Question about Swann Communications Swann ADW200 less Camera _ Recei SW322yDW
Power input on receiver broke off circuit board
Can my powered subwoofer be fixed?
Possibly, It took a while but I had a pair of 25 year old JBL Subs repaired after many said they cant be fixed. Have a look on line or in the phone book for your nearest amplifier / speakers / musicians electronics repair shop.
Apr 08, 2015 | Audio Players & Recorders
HDMI/ DVI inputs failed approx. one month after connection of Denon home theater receiver with HDMI pass-through feature "on." Gear successfully re-connected via component video...
hi welcome to fixya
i want to clarify first the problem sir so as of now the problem with your tv won't power on then you are using again the old main board is that right ? when you use the new replacement main board the tv is functioning will the only problem is that the HDMI / DVI inputs doesn't work. and now you encountered power supply problem like won't start up or something that cut the supply in which the stand by indicator is turn off so as my idea it has a problem with the old board. but before you come up with the board making sure all the connectors coming from the power supply is properly connected to the main board as will as flexible and lvds cable for the T-con board is properly inserted.just let me know if is that what you are asking for so i can give you additional solution thanks for consulting the fixya.
Aug 30, 2011 | Televison & Video
Hdmi circuit fried in thunder storm! radio still works just can't get video through hdmi circuit! Can the hdmi circuit board be replaced and how expensive would it be? Is it just a radio boat anchor...
Depending on your TV input/output, you can run your video components to TV via HDMI then run your audio out via digital optical, RCA, or other means to receiver. If you have more than one HDMI input on TV or, if you can use component for video to TV, you can then run audio to receiver. Video pass through to the receiver is not the best way to hook up your system. Let me know if this makes sense to you.
Dave
Aug 10, 2011 | Sony 500W 5.1-Ch. A/V Home Theater...
My mission Mv-as subwoofer has an intermittant problem - it works for a short time and then the unit fails to function. there is not a problem with the power and the speaker unit is not damaged. is this...
Yes , the possible fault can be a suspected fault in the sub woofer power amplifier. You will need to remove to check the circuit.
It can be a faulty or dry soldering in the main board., re solder IC.
Also if the IC is faulty it can be erratic, a signal test must prove it right applied to the input.
Oct 27, 2010 | Audio Players & Recorders
I have receiver VSX-D509S. Have had it for
Check for a bad ground on the input circuit board. you will need to re-solder them. Remove top cover and rear panel (many screws on rear panel) The input board can easily be accessed and resoldered. you should also check for a bad ground on the speaker jacks. If it is not repaired, sooner or later you will probably need an output IC. good luck.
Oct 16, 2009 | Pioneer VSX-D509S Receiver
I just changed the battery on a garmin ique 3600 and the backlight won't come on. Any tips?
Most likely you broke one or both wire from the backlight to the circuit board. Open the unit up and look for a black and red wire. Both should be soldered to the circuit board. LED's are used for the backlight and so it does make a different that the back and red wire are soldered to the circuit board correctly.
Oct 04, 2009 | Garmin iQue 3600 GPS Receiver
I broke off the power connector inside my Tomtom
I finally managed to pull back the rear cover by inserting a thin piece of metal at the top of the rear cover. It snapped off by pulling it backwards and then downwards. And I soldered the connector back on. I only had to solder the 4 feet of the small metal shield, the contacts are just pressing on the circuit board.
Mar 30, 2009 | Tomtom One XL GPS Receiver
Subwoofer blows the internal fuse when receiver is turned on
possible solution - this can be caused by a fault in the receiver unit. the sub has a triac 'high side switch' circuit that can cause the fuse to blow if it doesn't get a good switching signal e.g. if the receiver power supply is not running at the full voltage. check the plug pack wire for damage, check the 12v input area on the receiver board for dry joints, particularly the power input socket. hope this helps.-pj
Dec 11, 2008 | Bose Acoustimass 16 Speaker
Battery charching input broke off of phone
Once the circuit board is damaged the phone is usually done for. The only thing i would suggest is to see if your service provider has a replacement phone or circuit board that a certified tech can replace/install. For future ref, opening the phone is a no-no and voids any warranty, the goes for super glue.
Feb 26, 2008 | Siemens SX56 Pocket PC
Swann Communications Swann ADW200 less Camera _ Recei SW322yDW Logo
Top Swann Communications Home Security Experts
Lawrence Oravetz
J.D. Browning
J.D. Browning
 Mikey
Mikey
Are you a Swann Communications Home Security Expert? Answer questions, earn points and help others
