Question about Kenmore Refrigerators
Does the kenmore refrigerator model #6882 have a never clean condenser
5 Suggested Answers
the dr
  • 447 Answers
SOURCE: inside fan motor - evaporator
Yes if you dont hear the evap fan wprking remove rear panel in freezer let me know what you see. Is coil iced over? Is fan running? Is the motor warm? Attempt to spin the blade gently to see if the motor is bound. You can oil these.
Posted on Dec 02, 2007
  • 3 Answers
SOURCE: refrigerator condensation
I have a Kenmore Coldspot Model 70262990. When I get wet shelves (water, not just condensation), I was able to trace my source to the cold air vent from the freezer. In my case, the water melts from the evaporator and collects in the rear lower section of the freezer. It is "supposed" to go down the drain tube. However I had the drain hole freeze over. Then additional water from the defrost cycle would accumulate in the freezer floor (under the plastic floor) and eventually find its way down the cold air vent between the freezer and refrigerator section. You'll need to unplug the unit, take the plastic floor out of the freezer, remove the evaporator panel to access the defrost drain, melt the frozen water (hair drier works nice), and remove all the water (towel/sponge & bucket). Make sure the drain is not frozen and not blocked. Then put it back together and plug it in.
Does anyone know how to stop the drain tube from freezing over?
Good luck.
Posted on Apr 26, 2008
  • 8 Answers
SOURCE: subzero model 650 refrigerator
If the light keeps coming back on and temps are rising in the refer section, then you most likely have an evaporator leak. Check to see if you see either a moist spot or ice on the back wall on the left side of the back wall of the refer. If you do, it's definetly a leak. Call a authorized Servicer.
Posted on Oct 13, 2008
  • 1218 Answers
SOURCE: Kenmore refrigerator model 53552200 evaporator fan
Good day,
First step is to check the condenser fan motor to make sure it is running. It is not unusual to dislodge something causing that motor to not be able to run after cleaning. In some cases one of the blades of the condenser fan motor can be bent causing the problem as well.
You access that motor from the bottom rear.
Posted on Apr 03, 2010
My Kenmore bottom freezer refrigerator model 59679243010 ice maker is mot working.
Check your temperatures, that typically happens when the freezer is not cold enough, Clean your condenser, that may be the cheapest fix.
Jan 19, 2016 | Kenmore Refrigerators
Where is the condenser in my Kenmore French door bottom freezer, and how to clean
Condensers are usually on the bottom of the unit and you can clean them by blowing out the dust with the exhaust side of a vacuum cleaner. Or an air compressor if you have one.
Some newer refrigerators have the condenser coils on one of the walls so they are inaccessible for cleaning. But since they are sort of sealed off there is really no need to clean since nada gets in there.
Aug 20, 2015 | Kenmore Refrigerators
Freezer and fridge not cooling. kenmore elite side by side, model # 52293100
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 11, 2011 | Kenmore Side by Side Refrigerator
Kenmore Coldspot refrigerator not staying cold. Model 106 9710582.
heatman101
Apr 14, 2011 | Kenmore Refrigerators
I have a Kenmore model # 596:75523400. Both the refrige and freezer is no longer cold. I can hear the fan but it's warm inside. Would cleaning the coils in the back help or is it really dead?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Jan 23, 2011 | Kenmore 53642 / 53644 Side by Side...
Kenmore refrigerator model 53552200 evaporator fan motor won't shut off since I had the unit unplugged to clean the condenser coil. It's been 2 days now, and I don't know if it has gone through a defrost...
Good day,
Apr 03, 2010 | Kenmore Refrigerators
Kenmore is running all the time.
Is temperatures ok inside? Has condenser been cleaned at any time ? What is the complete model number? Let me know, Sea Breeze
Mar 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore refrigerator not cooling and lights out
is the compressor hot? same as last job. unplug ref. clean the condenser coil, install new 3n1 start relay on compressor.
Nov 04, 2008 | Kenmore 53642 / 53644 Side by Side...
Water leaking out bottom of refrig/freezer
Sounds like maybe two things. Your freezer isn't closing correctly and condensation is forming, bad seal maybe. Other option is you need to clean the pan on the bottom of the fridge. Condensation gathers there and it is normal, but if you alot of crud down there it will cause water to gather. Hope this helps...
May 25, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
