Question about Razer Video Game Consoles & Games
Usb power surge
USB port got knocked while Naga was plugged in, claimed there was a power surge and now neither the port nor the mouse works - not sure what to do.
JMuskovitz
  • 135 Answers
SOURCE: USB cord on the controll is becoming extremely hot....
It sounds like there is an electrical short in the game pad's cable. If it is under warranty, you should contact Logitech. If not, it is unlikely that you will be able to fix this. It clearly sounds unsafe to continue to use it.
Posted on Apr 16, 2007
babb
  • 104 Answers
SOURCE: Power surge on hub port error msg
The printer is the problem, obviously but, also try using a different USB cable to see if that doesn't help! When plugging up th cable, look for anything out of the ordinary! If changing the USB cable doesn't resolve the situation then it could be something shorted out in your printer and you need to take it to a service shop for repair! regards, babb
Posted on May 15, 2007
Syd_
  • 47 Answers
SOURCE: power sugre with m240
Hi there. This message would indicate any one of the following: 1. You have a lot of USB devices plugged in to your computer, and the maximum power supply for the USB ports has been exceeded by plugging this player to your computer. It would be best if you unplugged 1 or 2 of the USB devices connected for the time being. 2. You are plugging the player on your front USB port, and may need to plug it in the rear USB port to acquire ample power supply (front USB ports do not get as much power as the rear USB port -- sad but true) 3. You are using a laptop and may need to try another USB port on that computer. Purchasing a self-powered USB hub would be ideal as it gets its power supply directly from the wall electrical socket.
Posted on May 16, 2007
  • 1019 Answers
SOURCE: power surge on usb port
unless your a very competant motherboard components repairer.
this is beyond repair. i,d suggest taking it to a repair centre, where they will replace the motherboard. and unfortunately a large invoice to go with it. probably more cost effective to look at a replacement laptop.
Mike @ Compurepair.
Posted on Jul 31, 2008
SOURCE: keyboard, mouse and usb ports don't work.
I just had mine fixed by http://www.laptoprescuer.com/ Unfortunately, this is a motherboard problem but they were a little cheaper than the others since they were able to fix the I/O controller (which is the culprit) and not replace the whole motherboard. So with shipping back and forth it still cost me around $250. :( ...but... they did a great job and I'm and running!
Posted on Nov 17, 2008
Gaming mouse cannot detect
try to plug into every usb slot... see if your mouse can still work or not... but i recommend you to bring that mouse and claim for it warranty....
ps; if you plug your mouse into the PS/2 port, u need to restart your pc. i hope this will help you.
Jun 13, 2012 | Computers & Internet
My computer suddenly started signaling that a power surge problem, a usb hub has exceeded the power limits. i was told to uninstal the usb ports and install again. i did and starts to work when i plug in a...
If you are using a usb hub it could be the problem; try disconnecting the hub. Try to plug the pen drive into a usb port on the pc not on a hub. If the usb hub has a separate power supply make sure it is working. Hope I was of some help, Thanks for using FixYa
May 11, 2011 | Computers & Internet
My HP mouse is plugged in and the red light is on but I do not see the arrow on the screen. What is wrong?
Hmmm... if you are using a different mouse on the same pc and it works odds are your HP mouse is fried. Just out of curiousity and to confirm that the USB port that the HP mouse was connected to is not damaged, insert the Logitech wireless USB receiver into the HP's port and see if it still works.
If it does I suggest replacing the HP mouse. There are a number of factors that could've killed the mouse from USB power surge to rough handling, etc.
BD
Sep 02, 2010 | HP (A2839B) Mouse
My mouse does not work. I originally could not turn the pc on for approximately 1 week. I took it in for repair , they could not find the problem. When I returned home and repluged all the wires the...
Are you using an USB mouse? If so you may like to try another USB port or there might be some wire to the USB port not plugged right. You can check the printing on the motherboard to see how it should be plugged. (There is several wires for each USB port with a certain order into an plug on the motherboard when the USB port is not on the motherboard). You can check the power and make sure it is connected well and enough for everything. Other options will be to use other mouse like wireless mouse or PS/2 to USB converter to make a PS/2 mouse an USB mouse or vice versa. Checking motherboard and measuring every voltage could be very complicated.
Jul 24, 2010 | HP Pavilion dv1600 Keyboard - 412374-001
I replaced my hard drive in my hp pavilion desktop a1520n windows loads and then reads that i will have to register my copy of windows But my keyboard and usb ports dont have power so i cant do a...
A lot depends on where the keyboard and mouse are plugged in. I have seen in the past that the USB in the back works better than the front. Are these the original keyboard and mouse? If not, use the original until after Windows loads the desktop.
Mar 21, 2010 | HP P2360AA Keyboard/Mouse
Hp nx6110 laptop error power surge on hub port
OK if you have anything plugged into the USB Ports at bootup, unless Keyboard or Mouse, remove everything, and see if it boots normally, if it does, then the "Hub" you are using may be faulty, or a device you are using is drawing a lot of current at switch on and overloading the USB bus, that can only supply 500mA. If it still does it, and you do use a USB KB & Mouse, then remove them one at a time & reboot, between, and see if it was one of them causing the problem. If you have nothing attached then your internal USB bus is flaky.
Feb 16, 2010 | HP Compaq nc6120 Notebook
Ps2 port doesn't recognize Microsoft Optical mouse
You might think about a USB hub for all your USB devices. ps2 port is more or less dedicated for mouse, which is why your mouse pointer is stuck in the middle of the screen. Go ahead and get an externally powered USB Hub to power other USB devices. To answer, ps2 for mouse needs just a mouse, not USB device.
Sep 28, 2009 | Microsoft Windows XP Professional
When i plug my usb mouse or the webcam on my new motherboard my PC does not open,.while the ps2 mouse it works,.moments ago i restart the PC and it has a message POWER SURGE ON HUB PORT!!.HOW can i solve...
you are connecting your mous mous or web cam through a usb hub which is not having power to run the device instead you should attach a device directly to the system or use a hi speed usb 2.0 hub
Sep 16, 2009 | XFX GeForce 6200 Graphic Card
Anytime I plug something in to the USB port it give a error message that states, Power Surge on the USB port. What can I do to fix this?
The USB device could be drawing more current than the USB port can supply or the USB port may be faulty.
Get a powered USB hub and plug it into your computer's USB port and then plug the USB devices into the powered USB hub.
Aug 16, 2009 | Dell Dimension 3000 PC Desktop
Mouse and keyboard not working / recognized by computer
If its an USB keyboard and mouse, try to insert keyboard in upper port and mouse in lower port USB.
Sometimes when they Both are inserted in port in same line, they are unable to Fetch equal amount of power.
Try this and do restart your computer, after inserting them in USB ports.All the Best
Jul 02, 2008 | E-Machines T3624 PC Desktop
Video Game Consoles & Games Logo
48 people viewed this question
Top Razer Video Game Consoles & Games Experts
James Wishart
Are you a Razer Video Game Console and Game Expert? Answer questions, earn points and help others
