Question about Moen 7310 Legend Single-Handle Kitchen Faucet with Side Spray Chrome...
Moen Kitchen Faucet Repair Diagram - Moen 7310 Legend Single-Handle Kitchen Faucet with Side Spray Chrome...
jj505
  • 195 Answers
SOURCE: Loose handle on my Moen single handle kitchen faucet
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Posted on Apr 06, 2009
  • 3600 Answers
SOURCE: I have a moen pull out kitchen faucet that leaks
You have a bad internal o-ring or the sprayer o-ring is leaking, if you look under the sink turn it off and then turn it back on, if you see it leaking out the center shft where the water pipes go into then the faucet may have a broken pipe or loose pipe. check and tell me where it's leaking at. You can buy kits to repiar them they are inexpensive.
Posted on Aug 30, 2009
  • 44 Answers
SOURCE: I cant stop my Moen single lever kitchen faucet
1. If it's "leaking" from the body then, the O-Rings between the body of the faucet got gunked up with minerals from your water. This interferes with the seal.
The answer is to take some grit cloth/very fine sandpaper and clean the inside of the spout body. Wipe clean. I would also suggest replacing the O-Rings on the faucet body, but at the very least wipe the O-rings and faucet body clean.
THEN: lubricate the inside of the spout body AND the O-Rings with silicone grease. It's translucent and readily available and the only thing I would ever use for a faucet repair. NOT plumber's grease, NOT WD-40.
Reassemble and enjoy.
2. If it's dripping, the you need a new cartridge. You can get them for FREE from the hardware store if you have the old cartridge to trade them. The problem is that Moen cartridges are water-sealed into place and you need a special tool to break that water seal. The special tool (just a tiny piece of specifically shaped plastic, really) comes, you guessed it - with the new cartridge.
Two possible solutions: a) bite the bullet and just buy the cartridge (~$25) or buy a Moen cartridge puller, usually available from the hardware store as well for about the same price. Ask, they might even lend you one.
The point of whichever tool you end up with is to rotate the cartridge itself inside the faucet body to break the water seal so that you can pull it out with a set of pliers. There will be a retaining clip to pull out as well.
www.plumbingpartsdepot.com/moen7300.gif
http://img2.timeinc.net/toh/i/a/plumbing/faucets-toilets-07.jpg
Good Luck.
Posted on Sep 09, 2009
Testimonial: "this will give me something to work on. thanks"
  • 127 Answers
SOURCE: Moen kitchen faucet model 7430 leak
cartridge does not stop that type of leak. If it is leaking from around the base of the spout it is o-rings that are the problem that are onthe valve after you pull the spout all the way off.
Posted on Oct 18, 2009
FixinFax
  • 3085 Answers
SOURCE: need to replace cartridge in single lever moen
Turn off water
Remove the handle with an allen wrench, usually 1/8".
Unscrew the dome with a pair of channel lock pliers with a rag to prevent scratching.
Wiggle out the old cartridge with the channel lock pliers.
Clean all innards with WD-40.
Reverse procedure
Posted on Dec 12, 2009
Testimonial: "Thank you for the speedy reply it was needed at the time because the part was jammed or at least it seemed so."
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Moen kitchen faucet repair
    moen is guaranteed for life. call them for free replacement. really.
    Mar 17, 2015 | Moen Plumbing
    Moen banbury faucet repair
    I had a look at the installation guide and exploded diagram, It seems that the whole assembly will be tightened when the mounting nut is put on.
    The links to the installation guide and exploded diagram are:
    http://www.moen.com/shared/docs/instruction-sheets/ins2224.pdf
    http://www.moen.com/shared/docs/exploded-parts-views/87017pt.pdf
    Jan 18, 2014 | Plumbing
    How do I get to the valve cartridge to replace it?
    how to replace moen cartridge for two handle kitchen faucet ... cartridge for two handle kitchen faucet exporters,how to replace moen cartridge for two handle kitchen faucet suppliers,how to replace moen cartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
    Mar 17, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    I have a moen kitchen faucet with spray (high spicket) and a leak is developing at the bottom of the spicket. i may need a washer, but i do not have a diagram. i believe the model number is kvn01-01. thank...
    If no satisfaction from Moen, hardware stores usually have "O" ring replacement kits by faucet type, and it will likely have the one you need in it.
    Usually only a few dollars.
    Jan 04, 2010 | Moen 87530 Touch Control Single Handle...
    The cartrige inside my moen faucet leaks
    moens website. they have parts break down and diagrams
    Nov 30, 2009 | Moen F7425 Chateau Single-Handle Kitchen...
    My kitchen faucet leads when i turn it on, is
    Yes moen has replacement cartridges. Any home improvement store will carry them. I prefer Lowes.
    Sep 30, 2009 | Plumbing
    I cant stop my Moen single lever kitchen faucet from leaking. how can I fix it?
    Even Moen faucets can wear out. The first thing you should do is check your warranty. Below is a link to there warranty information.
    If the warranty period is over then your going to need to repair it or replace it.
    In general, leaks are often caused by a scratched or torn cartridge, o-ring, or grommet. Typically, a cartridge repair kit or replacement o-ring will correct this type of leak so a repair is less costly.
    Places like Home Depot, Lowe's or where you originally purchased the faucet should carry a repair ebuild kit. Most times on the back of the package there will be a diagram of the internal parts and how they assemble to help with installation. If not just take you time as you disassemble the faucet. First make sure the water supply has been shut off under the sink. Make sure you have a clean area to place the old pieces for reference. Having something to stack them on in the order they came out will help. Make sure that you check for any small set screws that may be used to lock things in place.
    If you do this repair yourself and have any others questions or if you run into problems feel free to ask me for help.
    Good luck.
    http://www.moen.com/consumersupport/warranty.cfm?location=TopNavCustomerSupport
    Sep 08, 2009 | Moen Monticello Single-Handle Kitchen...
    Moen 7310 Legend Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
    214 people viewed this question
    Top Moen Plumbing Experts
    john h
    Don Numinen
    Don Numinen
    Mike
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
