Question about Watches
Airflow DB1 digital barometer - Watches
How to fix the error concerning barometer
1 atm = 29.92 in Hg (inches of mercury)
1 atm = 760 mm Hg (millimeters of mercury)
1 atm = 1013.20 millibars
1 atm = 14.7 psi (pounds force per square inch)
1 atm = 1013.20 hPa (hectopascals) ...
Unit Number Required Data Entry Elevation Of Barometer ASL Meters Feet Observed Barometer Reading Inches Hg Millibars
Nov 04, 2016 | The Watches
I have a Suunto X-Lander and i dont get along with the barometer/altimeter. The barometer always shows about 2 mbar below the nearby airport homepage. Can i by myself calibrate the sensor? This even...
Erik, the altimeter uses barometric pressure to determine changes in elevation. Rule one is whenever you know the elevation for a fact, adjust it as the barometer is changing often and therefore affecting the altimeter reading. The only sure way to avoid this is use GPS. Altitude is derived from locating 3 or 4 satellites in a geo syncrohnus(SP?) orbit. Pilots always reset the altimeter before take off and you should too. Find elevations on road signs, maps, etc.
May 24, 2011 | Watches
I need an instruction manual for a Casio Pathfinder watch. I show PAW-1400T-79VCR on the box as the number. Can u help me find one? It has a solar battery, digital compass, altimeter/barometer and...
you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Aug 13, 2010 | Bulova Watch
Hello, I don't understand how to calibrate the altimeter
May I get the make and model # of the watch to help you more
Jan 22, 2010 | Timex Adventure Tech Altimeter Barometer...
Buttons on casio pro trek watch stopped working -time still shows
Sounds like the solar back up cell needs to be replaced. You can get it repaired for rather cheap less that $30(US). You can contact www.casiosalesandservice.com to have it serviced. 877.659.0761
Jun 25, 2009 | Casio Protrek Triple Sensor Tough Solar...
Barometer ERR message on Casion 2271
here is the link for very complete manual:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2271.pdf
Download it and follow the instructions how to set and reset the altimeter and other features of your watch. Use zoom or magnifying tool, as the document originaly has tiny script.
Do not forget to rate please.
Feb 09, 2009 | Casio PRG-40T-7 Pathfinder
Casio protrek watch altimeater and barometer only showing ----- lines temp and clock are fine I have comparable problems With me it is even stranger. My barometer works still more or less, as long as I...
The best would be to start with the battery check (must be full power) and full resetting of the watch.
Here is the link to user manual download page:
world.casio.com/wat/download/en/manual/ - 23k - Cached - Similar pages
If all this do not help- find your nearest watchmaker and ask for help.
Dec 21, 2008 | Casio Protrek Triple Sensor Tough Solar...
Casio Protrek PRG-70-YT
wait until the battery is full reloaded
Jul 08, 2008 | Casio PRG-40T-7 Pathfinder
Adjusting meteo function
Yes, Sir. But remember when pilots reset their altimeter with the local altitude, the pressure value matches the moment wheather pressure. It will be wrong anyway, if you reset you altitude, but the pressure readings are still wrong. Im my case it is happening. The altutide is correct but the pressure of the watch does not match the local pressure. It is 20 hpa over it. By the way, I am an airline pilot.
Mar 05, 2008 | Tissot T-Touch T33759851
Watches Logo
43 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
