Question about Health & Beauty
How do I manually turn OFF the scales? - Health & Beauty
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Health & Beauty Master
  • 102,366 Answers
What make and model?
Posted on Jul 24, 2013
  • Jeannie Jul 24, 2013
    CVS Digital Body Scale
Calibrate Salter model 9140 bathroom scales
Remove the battery and count to 10 and then replace it.
i found this
You do not reset the scale. It only saves the last recorded weight of the user. So, if you weighed yesterday, it will put your recorded weight in memory. The next time you select your user number and step on the scale, it will compute the difference from your previous record and save your current weight.
and also this
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery until you first complete the steps listed above.
Not sure if this is the correct manual, but may be close. Page 3 and 4.
Salter Housewares Body Fat Computer Instruction Manual Page 3
Nov 27, 2017 | Salter Health & Beauty
Scale BFM588 User manual
Although the HealthOMeter.com site no longer posts a user manual for the BFM588DQ-81 scale, they do have a different model scale, BFM955-60, instruction manual that will work for the BFM588 because all the setting buttons are identical. You can download the manual for free at their site. Go to the site, under "Service & Support" setect "Instruction Manuals", then select "Body Fat Scales". Once there, find and select the BFM955-60. It will open as .pdf document and you can save it to your computer and print it out. It worked for my BFM588 scale for which I had lost the user manual.
Nov 16, 2014 | Health-O-Meter Health o Meter BFM588DQ-81...
My Salter Model 2001 kitchen scale, shows an 'ee' on the screen. This error code is not listed in the manual. Any suggestions?
"EE" means that the scale has been overloaded. Try placing a small weight (i.e. 250g block of butter) on the scale and then turning the scale off and then on again with the small weight still on the scale. What this does is to try and re-calibrate the scale. If this doesn't work then I am pretty certain that the scales will need to be replaced. The scales in question do have a 15 year guarantee and you can try contacting Salter Housewares directly if you have your proof of purchase.
EE showing on screen
Sep 12, 2014 | Salter 2001 electronic kitchen scale
How do you calibrate, it's a body fat scale, can't find model #?
It's important to find the model number to be able to find the correct manual. Below is a link to FAQ's about Taylor body fat scales.
If you do a google search for "taylor body fat scale" you will see a list of a few models. Examine each to see if one of them is the same as yours.
Taylor USA FAQs Scales
Searches related to Taylor body fat scale model number location
taylor body fat scale model 5741 manual
taylor body fat scale model 5761bf
taylor body fat scale model 5731f reviews
taylor body fat scale accuracy
taylor body fat scale 5731 review
taylor body fat scale athlete mode
taylor body fat scale readings
taylor body fat scale5758f manual
Aug 01, 2014 | Taylor Health & Beauty
Resetting my accur 8 digi scale cp-1000
please preform the following procedure
Calibration
1. Place the scale on a leveled surface & turn off the scale.
2. Press and hold the "MODE" key and ON/OFF key until the LCD
displays a random number.
3. Now release both keys and press the ON/OFF key once. The
display will read "CAL" and then "1000.0".
4. Place a 1,000g weight on the center of the platform and wait 3 to 4
seconds. The LCD display reads "PASS", then "1,000.0g". Remove
the weight and turn off the scale.
5. Calibration is complete and the scale is ready for use.
check this link for manual:
Untitled Page
Apr 25, 2014 | Health & Beauty
When i stand on my scales all it does is err i cant find my manual what can i do to fix this.thx
Normally you must "zero" electronic scales before each use. This is done by briefly stepping on the scale with one foot to make it turn on. After a couple seconds it should display "0" and then it is ready for you to stand on it.
Nov 01, 2011 | Taylor Health & Beauty
Have a braun thermoscan and want to change it from F to C degrees lost manual
From the manual of the thermometer:
This thermometer is shipped with the Fahrenheit temperature scale activated. If you wish to switch to Celsius (°C), proceed as follows:
• Turn on the thermometer. (If it is already turned on, make sure it is not in memory mode.)
• Press the /mem button and keep it pressed. Then press and release the activation button to switch over to the «change temperature scale» mode.
• By pressing the activation button again, the Celsius scale is activated, «°C» is displayed on the LCD. Each further pressing of the activation button toggles the scale between °C and °F.
If this isn't the right manual, go to: http://braun.kaz.com/kaz/service and select your country from there.
May 16, 2010 | Health & Beauty
When i try to weigh something on it it displays 'our2'. And does not work
OUR2 is probably OutZ or Out2, means you have to recalibrate your scale. Refer to your scales manual for instructions on recalibrating, usually you have to turn on your scale, press CAL button, wait till it displays for example 100g, depending on how much your scale can weight, then put that weight, for example 100g on your scale (you can use coins if you don,t have anything else, though be precise as coins can weigh more or less,informationon coins weight can be found in your country national bank site. After you put the weight, it should display OK or PASS, if it's FAIL or the scale turns itself off, it's either broken or the weight is not correct
May 16, 2010 | Microwave Ovens
Does not turn off automatically
Turn remote "off", press and hold "Kg - Lbs" button, turn unit "On". Display should show "0", then "320" or model number. Unit was programmed to disable auto off. Works great now.
Thanks
Jun 01, 2009 | Health-O-Meter Healthometer 320KL Digital...
Health & Beauty Logo
74 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
