Question about ShoreMaster Blue Wave Custom Boat Cover - 2200 Pure Bay 06 - 11, Prism
2011 blue wave pure bay 2400
Fuel problem
Why is my pure sine wave keep blowing fuses?
please check if all attached connection are tight .Sometimes loose wire connection also causes fuse blow
Sep 15, 2014 | Electronics - Others
I'm trying to run a 750 watt whirlpool compact microwave with a 2500 watt Cobra inverter. The microwave runs normally, but it won't heat. If I plug it in at my house it heats fine. I'm stumped. I load...
I assume your not using a pure sine wave inverter. A lot of electronic devices won't work on a lower cost inverter (modified sine wave) that has a square sine wave, either invest in a true sine wave inverter or don't run sensitive electronic equipment, I'm somewhat surprised you didn't damage the circuit board in the microwave...Below is a link of a inverter that would work if you want to spend the money for one.
2500W 5000 Watt Power Inverter Pure Sine Wave 12V dc 110V 120V ac LCD...
Feb 05, 2018 | Electronics - Others
Need owners manual
Without knowing make or model other than 600 Watts and pure sine output:
http://www.donrowe.com/user_guides/samlex/ssw_series.pdf
is for a series of pure sine inverters, yours should be similar enough to the 600 Watt version to be of practical use.
Jan 14, 2012 | Inverter 600 Watt Pure Sine Wave
Frequency Inverters DC-AC
I highly suggest you invest in a good quality inverter. For most equipment either pure or modified sine wave is fine. I would suggest you install a line conditioner after a UPS for any computer products. The line conditioner stabilizes the voltage much more closely than a UPS will.
As far as building your own, I've taken apart a lot of UPS models which have a DC-AC converter in them and they are filled with lots of heavy heat sinks, transistors, resistors, capacitors, etc. You can usually find these very cheap since the batteries die but the converter is fine. Check the input voltage of the original unit and start from there to make one easily that has everything already assembled with minor modifications.
Jan 15, 2018 | Xantrex Technology Ags Harness Cable...
Run a CPAP on a power inverter
I would not do this, you really need a pure sine wave inverter to guarantee the safety of your CPAP machine. At the price they are selling this device it could not be pure sine wave. 150W pure sine wave would be $70-$100.
Mar 05, 2009 | Thermal Engineering Corporation I-Tec 150...
Monitor 2400 heater will shut down when I run My generator
A UPS unit might work. Electronics need steady clean power.
Dec 18, 2008 | Intel CASE 350W PWRS ALLIED W/ 24PIN +...
2400 watt inverter in alarm
Are you using the correct by-pass relay. These are specially made to be a break-before-make just to prevent what your describing.
Nov 15, 2008 | Inverter Pure Sine Wave 1500w Inverter
ShoreMaster Blue Wave Custom Boat Cover - 2200 Pure Bay 06 - 11, Prism Logo
49 people viewed this question
Top ShoreMaster Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a ShoreMaster Boating Expert? Answer questions, earn points and help others
