Question about Refrigerators
Amana bx21v1 not producing ice
3 Suggested Answers
muffteck
  • 202 Answers
SOURCE: Amana Refrigerator ARS9167AB Ice Crush does not produce ice at all.
either the switch is bad that moves the selection from crushed to whole ice or the ice crushing motor is out
Posted on Sep 16, 2010
  • 5370 Answers
SOURCE: amana BX21v1 Refrigerator bottom freezer is not working
The problem can be temperature not set properly or any of fridge or freezer door not closed properly and cool air is getting leaked out. These are basic possibilities which first need to be checked. But if these possibilities are checked ok and still the problem is same, then its weak compressor issue. Click the link below for more details:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
This will help. Thanks.Helpmech.
Posted on Nov 01, 2011
Amana model tg21vl stops making ice
pull on icemaker fingers to force icemaker , check for ice in tube to icemaker and listen for the valve to open , if all checks ok replace icemaker
Feb 24, 2013 | Refrigerators
Amana BX21v1 Refrigerator bottom freezer is not working
Nov 01, 2011 | Refrigerators
I just emptied all the ice out of my ice bin to take on a picnic, but now my ice maker won't make more ice. I have had it for 5 years with no problems. What happened? Did some setting get bumped? or...
1. Check to make sure the when you removed the ice bin that you did not leave the lever by the ice tray in the up position. That is the one the stops the making of ice whe the bin is full. This is the only easy solution.
2. Check to make sure that the vent between the freezer side and produce bin is closed. This is used when opened to keep that bin colder than the rest of the fridge. If that isn't it then there a few easy solutions.
Jul 02, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker did not produce ice, then it started to
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Aug 24, 2010 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
HI, our Amana ice maker produces only a shell of an ice cube sometimes. It happens during half of a harvest is emptied. We turn the ice off and let it sit for a few hours and then some harvests are...
you are having a problem with not enough water getting into the ice maker.
we call this getting "hollow cubes"
you have to clear or replace the valve that connects to your house water line. most are whats known as a "piercing type" valve. they get plugged or break into the water line of your house.
you can try to shut off the valve and then turn back on and see if you get full size cubes after that.
most likely you will have to replace the valve with a "drill type" of valve from your local hardware store.
this is very common and the new valve will fix your problem.
Jan 08, 2010 | Amana ATB1832AR Top Freezer Refrigerator
The ice dispensor is frosting over. Ice maker
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Jul 14, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana makes ice but not very much and we run out very quck.
unfortunatly your ice maker will only produce a limited amount of ice. Nothing you can do.
Jun 27, 2009 | Refrigerators
Ice Maker
well ur refrigretor is;nt producing enough gas to produce ice make sure u hire some expert who can examin and solve it.
Mar 18, 2009 | Amana ARSE66MB Side by Side Refrigerator
Oct 28, 2008 | Amana Refrigerators
Refrigerators Logo
11 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
