Question about Hardware & Accessories
How to set boiler timer for Vokera Compact Combi Boiler
How to set up manual time set up for the boiler and how does auto timer works in terms of its frequency
SOURCE: baxi boiler timer
1)Push all the little pins (bits) inward toward the centre of the dial
2)Set timer to correct time by
turning dial to current time, ie if present time is 4.00 p.m.
Turn the dial until 4.00 p.m is aligned with the arrow symbol
3)PULL OUT all the ( bits) toward the outer edge of the dial to set the time that you want the heating to come on .eg pull out all pins between 6.00am and 9.00am(as each pin represents 15 minutesyou should have 12 pins pushed out)
4) Ensure the3 way switch in the middle of dial is in the middle position(timer) if it is at top position boiler is(constant on)and at bottom positon boiler is turned off.
Posted on Feb 06, 2009
SOURCE: vokera combi boiler
air in system
Posted on Aug 11, 2008
SOURCE: I have a vokera options
E-mail the co.! Thank-you-very much!
Posted on Aug 27, 2008
  • 17 Answers
SOURCE: Vokera Linea 28 combi boiler
sounds like you have an earth leak or defective pump winding
Posted on Nov 27, 2008
  • 30 Answers
SOURCE: vaillant 831 combi boiler timer help
check to see the time clock is set with the clock symbol. there are three settings on analog clocks I , O and clock the I setting is constant running, the O setting is off and the clock setting is timer.
also try setting the thermostat up higher to see if the boiler fires.
Posted on Mar 30, 2009
Yardworks timer 59-3213-8 not functioning properly
Yardworks is a non-supported brand name that re-packages timers from different manufacturers including Orbit, Melnor, Tork etc.
Copy following link to access sprinkler timer manuals, to help identify product.
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Most Yardwork timers are sprinkler, but I have also seen auto-off christmas light timers.
Add a comment and describe timer in detail. Otherwise the only google result for that timer model is fixya, which indicates there are no online resources.
Also check battery ... if timer has battery, it will last about 3 years.
Also do not expose water timers to freezing temperatures.
Most timers last a couple years, and most have 1 year limited warranty against defects in workmanship. Unknown who supplies warranty coverage for Yardworks.
May 03, 2013 | Hardware & Accessories
I am wanting to wire a Baxi 105E boiler to a Danfoss 102 mechanical timer. The boiler has 5 wires = red, blue, earth, black and yellow. The Timer has six terminals = 1 DHW, 2 HTG, 3 COM, I (earth), 5...
1) Contact baxi:
http://www.baxi.co.uk/contact.htm
2) Which boiler wires? I don't know. Page 24 manual.
Manual says to disconnect link between terminals 1 and 2, and instert timer in-line.
http://www.acwilgar.co.uk/Boiler-Manual-PDF/Baxi/Combi%20instant%2080E%20&%20105E.pdf
2) I can tell you about the timer wiring.
Timer is 230Volts
Not sure if you have British Hot-Neutral 230Volt, or Hot-Hot 230Volt.
Wiring is same 2 wires, but words to describe are different.
Let's say you have Hot-Neutral 230V
Connect Hot to L6
Connect Neutral to N5
This will power the timer so it runs and keeps time.
You can get Hot-Neutral wires from Hot-Neutral that arrive to power the boiler.
Now the timer terminals are separate.
E terminal is Earth or ground.
The Common is Hot wire.
The timer then turns on-off and switches back and forth between DHW and HTG.
HTG is heating
DHW is defrost.
Timer has 2 sets contacts.
When timer activates first set of contacts, then DHW defrost terminal receives power from Hot wire on Com terminal. At this time, all power is cut to HTG heating terminal.
When the defrost cycle ends, then the heating circuit receives power, and then the timer has programming that opens and closes a second set of contacts going to HTG heating terminal.
Which wires from boiler connect to each terminal, I am not sure.
Feb 03, 2013 | Hardware & Accessories
Hi, please help! I have just moved in to a new flat and there is an Ecosave timer linked up but I know for a fact I'm not on Economy 7 Does this mean that the timer is simply controlling whether
Manual says 'tappets are pre-set to off-peak.
However if you want different time, move tappets outward.'
http://waterheatertimer.org/pdf/Ecosave-Product-manual.pdf
Timer dial is ordinary 24-hour analog.
You can remove glass cover, and manually rotate the dial around and observe what happens to get best idea how you want to set timer.
http://waterheatertimer.org/How-to-set-timers.html
Set current time by manually rotating dial until current time lines up with winter or summer time arrowhead
Nov 04, 2012 | Hardware & Accessories
Hi, I am having problems with the timer that controls my boiler. It is a 'Lifestyle LP522'. The hot water is set to come on in the morning for 4 hours and again at 4pm for 3 hours. The heating is...
then there must be a problem with the programmer as the boiler thermostat will call for heat only if the programme is on try setting the water side to 24 hrs it won't cost any more to run , but will prove if programmer is working .
Mar 07, 2017 | Heating & Cooling
I need to know more about "Countdown - Auto -
Open following link to identify timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
59377 manual
http://waterheatertimer.org/pdf/Woods-59377.pdf
Auto: timer must be set in AUTO for programming to work
The word AUTO is printed on timer face.
Small black triangle will display above the word AUTO when timer is in AUTO
Countdown is feature that lets you set timer ON for set amount of time, and when time expires, timer turns OFF.
Manual button.
I have not tested this specific timer.
Simply plug lamp into timer, and then push manual button to explore feature.
Watch what symbols display, and watch what lamp does.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 08, 2011 | Woods Industries 59377 Indoor Digital...
I have a EC4000 electronic digital timer. The problem is when the timer hits a preset time to turn the boiler on , the boiler will not turn on, but when I hit the manual override button on the timer the...
Paragon EC4000series are programmable timers
EC4000/120 for 120V
EC4000/277 for 208-277V
Is this a new installation?
Or was timer working fine until recently?
1) With digital programmable timers like EC4000, if there is conflict in programming, or missed program, then timer might skip the program.
For example if program1 says ON at 7 and OFF at 8, and program2 says the opposite.
2) If wiring is reversed, then the manual override will work but clock will not operate, and the timer will not function.
a) for 120V timer:
-120V black wire from breaker goes to terminal2
-120V white wire from breaker to terminal1
-jumper wire from terminal2 to terminal3
-Load black wire to terminal4
-Load white wire to terminal1
b) for 240V timer
-240V Hots from breaker go to terminal1 and 2
-Load wires connect to terminal4 and terminal1
Below is link to EC4000 instruction manual
http://waterheatertimer.org/pdf/Paragon-EC4000-program.pdf
Troubleshooting steps say to review set-points.
Solutions:
Checking wiring as described above
Check programming.
Reset timer and re-program set times.
If you need more help, add a comment at bottom
Oct 26, 2010 | Paragon 4001-00 24-hr Timer Control 120v...
Vaillant 831 combi boiler timer help
Mar 25, 2009 | Water Heaters
Hardware & Accessories Logo
1,598 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
