Question about Kitchen Ranges
Glem ovens Glem 5 burner top gas oven (model number UN4S12Q).... how do I turn on the broiler, and is the broiler in the oven or on the bottom (where we are using for storage)? thank you in advance.
james klgr
  • 362 Answers
SOURCE: Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
Posted on Dec 08, 2007
Master_Tech
  • 770 Answers
SOURCE: oven & broiler not working
you ignitor is going out you will need to replace it the ignitor needs to draw a min of 3.2 amps in order to open the gas valve coil if short of this it will not open at thimes it may just have enough to open
Posted on Jul 09, 2008
docjohn174
  • 943 Answers
SOURCE: GX XL 44 Gas Stove Oven won't Work
HI. thanks for your question. the problem you are having is with the bare igniter, located in the oven on the gas burner. replace the igniter. thanks the appliance doc.
Posted on Oct 12, 2008
SOURCE: Oven burner doesn't light
Replaced the ignitor on mine 10 mins ago.... Works like it's brand new. You have to remove the bake pan in the bottom of the stove, remove the drawer, and the sheet metal shield protection the connection. Entire job was 10 mins.
Posted on Oct 22, 2008
SOURCE: GE spectra xl44 - Oven not working, broiler & stove-top burners fine
replace the ignitor for the oven. it's the lower one and not the one on top.
Posted on Nov 15, 2008
I tried to use the oven part of the glem gas, the igniter fires it up but it turns off as soon as I remove pushing the knob
can you smell any gas when the knob is set ?
before you ignite
in none or only a small smell of gas
can only think the gas valve faulty on that knob or the
gas pressure to the burner is lower than it needs to be
this is an example its a glen gas double oven
Oct 17, 2016 | Kitchen Ranges
I HAVE GLEM GAS COOKING RANGE PURCHASED 6 YRS BEFORE FRM SAUDI ARABIA. NOW IN INDIA CHENNAI. PLS LET ME KNOW THE SERVICE CENTRE DETILS
Please give me details of Glem gas cooking range service centres in Kerala . My id -mecentpl@yahoo.com
Nov 14, 2010 | Ovens
I have a Glem Gas Modena oven.2 of the burners do not ignite at all and another one has very small ignition. I don't know where the problem is as I am a newbie to troubleshooting ovens. Thanks for your...
Hi, just seen this, might be able to help if not sorted.
Do the burners ignite without using the ignition ie by match?
If not its probably the jets which are blocked.
If you need to know how to clear these let me know
Jun 11, 2010 | Ovens
Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 07, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Bottom burner in my oven barely comes on, in turn, not heating my oven to the temperature that is selected. Top burner (or broiler seems to work fine). The gas stove is a GE XL44 and is 6 years old. Please...
You need a new t-stat control. Your element is fine. Give us a call with your complete model number and we'll get the right part out to you asap to get you ready for the winter.
Oct 18, 2009 | Ovens
Broiler on top works but oven wont ignite
OK, it is likley that the oven ignitor isn't working and needs to be replaced. To verify if this is the problem, when you turn on the oven to BAKE and set the temp at say, 350. Watch through the window, (or you can have the door open). Look at the bottom, back, center and see if you see a bright orange glow appearing under the bottom panel.
If you don't, that is why the oven won't lit the gas. There is an ignitor for both the broiler burner at the top and for the bake burner in the oven compartment.
It might be possible that your oven uses the same ignitor for both the broiler and bake burner tubes, so you could swap them if you wish to confirm that is the problem before you go and order/buy a new one.
Sometimes the ignitor burns out half way through but because it still lits/glows, people think it's OK, but it won't get hot enough to signal the gas valve to open and allow gas to ignite and get the oven cooking.
If you want to see a line drawing and a parts list showing the ignitor(s), go to searspartsdirect.com and enter in the model number of your oven and click on the links shown.
Hope this helps and best regards!
Jul 31, 2009 | Ovens
Oct 28, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
OVEN WON'T WORK
you need to replace the bottom oven ignighter take the racks out then remove lower oven bottom take it out then remove flame spreader and ignighter will be on burner bar get replacement from appliance repair store take model number with you just because it glowes don't mean its good it should light withen 30 seconds
May 24, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Burners don't receive gas though oven/broiler does
tommi, this model has a cooktop lock-out solenoid feature. Try pressing and holding the top light keypad for 5 seconds and see if the top comes back to life. If not, check your owners manual, it may be a different key. The lock-out solenoid is in the back behind the outer panel. The cooktop lockout valve has been redesigned from a AC to DC voltage because of complaints of chattering. The new part number is 8184768. Lets hope you don't need it and just have the top locked out.
Apr 10, 2007 | Kenmore 75844 / 75849 Gas Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
