Question about Hotpoint Washing Machines
Blows fuse Our Ceragem massage bed blows it's fuse intermittently. We replace it and the bed might run for a month or one time or not at all. Replace another fuse and it may run several times then blow again. Any suggestions?
SOURCE: Friedrich Mini-Split blowing fuse
Low voltage shorts can be a real pain to find!!! i would try a process of ellimination: first i would try to elliminate the thermostat. then id look for a wire that is vibrating on something in the cabinet.
Posted on Oct 16, 2007
  • 79 Answers
SOURCE: MAH5500BWW model fuse blown
You probably need the motor conversion kit 12002039. This Neptune motor / motor control board has a high failure rate. To determine this you need to remove the front cover and inspect the motor control board near the floor on right side for burnt components or a blown 10 amp fuse. If you have burnt components or a blown fuse then your motor control board has failed and needs to be replaced. See www.neptunewaxmotor.com for Neptune disassembly pictures and other neptune information.
Posted on Jan 05, 2008
  • 84 Answers
SOURCE: washing machine fuse blows every couple of washes
the machine is pulling to much power.check to see if it is on a 15 or 20 amp outlet. you said you replaced the fuse. the amp size should be on it. if it is a 15 amp fuse,plug the machine into a 20 amp circuit and see if the fuse blows then. it shouldn't since it wasn't blowing everytime on the 15 amp circuit, but never put a 20 amp fuse in a 15 amp socket! the fuse can handle the load[ no pun intended], but the electrical wire would burn not blowing the fuse, thus causing a fire.
hope this helps.
wg
Posted on Feb 18, 2008
SOURCE: Fuse keeps blowing
This is probably a water heater problem  Try operating on the lowest temp  eg.15C If it goes through the cycle then its more than likely your water heater  You will need a refit
Posted on Jun 15, 2008
  • 280 Answers
SOURCE: fuse F3701 is blow-up after few munites turns on
Look at the power board " the one with the fuse" for capacitors that look puffed at the top or leaking at the bottom. If these are leaky the voltage drop will cause the current to rise and pop the fuse. After a time the caps will get bad enough that the set will stop working and may cause more problems.
Posted on Jul 10, 2008
Massage chair will not power up after electrical surge. what could be wrong?
Depending on how much current came down the line will determine how much damage has been done, it could have blown any circuit boards or even the motor, contact your electricity provider, they are liable for any damage.
Aug 10, 2014 | Human Touch STRETCHING HT-270 ROBOTIC...
1994 cadillac eldorado - fuel injector fuse blows out randomly
Short to ground on the circuit intermittently , do you know what a short IS ? Finding active short
Mar 03, 2017 | 1994 Cadillac Eldorado
Cooling fan keeps blowing a fuse on my 2000 maxima #1 fan. #2 fan works when a/c is turned on
It's is very possible. You may be correct however don't dismiss the wiring. The wiring may intermittently short with movement/vibration and cause fuse to blow but most likely you are correct in thinking that your fan needs replacement.
Jul 05, 2012 | 2000 Nissan Maxima
Massage chair fuse on it keeps blowing Model iRest SL-A08-3L
Get its PCB checked for any shorting or ask a technician to brush up the whole pcb with some alcohol and try 5A fuse instead of 4A. You can also look for latest Jade massager bed Carefit 5000 which is more advanced than a massage chair
Jun 04, 2012 | Health & Beauty
I have iRest Massage Chair. Model SL-A08-3L. Keeps blowing the fuse on the chair.
Hi.I do massage chair repairs.
I can assist with the repairs.
pls email me on
regman1@mweb.co.za
Regman
I have a whirlpool central air conditioning and the condenser stoped working. what could I expect it to be?
When you say the 'condenser' stopped running - I'm 'assuming' you are talking about the outside unit, and I'm also 'assuming' that when you say it stopped running you mean 'nothing' runs on the outside unit - fan motor OR compressor. The fan motor will drown out the compressor running noise which is a 'low rumbling' sound - often not heard by the layman because of the noise the fan motor puts out.
Assuming you are talking about the outside unit and 'nothing' is running either fan motor or compressor then you might be 'in luck.' Because the most likely reason for the outside unit to be totally off will be a 'blown fuse' or a 'tripped breaker.' The good news is that in 'hot weather,' especially the kind of hot weather that has been present this summer (especially in the south) - blowing a fuse or tripping a breaker is not necessarily an expensive repair.
Indeed, it's not uncommon for a AC unit to blow a fuse (or trip a breaker) on occasion, although it must be noted that doing so is also is sign on something seriously wrong with your AC, i.e. a fan motor breaking down electrically or even a Compressor, both being expensive items to replace.
But, as I said, it's not uncommon for a fuse to blow once in awhile.
I would check my fuses (and breaker) and see if this is what has happened.
If you have fuses (usually located outside close to the condenser) and have no way to check them (you check them with a ohm meter looking for continuity) - then just 'replace' them with new ones. Note: always put 'time delay/dual element' fuses back in - even if the ones that are in there now are 'one time' fuses. 'Time delay' fuses do just what they say they will do - (they hold for just a second or two during that initial start up (of the compressor) without blowing).
If a blown fuse/tripped breaker is your problem then "most" of the time the AC will run ok and you will not have any more problems.
However, if after replacing the fuses and turning the AC back on - the fuse(s) blows instantly, or a short period thereafter (say a few minutes or an hour) then you probably have a problem that is causing it - i.e. the fan motor or compressor is going bad.
Note: one thing that you can fix that might be causing the fuse to blow is a dirty condenser. So, check the condenser coil (think of it like a car's radiator). It 'must' be clean to run properly and when it gets 'really dirty and clogged with dirt it will cause high head pressure and can cause the unit to blow fuses and trip breakers.
Good Luck!
Aug 10, 2011 | Whirlpool Heating & Cooling
Ignition fuse keeps blowing, sometimes I drive 130 miles till it blows n sometimes 1/4 mile and sometimes as soon az I replace it it blows orther times I put a new fuse in and the fuel pump runs and when I...
I'd replace the fuel gauge sensor as a first thought, however, before doing that, I'd meter the sensor the times that it blows immediately.
You may want to check and see if it blows at a specific fuel level.
Trace the wiring to the fuel guage itself and make sure the wire isn't intermittantly shorting somewhere like where it runs through the headlight (if it does) and where it goes into the fuel gauge (or low fuel light).
You seem to have tracked the problem to the root area and just need to isolate it to the specific area.
Jun 28, 2011 | Harley Davidson FLHRS - FLHRSI Road King...
Display saying test and won't wash
Simple low cost alternative to ceragem compact cgm p390 & ceragem master thermal massager beds. All the Carefit devices are very easy to use at Home for natural & preventive healthcare and create miraculous health benefits.
Oct 13, 2010 | Hotpoint Ultima WF860 Front Load Washer
Interactive health chair model EMS-9, blowing fuses constantly
You should check the size of the fuse . It may be to low a watt. try a stronger fuse.
Apr 29, 2009 | Interactive Health Ht 135 Massage Chair
Fuse blowing
Your exhaust vent is blocked.
Timed dry is High heat.
Permanent press is a medium heat and intermittent.
The dryer does not get as hot as often in Permanent press mode. Therefore the fuse does not reach critacal and blow.
Remove the vent at the rear of the dryer and run a timed load.
If it dries correctly, repair your vent blockage.
If not, repost and I will lead you to the next step.
Feb 19, 2009 | Kenmore Dryers
Washing Machines Logo
132 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
