How do i unregister a phone extention for a mitel 5330e
I need to know how to unregister a phone extension so i can register another to it for an employee. how do i do that? i cant find it anywhere online.
SOURCE: Change the Extension ID To New Employee Name
To change the names on the NEC Dterm 80.
Feature, Conf, #, 0, *, 8974, LINE 4, 18.
Select Conf to go to the name you want to change.
Select Hold to erase the characters.
Select Transfer to save it.
Once you save, make sure you go back to "18".
Posted on Apr 22, 2008
  • 25 Answers
SOURCE: tesco arc200
to register the phone press the page button on the base for 10 secs til the base starts to beep the register the handset in the menu of the phone the pin for the base is 0000
Posted on Feb 16, 2009
SOURCE: changing employee name on extension
http://www.phonserv.com/1_m7310_phone_meridian_norstar_phone_system.htm
This has PDF file that will give instructions.
Also this link has more instructions:
http://www.phonserv.com/1_PDF_user_guide_meridian_norstar_phone_systems.htm
To Change the Name on a Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "Chng"
4. Enter the mailbox number (extension. you want to change the name on
5. The display shows "Reset Password"
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
Posted on Mar 10, 2009
  • 4 Answers
SOURCE: HOW TO CHANGE NAME ON THE EXTENTION LINE
The manual was no help but this website was a lifesaver
http://norstarsupport.com/Support/DR5_Chg_name_phone.htm
Posted on Mar 11, 2009
Techy101
  • 132 Answers
SOURCE: my tracfone says unregistered sim on it
http://www.tracfone.com/phone_details.jsp?model=PCTFV170P_EN
Visit this URL and click on the tab that displays "activate or reactivate phone".
This will take you through the necessary steps to activate your device and your sim-card. Thanks.
Posted on Mar 26, 2009
Mitel 5330e IP phone. Saying voice mailbox is full on an extension when someone rings the number but when pressing the voicemail button it says I have no messages
Try to dial voice-mail, press star and manually enter the extension and pass code. You could have another mail box notifying that phone
Dec 06, 2016 | Mitel Computers & Internet
How can I unlock my Mitel 5330e ip phone?
Why did it lock in the first place? Is it an IP device only, have you enabled phone lock, is it locked out?
Could be a number of reasons
Mar 13, 2015 | Mitel Computers & Internet
How can I get my wireless headset CS520 model to answer a call without having to lift the phone receiver first?
A headset button can be added to the phone that when pushed will activate the headset port on the phone. Once added the light will light when headset mode is active. This button can be added through the multi-line set key assignment for in the mitel. I would also suggest added a release button at the same time as the release key would be used to disconnect a call in headset mode.
Mar 09, 2015 | Mitel 5330e IP Phone 50006476
Password needed for messages on mitel 5330e
Try password 1111 as this is the default for mitel voicemail.
Feb 12, 2014 | Mitel 5330e IP Phone 50006476
How do I change voicemail setup?
Login to you voicemail and listen to the prompts
Jul 23, 2013 | Mitel 5330e IP Phone 50006476
What is the superkey?
It is the blue button above the red button.
Your system will basically have an extension setup to the phone. For the 2 to talk to each other you will need to send the pin.
Our setup is ***extention number. Then hit superkey. Yes you need the 3 stars.
But your system maybe configured differently.
Apr 20, 2012 | Mitel 5224 IP Phone
I am trying to register my Mitel 5201 IP phone to our mitel system but it is not working. The message indicator light does want to flash anymore, nothing happens when i connect it. Please help!!!
the 5201 set must be registered manually in the phone system. Log into the system. Change the extension. Type the MAC address of the phone in the proper field in the form. The MAC address is located on the bottom of the phone.
Sep 14, 2010 | Mitel 5201 IP Phone
Call divert
You can use the superkey
Phonebook - No
Advisory msgs - No
call forwarding = Yes
Allways = Review
from there you can select the extention number you want to forward the calls to. Having done that you need to turn on call forward always on. I do this by using one of the programmable keys on the Phone
Jul 07, 2009 | Mitel 5212 IP Phone
Log In Mitel 5212 IP Phone trouble
Hi this is probably because the phone has gone to Hotdesk mode and your company blocks hotdesk phones from making external calls. You will need to log back into the phone. If you know your extention number you can press *96 on the phone you then need to enter your extention number and press # you then need to enter a pin number. If you do not know your oin or have not been given one try pressing # again if the phone reasks for the pin you will need to contact your systems administrator to reset your pin - Hope this helps (ps *97 loggs the phone out)
May 08, 2009 | Mitel 5212 IP Phone
Computers & Internet Logo
David Payne
David Payne
