Question about Apple (1910) MP3 Player
1910 100 lin bundert mark note - Apple (1910) MP3 Player
What do you call the little switch under the knob that make tread meal go faster? I have a model 9890 Vistamaster and it shorted out
The little device is known as a potentiometer if it has 3 terminals. Unlikely but if only 2 terminals it is a rheostat.
The device should be replaced with an identical device if possible and the original should be marked with the type and value, eg. log, antilog or lin(ear) and 50R, 50K or 50M or any of many other values.
If designed to handle significant current it will be marked wirewound...
Most electronics constructor outlets will stock a range of these fairly standard devices.
Feb 06, 2018 | Cars & Trucks
Why oil light comes on own my 95 Lin mark 8
Gary take your car up to Advance Auto they can check your oil sending sensor.
Jul 12, 2016 | Cars & Trucks
How many linear feet is 18 sq.ft.
You get square feet by multiplying linear feet with another linear feet. 18 sq.ft = 3 lin ft x 6 lin ft or 2 lin ft x 9 lin feet or 4,5 lin ft x 4lin feet.
Sq ft is used to quantify surface area where linear feet quantify distance but lin ft x lin ft gives you square ft (surface area)
Mar 07, 2016 | Office Equipment & Supplies
Aafter washing my clothes comes out with black marks on clothes and in drum
Check to see if there is old soap residue trapped in the linning of the door seal. Also a run through with a water softner like Calgon can help.
Oct 03, 2014 | Washing Machines
How to install tiing on a 2001 lin ls 3.9
On the sprocket you should see same marks, clean it well, it looks like a small hole
Mar 26, 2013 | Lincoln Cars & Trucks
Citroen berlingo crankshaft pully layout
Citroen has timing hols where you can put a 8mm bolt in the pulley and a 6mm in the crank to lin them up check this pdf on timing. it'll help From Shawn Howell http://www.search-document.com/pdf/1/citroen-berlingo-timing-marks.html
May 08, 2012 | 2006 Citroen Berlingo 1.9d
My mark 8 driver side door will not open from the outside, when I pull the handle I hear a clink clink noise. I think the metal poles inside the door is disconnected. How do I fix it?
start by removing the in side door panel then you should be able to see what came off or broken this happens some time when a slim Jim is used incorrectly look 4 hidden screws in arm rest some times they are covered by little plastic caps or under a light Lin's under the power switch bot the bottom part usually UN snaps
Mar 12, 2010 | 1996 Lincoln Mark VIII
My 1996 Lincoln Mark VIII will not start. It
Check your power to your fuel pump. Put your ear to the filler for the gas and get someone to turn on the key, do not crank.. You should here the fuel pump cut on. If not suspect pump problem. You can also take the lin loose at the fuel filter and check to see if gas comes out after key is turned on and work your way to the engine if you get gas there just follow the lines.
Jun 30, 2009 | 1996 Lincoln Mark VIII
44 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
