Question about Saws
Toolkraft table saw model 4100 - Saws
blueextc3221
  • 15935 Answers
SOURCE: I'm looking for a manual for a Craftsman table saw model 137.2488
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0606545.pdf
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Aug 09, 2009
SOURCE: Manual for Powermatic model 70 table saw
Did you try Powermatics web site?
Posted on Aug 23, 2009
  • 7 Answers
SOURCE: I have a craftsman table
Maybe you could try using the outline of the regular insert to cut a new insert out of a piece of polycarbonate (lexan) or ABS plastic. The clips that hold my dado insert barely hold it in place on mine, and I've seen other saws that use plastic.
Posted on Aug 14, 2010
puertobori
  • 7733 Answers
SOURCE: need the manual for my delta 10" table saw model
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 17, 2010
  • 396 Answers
SOURCE: Owners manuel for grizzly 10" Table saw Model
You can go to grizzly.com to download the manual at the below link.
http://cdn0.grizzly.com/manuals/g1023z_m.pdf
The parts list can be downloaded at the below link.
http://cdn0.grizzly.com/partslists/g1023z_pl.pdf
Good luck, If you have any questions let me know;
Stephen.
Posted on Apr 27, 2011
I have a Bosch 4100 table saw. The first indication of trouble was that the rpm's seemed to be running dangerously high. Then after cutting a couple of small boards to get through the day, the rpm's t
Make sure the tool is unplugged - on the motor there is a cap held on by 2 screws. Inside you will find the speed control #2610997306 and while you are there I would recommend changing the brushes #2610997207
You can purchase these parts from ereplacementparts.com
Jan 28, 2015 | Bosch 4100 09 10" Worksite Table Saw...
Toolkraft saw won't turn
need more info and maybe some pics...bearings, blockage, locked arbor???
Jul 04, 2014 | Saws
Riving Knife won't go down enough.
ok thank you for reporting that your problem was solved.
Feb 18, 2012 | Bosch 4100 09 10" Worksite Table Saw...
Brand new bosch 4100 jobsite table saw
there are no adjustments on the movement you described. If this is a new saw as indicated I would return for warranty repair/replacement.
Feb 09, 2012 | Bosch Saws
Smoking
if it is smoking when power is switch on - there is a chance that the motor winding has shorted out. OR it could just have sawdust in the motor, ( use a air compressor to blow down the saw and motor and see if this solves the problem ).
c...
Jan 02, 2011 | Bosch 4100 10" Worksite Table Saw
Electric blade brake sounds like it is seized up. Upon starting table saw (bosch 4000), motor sounds like it is binding. How can I disengage the brake??
There is no electric brake on the Bosch 4100 table saw. If the motor sounds like it is being held back its possible the rear armature bearing has seized or the field coil is faulty. Both these problems cause the motr to not turn at full speed. The motor must be serviced.
Dec 08, 2010 | Bosch 4100 10" Worksite Table Saw
Bad vibration and noise from saw
Are you sure blade is straight, and mounted on arbor correctly? that's the first thing to check. Or remove blade and 2 arbor plate's and run saw. If you have a vibration after that you have a bearing problem.( rear bearings go bad on these saw's) other they are the best saw for the price. We have about 50 of the 4000 model. hope that help's Never had a vib problem.
Jun 01, 2010 | Bosch 4100 10" Worksite Table Saw
Saw slowed down. Shut off saw and restarted. runs backward.
Sonmethings shorted out inside motor / strip and see if any debris is in there.
It has somehow repolarised from the negative side to pos side!!
Jan 20, 2010 | Bosch 4100 10" Worksite Table Saw
Sounds like I need to lubricate something.
flip over the saw you will see a motor
take it out the bearings need changing.
Aug 06, 2009 | Bosch 4100 10" Worksite Table Saw
Saws Logo
63 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
