Question about Coffee Makers & Espresso Machines
Rubber gasket HI. I've a Delonghi EC 130, the similar as Silvercrest CP-A450, and the Rubber seal is broken. Where can i buy one? I'm from Portugal, by the way... Best regards Emidio Serra emidioserra@gmail.com
jsrock516
  • 5911 Answers
SOURCE: chenging the rubber gasket attached to kenmore H2e front load washer
The following link provides you with step-by-step instructions on how to change the door bellow:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
This is not a difficult repair. Just follow the steps provided. If you have any questions, please let me know. I hope you find this information helpful.
Posted on Sep 02, 2008
SOURCE: Leaking rubber seals
Ryan,
I had the same problem on my wife's 2000SLK, took it to the dealer, they did a water pressure test in this area, charging me $80.00 and came up with nothing. Upon my further investigation, I discovered that there is a drain built into the rubber seal at the top of the windshield, in the corner where the top of the door glass meets that rubber seal on the driver's side. look carefully and you will see three small holes in the rubber seal at the top of the windshield and a larger triangular shaped depression in the corner, this is a "catch-basin" drain that runs all the way down the side of the rubber gasket along the end of the "A" pillar emptying in the space in front of the door, then onto the ground. First I cleaned out the triangular catch basin carefully with a small flat bladed screw driver, then used compressed air to blow out the drain. Blow out the three small holes also. This procedure worked for me. Do the same on the passenger side. Good Luck!
Bernie
Posted on Dec 23, 2008
motor1258
  • 6674 Answers
SOURCE: Sunroof rubber seal
I'd stop at an auto glass place & ask them.
Posted on Jan 30, 2009
SOURCE: Delonghi EC 155 general help
You don't have to wait 15 mins. just a few minutes, then run some hot water to warm up the portafilter and dry it up, fill it up with coffee and when you get the gree light again, make your espresso . You will have to have a good fine coffee and make sure to pack the coffee really good and don't leave any around the edges , so could make a good seal. If you have steam coming out of the machine , is maybe to hot and is ready to brew . Cool down the machine after use, run water through it and let the steam out of the nozzle.
Posted on Feb 06, 2009
  • 134 Answers
SOURCE: I need a replacement rubber gasket for Six cup Cafetera Isabella
HI
You need to contact the manufacturer here
http://www.valira.com/eng/index.html
Posted on Feb 19, 2009
Keurig leaking from bottom
Check the Upper Rubber Gasket (fits around the top puncture pin). If it missing you will have leakage because here's no seal to protect leakage. You can buy it online or call Keurig Customer Service (if you still have warranty)
OR:
Upper Rubber Gasket not making a seal with the K-Cup or Reusable Filter and the water and/or coffee grounds leak out. To fix it simply move Upper Rubber Gasket 1/4" down. This should close the gap between K-Cup and upper needle.
Oct 07, 2013 | Coffee Makers & Espresso Machines
Rav4 sunroof leaks because of worn rubber seal and not because of clogged drain hole
most upholsterers should be able to help here If not go to a rubber dealer that sells sponge rubber etc as most have a good selection of auty trim rubbers that you can fit yourself. The best glue is loctite 406 Be careful as it is a super glue
Jan 10, 2013 | Toyota RAV4 Cars & Trucks
Rear Door seal water leak
If silicon is working,I would go with it,silicone last a long time and it's working.
Dec 25, 2012 | 2001 Toyota Sienna
I have coleman air conditioning units on my 1991 Georgie Boy. They both leak... water from rain and also when units are shut off, lots of water comes back in. I bought gaskets but it looks like someone...
I'm thinking that motorhome has a rubber roof, so you don't want to cut at roof, or you'll likely end up cutting rubber roof which is certainly not a good idea. It may take some work but try prying and scraping with a plastic scraper while someone lifts up ******* upper unit. Quite often whatever sealant they've used to seal between roof and gasket will start to let go with constant upward pressure.(lifting) If you have fiberglass type roof and not rubber, scrape and pry where gasket meets roof.
Oct 05, 2011 | Dometic Rooftop RV Air Conditioner
I'm trying to change oil pan. I've removed all visible bolts but it is stuck. Anything I might have overlooked?
If all the bolts are really removed, then try whacking it with a rubber mallet.....not too hard.
Hope this helps
Good Luck
Aug 07, 2011 | Daewoo Nubira Cars & Trucks
The door on the oven of our Delonghi Professional cooker isn't shutting properly.
have just fixed similar problem where door was not shutting properly by moving the rubber seals that are fixed on the oven so the ends are just tucked inside the oven cavity at the bottom, not swinging freely.
Hope this helps
Aug 25, 2008 | DeLonghi Kitchen Ranges
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
