Question about Vehicle Parts & Accessories
How can i find what model of the ungo keyless start i have
I bought a ford pick up truck that came with a security alarm and a ungo remote control, I would like to know if this remote is keyless entry , so far I've been able to make it work only to turn the a
You can reset Your system by turning Your Key on and off several times and you should hear the doors lock and unlock.. you will need to this really fast/ On and Off and On and Off and On and Off . Then You should be able to set Your remote control numbers it will be a 4 digit code.. give it a try..
Dec 27, 2014 | Ford Cars & Trucks
Hi, i have a clarion ungo command start on my 99 f350 diesel truck, and i have no owners manual or setting instructions. i want to set it to start and run at 4 hr intervals cause i live in sask, canada...
Hey I happened to find this while searching for the same part number on the back of my remote. Mine is a Clarion Ungo SR6000 and the product manual is here: http://www.clarion.com/us/en/MungoBlobs/669/603/SR6000.pdf
My remote is broken and I'm trying to buy another online without having to go through a local dealer b/c they all want me to come by and I just want to order the stinking FOB.
Nov 30, 2010 | Clarion GPS
I have an ungo remote start/alarm. This AM the car would not start and the alarm went haywire- kept going off, took control of the car, A/C going on and off, etc. Had to disconnect the battery to get it to...
i have a ungo sr 6000 i missed placed my lcd 2-way remote so i only have the secondary 4- button remote. How can i disable the timer auto start!!!!!!!!! PLEASE HELP ASAP !!!!!!!!! GOIN BROKE ON WASTED GASSS!!!!!!!!!!!!!!
Jul 30, 2010 | Ungo SR6000 2 Way Security with Remote...
Clarion ungo alarm model 5100
Can't seem to locate a manual. Just get into the wiring under the dash and follow the larger wires from the alarm brain and cut each wire, one at a time, from the factory ignition harness them tape. Start with just the starter wire to see if that fixes the issue for now. If this problem just started, check to see if there is a tach wire that runs under the hood to a coil or injector. If this wire is disconnected the remote start won't see the car is started and will continue to crank the starter.
Nov 03, 2009 | Ungo S670 Car Alarm 2way LCD & 4butt Rem
I got a used jeep grand cherokke
if the remote batteries died simply replace the batterys and all is well. the factory remote isnt programable btw
Jul 30, 2009 | Ungo SR6000 2 Way Security with Remote...
2006 tacoma will not unlock when remote started. also dash lights and parking lights flash when remote started.
May not be programed to lock in remote start, secondly if programmed lights will flash while in remote start.
Jun 28, 2009 | Ungo SR6000 2 Way Security with Remote...
Vehicle Parts & Accessories Logo
73 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
