Question about Toys
How to repair the electric motor for a power wheel barbie jeep? where can I find parts for the motor on line?
  • 3 Answers
SOURCE: 12v battery powered barbie jeep
If you are comfortable with wires then go to walmart and get a schumaker battery charger from the automotive department. either the Maintainer or the next one up I think ist is model 600 They are much better than the stock chargers because when the battery is full they automatically switch over to float mode so the battery doesn't get cooked. www.modifiedpowerwheels.com has lots of info on exactly what you would need to do. The chargers are 20 and 30 I believe and they can be used for other things like lawnmowers and car batteries if needed.
Posted on Dec 18, 2008
  • 3 Answers
SOURCE: Power Wheels barbie jeep wheels slipping
ihad 1 for my son the solution is if you have plastic whells i to screw somme screws in the whells you get better traction it workt for me dench
Posted on Apr 01, 2009
SOURCE: Is there a way to
Sorry to tell you but in order to remove the wheels from the "Barbie Jammin Jeep" wheels the parts holding the wheels on would actually have to be removed. The Jeep is made mostly of plastic that has been "molded to fit" meaning that trying to remove the wheels would be a big problem unless you intend on decommissioning the Jeep and it's parts.
Posted on Jul 29, 2011
  • 434 Answers
SOURCE: Power wheels barbies jammim jeep foot pedal switch
Under the foot pedal should be an access panel you can remove for the wiring. Alot of the time the wires corrode in there and you have to put a new terminal on the wire, where it connects to the switch.
Posted on Apr 27, 2012
adamfjeld
  • 1508 Answers
SOURCE: clicking noise on barbie jeep
you need a new gear box
Posted on May 21, 2012
My granddaughter's barbie cruisin' tunes jeep only has fast gear, no slow or reverse.
check and see if both wheels are spinning, if not you have a bad motor which would cause the other gears to not work
Jun 24, 2014 | Fisher Price Power Wheels Barbie Jeep
Barbie power wheel just spins doesn't move
some people stud the tires with screws, or rubber traction bands can be purchased, or just put rubber bands on the tires for indoor use
May 15, 2017 | Fisher Price Power Wheels Barbie Jeep
How do I disassemble the Barbie Jammin' Jeep?
alot of the parts are held on with screws from underneath, i can get you the assembly manual and you could follow that in reverse order to disassemble it
Jun 12, 2012 | Fisher Price Power Wheels Barbie Jammin'...
Broken barbie-kelly doll power wheels
You have to push the horn to make it go. I had same problem. Gave to hubby to look at, He had it going in minutes.
Dec 24, 2011 | Fisher Price Barbie - Kelly and Tommy...
My daughter's barbie power wheel jeep keeps slipping out of gear and won't drive.
make sure that the cogs on the tires are in tight contact with the drive motor, you might have to add some washers to take up the free space
Oct 06, 2011 | Fisher Price Power Wheels Barbie Jeep
Is there a way to remove barbie jammin jeep wheels without breaking the parts holding the wheels on?
Jul 29, 2011 | Toys
I have a powerwheels barbie jeep that does not work. The battery is good as I tested it yesterday. How do I go about fixing it? It was running fine just a couple of days ago and the next morning after...
I would suggest checking all of the connections in the wiring. Often the spade type connections can come unseated during use.
Check the following areas:
  1. Connection to the battery itself
  2. Connection to the foot switch (you may need to unscrew it from the floorboard to check)
  3. Connection to the electric motor(s) attached to the rear wheels
If the battery is older, it may have failed. If you have a multimeter, or even a simple test light, you can check to see if the battery has voltage. You're looking for around 5-6 volts. Anything below just off the charger could indicate failure.
Hope that's helpful!
Feb 28, 2011 | Fisher Price Power Wheels Barbie Jeep
Toys Logo
15 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
