Question about Dirt Devil POOL CLEANER FOR ABOVE-GROUND POOLS
What should my pump be set on when vacuming the pool
While vacuming loses suction, sand filter pressure goes high
That increase is due to the filter loading up with debris. Is the pool unusually dirty? If there is a lot of dirt and silt in the pool use the "waste" setting on your backwash valve while vacuuming.
This allows the water to bypass the filter and go directly out the waste line. Keep an eye on your water level because you will be removing water from the pool and may have to add more.
Jun 30, 2013 | Hayward SAND FILTER, PRO SERIES
Trying to open pool for my first time....not sure what to turn valves to so water will run into the filter from pool
red valve handles align with flow of water long ways the tail in direction of pipe valves open to open pool generally all Valves open Main drain (floor of pool). Skimmer square hole somewhere on side edge of pool... There could be a third Valve for a seperate Vacuming port (like mine) it can be either its below water line .. On the Round Sand filter theres a Multi port Valve I usually start the Filter in RECIRC mode .. While I net and gather debris then I add floculant leave on recirc two hours . Then Shut ALL down for 12 Hrs while all the algae and debris sinks to bottom . Water will be reasonably clear.. Make sure pools Extra full , And Vacum all on bottom on waste setting
Jun 04, 2011 | Hayward SAND FILTER, PRO SERIES
What does my filter need to be set on before i vacuum my pool
For regular vacumming with these Hayward pool filters, you will use the regular filter setting. If you have a very dirty pool or heavy loads of debris, vacuum on the waste setting so that the debris will bypass the filter and not clog or litter it.
May 21, 2011 | Hayward SAND FILTER, PRO SERIES
Dirty water coming back into pool
There is a spider gasket in the valve that could be broken or torn apart.
To check it seperat the valve at the handle and you will find the gasket
inspect .
The Pool Tech
Jul 05, 2010 | Hayward 1 HP Matrix Pump EC40 Perflex...
What setting should I have my Hayward Sand Filter system on when I am vacumming out my pool?
Your pool filter should be set on "filter" for normal vacuuming. If you have a heavy debris load or an extremely dirty pool, you might want to vacuum with the "waste" setting, if your filter has one.
May 20, 2010 | Hayward SAND FILTER, PRO SERIES
Vacum
First, make sure that you are on the "filter" setting. If you have large debris or an extremely dirty pool, you might want to try the "waste" setting. Also, make sure that your pool filter has been backwashed. You might also want to consider changing your sand if it is only. It could have lost some of its effectiveness. Let me know if you try this and are still having problems.
May 21, 2010 | Hayward SAND FILTER, PRO SERIES
I have a intex pool
go to intex.com and watch the video
Jul 12, 2009 | Intex 15' X 42" Easy Set Pool Complete...
Need help installing filter pump model 635 for my swimming pool
Just go to the Intex Corp link below. Choose the appropriate pool and/or pump. At the bottom of the page you will see a link for instructional manuals and videos. Hope that helps.
http://www.intexstore.com/ProductList.aspx?categoryID=30
Oh yeah, by the way...you may want to start looking around for another pump for that pool if you plan on using it more than a year. I have had mine for 3 years and I spend more time in the pool vacumming than I do in the house!! The 635 pump is not strong enough for the 18x52 pool nor does it filter out fine silt and sand...it sucks it up and spits it right back into the pool thru the return. Good luck to you
May 17, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Dirt Devil POOL CLEANER FOR ABOVE-GROUND POOLS Logo
43 people viewed this question
Top Dirt Devil Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Dirt Devil Pool and Spa Expert? Answer questions, earn points and help others
