Question about Coffee Makers & Espresso Machines
Saeco phedra programming
Does USN Phedra Lypo XT contain Creatine?
What kind of lens do you intend to use it with ?
Oct 31, 2016 | Cameras
Saeco Intuita adjust water volume
Press and hold the coffee button the entire time until the cup gets to the length that you prefer, then let go. That will program the cup to that length.
Saeco Parts
Saeco Espresso Parts Brew Groups Pumps Boilers Water Tanks Drip trays
Sep 14, 2013 | Saeco Magic De Luxe Espresso Machine
Engine will not start. its not the batterey
Look for starter and hit a couple of times if it works replace starter
Sep 04, 2013 | 2006 Lancia Phedra 2.2
I am looking for a manual to de-calc and clean in Saeco Vienna superautomatica sup 018
Descaling Saeco Automatic espresso machines SAECO VIENNA SUPERAUTOMATIC MACHINES:
SAECO VIENNA DIGITAL - MANUAL DESCALE PROGRAM
1. Fill the water tank with the Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water.)
2. Turn on the machine. Run approximately 1 cup through the steam wand by turning open the hot water steam valve). Turn machine off and let sit for 5 minutes.
4. Repeat this procedure until the water tank is empty. Then rinse water tank thoroughly and flush the machine by running two tanks of clear water through the steam wand.
5. To clear the "Decalcify" message on the Digital model, press the MENU/OK key to go into programming mode. Scroll up or down to select the "Signal.Descal" function. Press MENU/OK. Next, the messages " Quantity Water Not Reached" and "Left Quantity" will flash. Press MENU/OK again - the message "Reset Descaling Program - Yes" will appear. Press MENU/OK again. The Descale meter is now cleared.
SAECO VIENNA DIGITAL - AUTOMATIC DESCALE PROGRAM
1. Press the MENU/OK key to go into programming mode. Scroll up or down to select the "Descaling" function . Press MENU/OK key. Place a large container under the hot water/steam nozzle. Fill the water tank with Saeco descaling solution. (1 bottle of Saeco descaling solution to one full tank of water. Refer to the instructions on the bottle).
2. Then completely open the hot water/steam rotary valve/knob. The pump starts and the descaling program begins. During this phase the pump runs at intervals and the message "Machine is Descaling" is displayed. The complete program takes about 40 minutes. Do not add any water to the tank during this phase. When the message "Descaling Finished" appears, close the hot water/steam valve. The message "Rinse Machine" will appear.
4. Remove and rinse water tank thoroughly, fill with fresh water and replace on machine. Empty the container under the hot water/steam nozzle and replace. Flush the machine by running the tank of clear water through the hot water/steam wand until the message "Rinsing Finished" appears. Exit the Programming mode by pressing "MENU/OK" Refill the water tank with fresh water.
Descaling Single Boiler Home espresso machines (HOME SINGLE BOILER ESPRESSO MACHINES)
Approximately every 3 months (depending on your use and the water hardness), clean the machine with natural citric acid based decalcifying agent.
1. Add a descaling solution into the water reservoir. Mix thoroughly to dissolve (use warm water for better results).
2. Remove the filter holder and place a cup under the group head and another cup, or other container, under the steam wand to catch cleaning solution.
3. Turn espresso machine on, turn coffee pump on and run approximately 8 oz. of solution through the brew head. Turn machine off and let the machine sit for 15 minutes.
4.Run approximately 8 oz. through the steam wand, and again, turn machine off and let sit for 15 minutes.
Repeat by allowing solution to run alternately through the steam wand and brew head. Turn espresso machine off after each cycle. Repeat process until solution has been run through.
5. Do not leave espresso machine on. Do not wait for the ready light to come on. Do not use the steam switch during this process. Do not allow reservoir to run empty!
6. Rinse reservoir thoroughly with fresh water. Refill reservoir with fresh water. Run half a tank of fresh water through group head, alternating between group head and steam wand.
Feb 28, 2011 | Saeco Vienna SuperAutomatica Coffee...
Saeco Magic Comfort plus: Despite descaling the machine twice, the Descaling notice remains lit on my screen. Brews great coffee but what gives?
Hi
In the menu there is a program below the descaling program that says Reset descale. Enter this program and choose "yes", and make sure that you push the enter button to lock your answer. If you don't it will still be there.
Also go to your water hardness and move it to the #4. This will prevent you from having to replace the boiler sooner than needed. Descale when told to by the machine.
Jan 09, 2010 | Saeco Magic Comfort Plus Espresso Machine
Need to adjust coffee dose for odea go
SEE THE VIODEO AND OTHER LINKS ON TYHAT SAME PAGE:
ALSO:
Saeco Odea Go adjusting coffee dose Questions
May 21, 2017 | Saeco Odea Go
Programing clock on saeco coffee pot
You can get the instruction manual for your machine at saecooutlet.com, Click on user manuals and then select your machine.
To set the clock, hold the hour or minute button until the display flashes then adjust the time.
Feb 01, 2009 | Saeco TDCM15 Renaissance Stainless Steel...
Personal User Code
usually the code was programmed as all 1's... Try take and it should work..
For saeco parts or cleaning supplies please visit www.cerinicoffee.com.
Mar 31, 2008 | Saeco Royal Professional Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
