Question about Prima CV1311 TV
Prima plasma whilst watching tv there was two loud cracks heard the screen went dark snowy,the menu comes up can barely see it but no picture
Re: prima plasma - Prima CV1311 TV Standard (CRT) Televisions
Likley power supply
Posted on Jan 24, 2008
Sell it and buy real tv
0 characters
3 Points
My 42 inch plazma screen {prima} started to go all funny and then just went away, still has the sound, i left it on hoping that the picture would come back. all it did was start to smell like over heated...
not tv stopped working & was able to fix it myself
that smell was something burning out..........obviously
what part though that could be about anything
in mine it was a thermistor...the video section of the tv wont work without it
Sep 26, 2009 | Prima C2012 TV
Front panel blocked or locked
RCA Entertainment Series 32" Plus Gold, GEMSTAR, xbox ready has been in the shop twice so far. Transformer replaced and 6 months later the picture suddenly had horizontal white lines that gradually spaced apart more from top to bottom and it had a gray hue and fuzzy, but I still watched it for 3 months that way. Today I turned it on and about a minute later I heard a loud crackling sound coming from the back and the picture disappeared, screen went black. Is it worth fixing again? Please contact me at
Jul 09, 2009 | RCA 32F531T 32" TV
Samsung DLPTV bad picture and buzzing sound
You color wheel blew a bearing. You need to replace the color wheel.
Mar 28, 2009 | Samsung DLP HL-P5663W 56" TV
Prima HDTV has a black screen on TV, but works fine while Playing DVD
try turning the channel up or down with the tv remote to input 1 or 2 depending on which one is being used for the dvd player. tv should use input 1. dvd should be on input 2.
when turning the channel set it to show the dvd screen, then go up 1. if it doesn't show, return and go down 1.
Oct 22, 2008 | Prima C2012 TV
Picture very dark
try to adjust the screen at the back of the plyback.a big parts inside the tv with a wire attach to the picture tube. thre's a two knob there, the lower knob try to adjust it
Oct 09, 2008 | Sylvania 6432GG 32" TV
No sound or picture on my prima plasma tv
Sep 30, 2008 | Prima CV2011 TV
Prima q2716ss
WE took our T.V. to Gragal Electronics in Waterloo, On. and he was able to reset the settings within the tv and it only cost us $81.36 to have it fixed. Apparently other remotes can go in and corrupt the saved settings, which messes up your tv.
Mar 24, 2008 | Prima CV2011 TV
My prima tv on screen dispaly is in chinese? i think and picture is messed up
the picture tube arced and erased some of the eprom settings.this is a common problem
Mar 24, 2008 | Standard (CRT) Televisions
TV screen
make sure you lock the setting menu.
Sep 06, 2007 | Hitachi 27UX01B 27" TV
RCA F27650 27" TV - Snow Bursts
The model you listed, F27650 uses the new ATC113 series chassis, which is only about 3 years old. The ATC113 chassis is not known to have snowy issues, but if yours is then I would suspect that a solder joint is loose in the tuner. If your set is actually around 9 years old, then it might perhaps have the notorious CTC175 - CTC187 series chassis, which went snowy all the time due to cracked solder joints on the shield grounds around the tuner and microprocessor. In either case, some good quality resoldering should cure your trouble. If you have never done fine solder work on PC boards with small surface-mount parts, allow a qualified tech to handle it for you.
Aug 08, 2007 | RCA F27650 27" TV
Standard (CRT) Televisions Logo
179 people viewed this question
Top Prima Standard (CRT) Televisions Experts
olayoju victor
Are you a Prima Standard (CRT) Television Expert? Answer questions, earn points and help others
