Question about Brother DCP-J125
Dcp-j125 printer shows error message 50. paper jam. There are no paper seen as such from both back and front. Iv cleaned the printe rencoder slip. but no go. same error message:- init.50
jackboy
  • 2985 Answers
SOURCE: Paper jam
The various parts that open up to allow access are monitored by a micro switch. Switch the machine off and open all the access points locate the switch and make sure it is freely working and the connections are all in place. Then come back
Posted on Jun 06, 2007
Mix-it-up
  • 832 Answers
SOURCE: error message print unable 50
the encoder strip which gives the printhead the position is out of place (error 50). You have to open the printer and reinsert the strip:
http://www.fixya.com/support/t211210-brother_mfc845cw
Stick a 1.5 inch tape onto the printhead cover where the strip runs thru. This will prevent this accident in future!
Posted on Nov 05, 2007
Soulvisitor
  • 1113 Answers
SOURCE: can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Posted on Oct 16, 2007
checkitright
  • 1362 Answers
SOURCE: Brother MFC 3240C Paper Jam Error Message
If it is not resetting then either there is still something on a sensor or you did something to a sensor by accident.
here is the manual
http://www.retrevo.com/s/brother+2820+fax++manual
Posted on Dec 26, 2007
Mix-it-up
  • 832 Answers
SOURCE: DCP-130c error 44 Please Help
error 44 dcp 130/mfc 240/440 etc.:
abnormally high temperature within print head.
You have two choices to TRY to fix it:
1. put in new carts. press menu then start copy b/w then  fourtimes arrow up button (AUB) quickly one after another.
press by help of AUB and OK:
7 - (Ok) 6  - (ok) 4 (ok) then start b/w copy to initiate the carts and let the machine do some power cleaning.
leave the maintenance mode by pressing AUB 9 (ok)  and 9 again.
2. Make sure that the ph is at correct position simply by pressing on it from top (power up machine. wait til ph runs to left side. unplug from power. simpl press onto the ph). replug to power.
If you still receive the error the ph is defective due to bad generic ink and needs replacing.
Posted on Mar 21, 2008
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean 50.no paper jam occured
Clean 50 is either Dirty Encoder Stripe or broken Maintenance Unit. In first case clean thoroughly the vertical Encoder Stripe and it should work. In case 2 better exchange the machine
Nov 23, 2015 | Brother Office Equipment & Supplies
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean 50.no paper jam occured.
You need to pres Menu-Mono Start-Up Arrow 4 times in less than 2 Seconds !!! and you will be in Maintenance mode. LEDs will be flashing. Press the Up Arrow and numbers will change and press OK after the one you want to select. The number sequence is the following. 8-0 2-8-6-4 4-4-6-0 7-7 9-9
Oct 29, 2014 | Brother DCP-J125 Colour Inkjet...
Unable to init 50
paper jam or some sensor error, try to clean the sensor located at under the pump.
Feb 10, 2014 | Brother DCP-J125 Inkjet Multifunction...
UNABLE TO INIT 4F BROTHER DCP-J125
my brother printer when on the screen show unable to print 4f
model printer brother dcp-j125 how to solve the problem ?
Dec 16, 2011 | Brother DCPJ125 All-In-One Inkjet Printer
Error 50 brother dcp 130 d
on my DCP 130C display appear an errore message "imp. stamp 50". This is an error message in italian language that indicate impossible to print, error 50.
Please, have you some suggestion to resolve this problem?
Thansk in advance
Sep 19, 2009 | Brother DCP 130C All-In-One InkJet Printer
Brother Print Unable 50 Error
No ;-)
The encoder strip switched off the ph and has to be set into place again.
see here how to fix it:
(enlarge the browser window to see pics somewhat better)
An advice:
when you have set the encoder strip in pos. again stick some scotch tape on the top of the ph cover where the strip runs thru to prevend the slipping off again on next paper jam ;-)
Mar 29, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP-J125 Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
