Question about Panasonic DVD-RP56 DVD Player
Dvd player is playing a vertical split screen
My Panasonic dvd player is showing a vertical split screen on my TV. I have an Onkyo TX-SR605. I swapped out the Panasonic dvd player for a sony dvd player and am getting the same vertical split screen. I had this happen before, just can't remember how I fixed it.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
If the TV does the same with two different DVD players, it must be a menu setting on the TV. Look through the TV menu options.
Posted on Oct 27, 2013
SOURCE: error code on Panasonic LS50 portable DVD player
I purchased my LS50 over 16 months ago. I had a H03 error before and it went away after sitting on the shelf for three days. It worked ok for another couple of months and then stopped again. The screen says reading but the motor is not spinning. i pointed out that the laser lens is in the wrong place. When at resting location, the lens should be parked near to the spindle in the middle. The mechanism to move the lens backward and forward sometime get stuck at the end of its travel - furthest away from the spindle. If your player is out of warranty, then you maybe able to try this. Open up the bottom cover by taking out the screws - 10 or so. This will reveal the lens and motor module. Flip over the model and you should see the gear and shaft for the lens. Move the gear so that the lens move towards the centre. Click the covers back into place , reconnect the battery and try. If it works, put all the screws back. Mine was fixed this way but this is not a gaurantee that this will work on yours. Good luck.
Forgot to mention. You can also clean the gear shaft in case there are small particules stuck to the grease and affect the movement. After cleaning, apply a tiny bit of grease just to lubricate the moving shaft. Not too much. I am glad that the instructions help.
Posted on Dec 12, 2007
t0pc4t
  • 132 Answers
SOURCE: PANASONIC SA-HT800V
Ouch - This generally one of two things.
1 - Run up speed is not sufficient due to motor wear.
2 - The laser head sits within a 'plastic' runner, which wear down slowly, causing the laser to be misaligned - therefore not reading adequately.
Depending how adventurous you are feeling - you could dismantle the unit - and 'space off' the laser unit (Single piece of paper) this will lift up the laser.
Or you may be able to adjust the calibration power of the laser using a variable pot (unlikely to be available as these are generally hard coded nowadays - and not physical pots)
Posted on Aug 15, 2008
preachw996
  • 1179 Answers
SOURCE: dvd player split screen
I had the same problem. It turned out to be my cable that went from the dvd player to the TV. I replaced with new cable & everything worked fine again. Hope this helps & please remember to rate my answer. Thanks.
Posted on Feb 06, 2009
welcomejee
  • 10594 Answers
SOURCE: VHS to DVD-R dubbs fine: but won't play on SONY DVD player.
Please finalize burned DVD to play in another dvd player.
Posted on Apr 16, 2009
SOURCE: Panasonic DVD-RV31 DVD Player plays black & white only (no color)
Hi,make sure your tv channel says av2 and not av2s as this will play in b/w,hope this helps
Posted on Jul 11, 2009
I have a Onkyo SR605. When I play a video via the DVD the screen splits and is very unstable. I have swapped DVD's so I am relatively certain that the problem is in the receiver.
I would try a new HDMI cable that has the gold plated ends for higher resolutions. Some of the older non-plated HDMI cables seem to have difficulty with higher res DVD's. This is applicable especially to Blu-rays vs plain DVD's.
Sep 29, 2013 | Onkyo TX-SR605 Receiver
Sound won't play through Onkyo TX-SR605 when using HDMI
The chances are that you have selected an incorrect sound setting or not switched it on, for the HDMI you are using. With Onkyo receivers each connection will have it own settings for video and sound. You just need to look in the manual as to how to select the settings.
May 08, 2017 | Onkyo TX-SR605 Receiver
I want to control my Sony Bravia KDL-46VE5 TV with my Onkyo TX-SR605 remote controller. I cannot find the Bravia remote control code.
Sony TV codes for the Onkyo TX-SR605 are : 0000, 0650, 1100, 1167, 1300, 1505, & 1651.
Instructions for the Onkyo RC682M and more remote codes are available here. The Onkyo TX-SR605 manual is available here.
I hope that helps.
Dec 27, 2009 | Onkyo TX-SR605 Receiver
Onkyo tx-sr605 remote codes
Just go to Onkyo.com support.. all the manuals are online in pdf form
Dec 14, 2008 | Onkyo TX-SR605 Receiver
We cannot get a disc out of a DVD player Onkyo CP702?
What is the model number of your DVD player?
Nov 30, 2008 | Onkyo TX-SR605 Receiver
DVD signal received in wrong aspect
PRESS SETUP GO TO MISCELLANEOUS PRESS ENTER THEN DOWN TO OSD SETUP PRESS ENTER AGAIN AND DOWN TO MONITOR AND CHANGE TO 16.9.
HOPE THIS HELPS.
CABLE GUY.
Feb 21, 2008 | Onkyo TX-SR605 Receiver
Onkyo tx sr 605
well most dvd aint 7.1 are using dolby digital cable in digital mode ect on sterio set output on ps3 audio setting to digital
Feb 03, 2008 | Onkyo TX-SR605 Receiver
Video on game and dvd seem to work
DO you have hdmi monitor turned on?
Jan 05, 2008 | Onkyo TX-SR605 Receiver
New home theater setup- no signal at tv using onkyo tx=sr605
Could well be the quality of your cables. if you have high end cables the consult a service agent. if you have the cables that came with the products, go and get some better ones.
Nov 04, 2007 | Onkyo TX-SR605 Receiver
Panasonic DVD-RP56 DVD Player Logo
256 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
