Question about Kenmore 43142 Front Load Washer
Not draining...not filling
I am not sure of the model but the model # is 110.46472501. It started with not draining prior to warranty. The tech came out and advised us to clean the trap as was suggested to someone else, but it worked for 4 - 6 loads and then all lights were flashing again. Second tech ran a diagnostics (1st tech did not) said it was the door lock...new door lock still having a problem so now they are ordering 2 computer panels. I am not too sure if they really know what is wrong and are trying to charge me as they are saying the initial problem was not warrenty related...but the machine is still lighting up with the same code...Add a Garment, Rinse and Clothes Clean. Any suggestions?
  • 183 Answers
Blocked filters are not normally warranty related calls, however a reasonable engineer would turn a blind eye, the control module (pcb) can cause the door not to lock and create the fault that you have, insist done under warranty as on going fault. Regards Advisor
Posted on Aug 30, 2007
SOURCE:
How do I drain the water from internal water tank on cuisinart ss700 ?
First, I'm not a Cuisiart Tech, but I have worked on commercial equip and similar table top machines. Call your vendor or MFR for help. Check your manual for "Storage" or "Shipping" instructions.
*** the following is for information only ***
* At work we had to test all these types of units prior to installing into a customer's location. In most cases it was not a problem to leave the water in the "Internal Tank Boiler" as it won't leak under normal conditions. Removing the water may also cause problems at start up. Air bubbles in lines, etc.
* Once in a while we had to send it via post office which requires liquids to be drained or protected with absorbent padding and placed completely in a water tight bag(s).
* Draining (if not explained by the MFR or in the manual) is tricky and requires the unit to be disassembled (voiding warranty) to get at the inner tank plumbing. Removing the hose at the bottom of the heater tank will allow the water to be drained. Reattach all hoses and leave a note that the machine has no water and needs to be re-initialized like a new unit from the MFR or store. Not following the pre fill instructions will cause an element burn out and ruin your machine.
* I've come across a youtube vid that gets you to the location of the tank (it's connected directly to the pump) but be warned that this is not for the faint of heart and will certainly void the warranty:
https://www.bing.com/videos/search?q=cuisinart+ss700+drain+for+storage&&view=detail&mid=90CE1CEFE40B3CCA842690CE1CEFE40B3CCA8426&&FORM=VRDGAR
Aloha, ukeboy57
Feb 04, 2018 | Cuisinart Coffee Makers & Espresso...
Brand new from day 1 can hear water go in doesn't seem to fill long starts wash cycle not even a minute then stops drains then shuts off
Stever,
Call where you purchased it and have them send out a service tech. Most appliances are under warranty for a year from purchase.
Apr 22, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
Maytag model MVWC200BW0 one year and 12 days old starts to fill and then drains before finished filling.of course Maytag was not helpful since warranty expired 12 days after one year. What could be t
You will need to replace the control board. Here is that part to order. Electronic Control Board
To replace the board you will need to remove the screws on the back of the console to access the control board. It is an easy repair.
Oct 28, 2014 | Maytag Washing Machines
Washing machine won't drain, filled with water
You need to remove the hose prior to filter. Make sure machine is turned off & unplugged, be careful not to splash washer on any electrical components.
Dec 18, 2013 | Kenmore HE2 Plus Front Load Washer
Why won't my GE dishwasher get my dishes clean?
IF all appears to be working just leacing film on dishes or if not actually cleaning dishes there could be several things it could be... the basics to start with are first make sure the entering water temperature to dishwasher is a t least 120-140 degrees ... run water at sink prior to starting dishwasher.. next remove drain line from under sink and check for any obstruction where it connects. check the area under lower spray arm for trash/food build up and if you can remove spray arm and clean port out of any calcium build up... make sure the water is filling unit properly run a cycle and when you start unit listen when it stops filling open door and make sure it has enough water in it.
Jan 27, 2011 | GE Dishwashers
The door will not go to lock,I push the start button it will run for 2seconds,then it will stop and flashes pause,their is a small piece that broke off the bottom of the lock,but the door seems to shut...
these elctronic controls can become problems to troubleshoot sometimes. however the normal operation on this model when you power up is it will drainn first or try to drain any water left in bottom to make sure you have fresh water. then the door will lock prior to it filling with water... i would first try to look at drain pump and hose to drain and make sure no obstruction and that drain pumpp is working properly... if all looks good and your sure drain pump is ok then look at the door lock mechanism as it could have failed... repost with anymore questions ,but willing to bet the drain pump is the culprit...
Jan 09, 2011 | Frigidaire ATF6000ES Front Load Washer
Wash machine is draining while trying to fill up
Make sure your drain hose only goes into the stand pipe about 4" and secure it. If it goes in too deep a siphon will occur. Also make sure your stand pipe is not too short. It needs to be 18" above the trap or 30" above the floor. If it's less, then siphoning can also occur.
May 19, 2009 | Washing Machines
Error code
The unit did not reach it's full fill level after 10 minutes.
Check that water is not siphoning out as quickly as it fills. The drain hose must go up and attach under the counter top or go through a hole in the cabinet at, or near the counter top prior to connecting to the drain under the sink.
Also check that water is coming in at a sufficient level. Check the water shut off under the sink to be in the full open position. The screen in the water valve could be blocked, or the valve itself could be bad. If no water is coming in at all, make sure there is nothing (silverware) under the float. If not, suspect a bad valve.
**Remove power from the appliance prior to attempting any repairs.
May 10, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Maytag HAV2360AWW will not start
Check the back of the lid their is a litel plastic button to make sure the lid is closed see if not broken or stack
or see if drain pomp V belt is out of place or broken
this is the simple way
Dec 19, 2008 | Maytag HAV3460AWW Top Load Washer
Filling up with water
Jimbo, you are going to need a new inlet valve. This is very easy to change out. Remove the 3 torx screws in the back for the top. Slide it off toward the back. The valve will be on the inside top left. Two quick connect harnesses, a couple of hose clamps and your done. I don't have the part number on hand but you can find it on the tech sheet located behind the bottom panel. Three screws to take that off. Or you can go to repairclinic.com, enter your model number and hunt it down from there. Once you change the valve, your leaking problem will be over. Catriver.
Dec 19, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 43142 Front Load Washer Logo
53 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Gordon Richard...
