Question about Dryers
Where is the drain pump of my combination washer/electric dryer
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Bay, thank you for your question! Generally speaking, the drain pump is typically located on the front right hand side of the washing machine, behind the front panel. I hope this information helps to some degree.
Posted on Jul 25, 2013
    Problem Solver:
  • 18 Answers
Need more. info like model number.
Washer does not drain
check pump for a blockage.....
cheers
Feb 19, 2015 | Whirlpool LTE5243DQ Combination...
Kenmore washer no spin
Does the washer drain the water quickly?? Are there any error codes?? Usually the drain pump sump is clogged and not draining, thereby not letting the unit advance to spin.
Nov 23, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore twin washer do not drain yes
Does the pump engage and if so there might be something stuck in the hose before the pump
Mar 10, 2014 | Whirlpool LTE5243DQ 24" Compact Thin Twin...
Washer won't drain water
Open then front panel and see if you need to order a water pump mine has a A nail on water pump repair clince.com hope that work or go to youtube type washer don't spin
Nov 07, 2013 | Kenmore Elite HE4 Electric Dryer
Water wont drain out
Easy fix, probably a sock in the pump or such.
TWIN TWIN SERVICE MANUAL
Dec 22, 2012 | Whirlpool LTE5243DQ Combination...
My washer dryer ventless combo spins but wont drain all the water or dry. the lint trap is empty and the dryer is working but the water is not fully draining the last amount out of the machine
Washer will not drain:
Thedrain water pumpis the main part in your washing machine that pumps out the water. If this is defective or has failed in any way, this will be the reason why your washer will not drain the water. Before you order a new drain pump, make sure tocheck the pump to be sure a small object like clothing or similar has not lodged itself insideof it causing the NO DRAIN issue and even a no spin issue?. If the drain pump is not clogged, you can test it with a multimeter and remove and replace if needed. Go to Google or YouTube and search for "Replace Washing Machine Drain Pump" then type your brand and model number of washer to show you details on replacement.
Read more:http://removeandreplace.com/2014/10/30/fix-washing-machine-that-wont-drain-washer-not-draining-water/#ixzz3X2LbXMWJ
The washing machinedrain hoseis where the water flows through to get the water out.If this drain hose is blocked, kinked, bent, or clogged, the washer will NOT be able to remove the waterfrom the tub. Check the drain hose to be sure it allows the water to flow freely. You can take the drain hose off and run water through it in your sink to be sure it is not blocked. If there is water STILL in the washer when you remove the drain hose, grab a bucket as the water will exit from where you disconnected it
Thewater pump belt(to drain out the water) may have broke or become frayed or loose.If this belt breaks then it is unable to drain and remove the water from your washer. Inspect the belt to see if this is causing theNO DRAINissue and remove and replace if needed.
If thelid switchis not working as required it will cause your washer to not drain (and many other problems).This may be unlikely as a bad lid switch will usually cause your washer to alsonot agitate or spin.However on some models this can vary. The best thing to do if you have a suspected bad lid switch is to test it. It can fail electrically and or mechanically. If mechanical failure is the issue, you should be able to see if it is cracked, broken, or not in place to make contact with the lid. To test it electrically, use a multimeter set on Ohms and test it for continuityMy advice is free cuz God is good!
Fix Washing Machine That Won Drain Washer Not Draining Water
Mar 15, 2011 | Equator EZ 3710 CEE / W Ventless...
The washer will not spin.
first check the lid safety switch,then check the drain hoses from tub to pump to house drain for an obstruction,if it senses an obstruction the pump wont start and drain tub
Mar 19, 2010 | Washing Machines
Water doesn't drain after the cycle and the dryer does not kick on
hi. in that washer they use an electric pump, to drain the water. so sitting all this time , its seized up. remove the front panel . dismantle the pump. and clean. and oil a little bit. thanks the appliance doc
Oct 16, 2008 | Hotpoint NBXR463EBWW Electric Dryer
Kenmore top load washer won't drain
Could be the pump itself or the belt driving it... many of the older type washers run the pump off of a drive belt and many of these pumps get clogged with material so that they do not pump... usually, you can unbolt the pump and seperate the pump casing to access the impellor and clean out the insides.. As always.. be certain to unplug the washer first..
Hope this helps
Sep 21, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
29 people viewed this question
Top Dryers Experts
