to follow the below step and solve the problem.,Then after trying out this steps and still does not work,That means you will need to replace the USB cable...
Hi, when an m3player does not detect on your PC, usually when Drivers that corrupted..
How to rectify the problem:
Connect the mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mp3 player Connect and mp3 player Express which only use MTP mode. MTP mode is the recommended and default method for mp3 Players when used with Windows OS.
The mp3 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Good luck......
Mar 12, 2011 | Audio Players & Recorders
My transcend Ipod is not getting detected in the computer
Hi, when an pm3player does not detect on your PC, usually when Drivers that corrupted..
Refresh the drivers
Hope it helped.
Good luck to you.
Feb 25, 2011 | Transcend T-Sonic 840 MP3 Player
Sansa Fuze, 8GB, unable to be turned on in the car after playing it just a short while ago, and is unable to connect to computer; screen is white.
You may need to now reset the player, that may have been a bit much for it. To reset your Sansa Mp3 player. Slide and hold the Power switch up for approximately 20 seconds. Release the Power switch. To turn the player on, slide the Power switch up then release instantly. If that does not get your player working again, try and Format to clear any corrupt files that may be present.
http://www.fixya.com/support/r3962743-sansa_mp3_player_frozen_reset_format
-Also try to refresh the driver in your PC. Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. >>>><<<Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61 Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207 If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit
Mar 20, 2010 | SanDisk Sansa Fuze MP3 Player
My son's mp3 stopped playing yesterday. We plugged it into the computer. There's no response from the player and no indication from the computer. the usb ports on the computer work.
Are you plugging it infront or at the back USB port of the computer? Try turning it off first and then plug at the back usb port. Once plugged in, that would be the time you turn the MP3 player on. If the computer still does not detect the mp3 player as new usb device, then i guess the mp3 player must have been fried due to not being "safely removed" from the usb port. Make sure you are safely removing ALL usb devices when disconnecting them from the computer.
Mar 01, 2010 | Audio Players & Recorders
On my mp3 i had washed it on accident but the battery was dead when i did i tried to plug it into the computer it did nothing; i dried it it finally worked with my computer reading it and all; i instantly...
Try and reset the player. Reset the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Then try this Connect the player to your computer. The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the players screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. <<<<< BUT TRY THIS FIRST >>>>>
Check the Device Manager 1. Right-click My Computer, and select -- > Manage.
Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS.
*** See This Tip Posted here **** --> http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <--
Copy this address into a new window.
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. >>>> BUT TRY THIS <<<<<<< Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Verifying and changing the USB mode of the device to MSC or MTP From the Main Menu, select Settings > USB Mode.
Feb 23, 2010 | SanDisk Sansa E280 MP3 Player
I'm having trouble charging my mp3 it won't stay connected how do i fix that?
Refresh the driver
Solve your MP3 Player Connection Problem.
Refresh the drivers
Feb 22, 2010 | SanDisk Sansa Clip MP3 Player
Clarion DXZ385USB will not play from the usb input
It is not compatible. I had the same receiver and mp3 player. according to the Clarion website, an "ERROR 5" is the message for a compatibility problem. You probably got an "ERROR 2"(format problem) when you had the player plugged in and then cycled through the sources(that's how I received the error).
I have since bought an Ipod and the USB input works just fine. Clarion says the deck is MTP compatible, but it will not run a lot of MTP devices. Only Ipods and certain memory sticks. The Creative Zen Vision M is read as an MTP device when it it plugged into anything like a computer, Xbox 360, and the Clarion USB receivers. The Clarion units even attempt to read it as an MPT device, but will not play. It is not an issue with the receiver or the MP3 files. The Creative Vision M is not a compatible device, sorry.
May 29, 2009 | Clarion DXZ385USB Car CD/ MP3 Player
EMERSON MP3 MUSIC PLAYER, EMP312-1, "FILE SYSTEM" ERROR
ok here we go i dunno how i figured this out lol but it took a while. okay so ur gonna go to control panel, device manager, and uninstall the driver for mp3 player. then disconnect mp3 player and reconnect it to reinstall mp3 player. it will recognize it as emerson mp3. right click on it (im running xp) go to properties, click on the tools tab and click on check now on the error checking and select both options of automatic fix file system errors and scan for and attempt recovery of bad sectors. then hit start and it will start the process of fixing the file error. it takes a couple minutes and when its done disconnect the mp3 player n turn it on and voila!!! it works again. if u need more help u can e-mail me at davidh9732@hotmail.com. hope this helps yall so u dont throw them away
Oct 27, 2008 | Audio Players & Recorders
File error
What's the music format of the songs that you placed on your mp3 player? Some MP3 Players only capable of playing song files with .mp3 extension and are incapable of playing other music format like wav, wma, etc. Check also the contents of the player for corrupted files and foreign files. Some viruses from a computer could affect the performance of your mp3 player.
Jan 02, 2008 | Sony NWZ-B103FBLK MP3 Player
YP-U2JXB & YP-U2JZW Won't sync...Help!
Error C00D1236 virtually always indicates one of two things:
1) The device is trying to sync hidden files--are there any?
2) There is licensed media that is being synced, and the license is either corrupt or has expired. If you have any licensed media, then try going back to where you purchased it (in an iTunes-like music management program? In WMP?) and refresh/renew the license.
The bad news is that until C00D1236 is resolved, you can't sync your device. frown.gif
You can bypass syncing, and directly transfer files, In my computer, the mp3 plaer will be shown as a drive.
Now if one of the two solutions above is not feasible for u, try this:
In case you have a problem to connect your Samsung YP-U2J Mp3 player, you should update Firmware to get it working. The new Firmware may be downloaded from Samsung.com.
CLICK Here to Download : Firmware Update
This error is common with Windows Media Player
Here is the instruction:
  1. Download the YP-U2J Updater
  2. Remove Mp3 player if you already connected to the USB port
  3. Run the program (You should see something like: Please connect the device)
  4. Hold down the Play button and connect the Mp3 Player to USB port (Hold down the play button while you connect the device, you should see a message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message "Initializing" on YP-U2J Updater, you can now remove your hand from play button.
  6. Check the Format Data Area checkbox (By clicking the yes button, you will lose all of your data in your Mp3 player)
  7. Click the "yes" button
  8. Finally, click on the Start button (takes less than a minute). DO NOT REMOVE YOUR DEVICE
  9. IMPORTANT: After updating the firmware, you MUST disconnect the Mp3 player and turn it on. You will see a 20% message for about 50 seconds and it will be restarted automatically.
Update: Please keep in mind that if you sync your Mp3 player with a computer that has a Windows Media Player 9 or 10, you should do these steps again
Nov 22, 2007 | Samsung YP-U2X Digital Media Player
Milennia Mr60 AM - FM - USB Stereo 42234 MILMR60 Logo
22 people viewed this question
Top Milennia Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Milennia Audio Player and Recorder Expert? Answer questions, earn points and help others
