MB.W020B.006 Gateway Motherboard Capacitor Replacement
I disassembled my laptop (Gateway W350I) because it was overheating near the 2.5mm DC barrel jack. It looks like there's supposed to be two capacitors in parallel on the motherboard right behind the power jack, a C8 and a C11. C8 is missing! Is there any way to figure out what capacitance it should be? Any suggestions on where to get a replacement? Thanks.
    Top Expert:
  • 12,223 Answers
You can use the another capacitance from c11 as reference and replace it. Do not use less microfaradio and less voltage, use the same like c11
God bless you
Posted on Jul 24, 2013
Laptop capacitor
Hi Melissa,
The best i could find was on ebay.
Here's the link for the Fan
http://www.ebay.com/itm/NEW-Gateway-NV53A53U-NV53A63U-NV53A51U-NV53A50U-CPU-Cooling-Heatsink-Fan-7784-/281088859805?pt=LH_DefaultDomain_0&hash=item4172339e9d
And without telling me the type, size and rating of the Capacitor i think the best place you could find it is at Radio Shack or another store like it.
If you feel comfortable removing and replacing the entire Motherboard, here is a link on ebay for a replacement Motherboard.
http://www.ebay.com/itm/Gateway-NV53A38U-NV53A46U-NV53A47U-NV53A48U-Motherboard-MB-BL002-001-7595-/281012076283?pt=Motherboards&hash=item416d9ffefb
Hope this helps!
Thanks and please rate;)
Gary
Aug 27, 2013 | Gateway nv Computers & Internet
MB.W020B.00 Gateway Motherboard Capacitor Replacement
use the reference capacitance in microfaradio, with equal voltage like c11 not less. You can go to any electronic store like radio shack and get it.
God bless you
Jul 24, 2013 | Computers & Internet
Gateway id49c notebook power issues
http://support.gateway.com/s/notebook/2010/gateway/id/id49C/ID49Cnv.shtml
1) Test the AC adapter (Charger) first.
http://www.itsbattery.com/gateway-ac-adapter/Gateway-ID49C-AC-Adapter.html
Test with a multimeter.
(An economical multimeter can be purchased for as little as $5 to $12. Available in a multitude of stores. An auto parts store is but one example. Checkout aisles of major discount stores, may have them on the rack)
Function knob set to DC Voltage.
(If just a symbol the symbol is a dotted line over a solid line)
If more than one DC Voltage scale set it to the 0 - 50 Volt scale.
Positive (Red) probe lead of multimeter goes to the Center Hole, of the plug end that plugs into the laptop.
Negative (Black) probe lead touches the cylindrical metal shell, on the outside of the plug end.
You should be reading 19 Volts DC.
Also have an assistant gently wiggle the cable from AC adapter to laptop, and power cable to AC adapter (Charger)
Fluctuation in the reading means you have broken wires.
AC adapter checks out OK?
2) DC Power Jack:
The DC Power Jack is the jack on the laptop, that you plug the AC adapter (Charger) into. (DC_IN)
Battery removed, (And AC adapter, 'natch), use a No.2 pencil, and with the eraser, gently see if you can move the Center Pin around.
ANY perceptible movement means damage to the DC Power Jack, and replacement.
3) AC adapter and DC Power Jack checks out?
Problems with the Power MOSFETs used in the power section, on the motherboard, or possibly Ceramic Capacitor failure.
(Multi-Layer Ceramic Capacitor, and they are Surface Mount Devices)
Using the HP Pavilion dv6000 series, and Pavilion dv9000 series of Notebook PC's, as an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Looking down at the second photo with the Alpha and Omega Semiconductor - AO4407 - Power MOSFET circled in Yellow, look at the small rectangular shaped object to it's Right. Has a wide dark band on it.
This is a Ceramic Capacitor.
There is one above it of the same size, one above that one, and one to the right of the top one.
If any one of these, or the Power MOSFETs are blistered, blackened, or bubbled, they need to be replaced.
Due to issues that could arise by replacing, and having more components be bad, or go bad; the logical choice by most tech's is to simply replace the motherboard.
(Also puts more dinero in their pockets)
[ Your user name reminds me of Hee-Haw. "If it wasn't for bad luck I wouldn't have any at all." Lol!
Hey...........it's going to get BETTER! ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 16, 2012 | Gateway mb.wq502.001 - Id49c Intel Laptop...
Gateway W350i won't charge new battery
1) the charger from power supply inside of the laptop is defective.some component is burn or open,or short.
2) Of course you must shure that the batteries new is o.k you must go where do you buy and test it in another computer for to see is charging.
God bless you
May 09, 2012 | Gateway Computers & Internet
Laptop won't power on with ac adapter or battery
Could be a combination of things.
1) Battery is low. Not enough power to turn the laptop on.
Caused by;
2) AC adapter has a plug on the end of the cable. The plug plugs into a DC Power Jack on the laptop.
The DC Power Jack is bad.
2a) The DC Power Jack has a bad connection to the motherboard, (Cracked solder joints), and/or the jack itself is bad.
2b) Center Pin is loose in the jack's mount.
The back of the Center Pin where it mounts has become loose.
2c) The plastic body of the jack, which composes the jack's case, is cracked. This allows movement of the Center Pin.
2b, and 2c cause a bad connection with the AC adapter plug.
No charge to the Battery, no power to the laptop.
http://www.laptopjacks.com/view_part/For-Gateway-MX6920-DC-Power-Jack-GW51425.html
[ If this is the case the DC Power Jack needs to be resoldered to the motherboard. The cracked solder joints need to be re-melted, (Reflowed)
Entire laptop needs to be disassembled down to the bare motherboard in your hand.
(No Processor, Ram Memory, or any adapter cards mounted to the motherboard. Nada)
OR,
The DC Power jack needs to be replaced.
This entails disassembling the entire laptop, down to just the motherboard in your hand. (Same as above)
The old DC Power Jack is de-soldered, and a new one soldered in place.
Very FEW computer repair shops have the necessary skill level.
They just want to replace the entire motherboard.
IF one is available.
More Ka-Ching for them also. ]
3) The AC adapter is bad.
Not providing power to the laptop, to charge the Battery, nor give power to the laptop without the Battery.
AC adapter cord from adapter to plug, which plugs into the laptop, (DC Power Jack), may have a break in it.
May be an intermittent contact provided by wiggling the cord.
If this is the case the wires have stretched, and broken.
Wiggling causes the wires to briefly touch, and make contact.
Where this cord meets the plug itself. A lot of times there is a break in the wires in this area.
Solution is to replace the AC adapter. There are universal AC adapters you can buy, or perhaps Gateway still has some for sale.
(Ka-Ching)
Oct 21, 2010 | Gateway MX6920 Notebook
If I need to repair or replace my gateway mx6448 motherboard, which is most cost-efficient: to repair or replace? How would I know the difference? I am not an expert, but can I do this repair or...
Depends on what is wrong. Is it the DC Power Jack? The jack you plug the AC adapter (Charger) into?
Average cost is around $100 for a DC Power Jack replacement. (It's labor intensive, but the jack itself usually runs around $8 to $14 )
Most computer 'repair' shops do not have the skills required to perform this procedure.
The easy way is to just replace the motherboard. (Also more Ka-ching in the pocket)
Just a typical DC Power Jack replacement,
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Disassembling a Gateway MX 6000 series laptop,
http://www.insidemylaptop.com/disassemble-gateway-mx-model-ma2a-series-laptop/
Some designs of the motherboard, have the DC Power Jack mounted in an area on the motherboard, that DC Power Jack failure is a reoccurring failure.
The motherboard cracks in the area the DC Power Jack is mounted. (Breaking the circuit traces)
In this instance it's better to replace the motherboard. Of course it's going to fail later on.
Your question: "Can you replace the motherboard?"
I have confidence in you, I believe you can.
Doesn't take a rocket scientist, but does require patience.
1) Remove ALL Power to the laptop. AC adapter (Charger), and Battery.
2) It would behoove you to buy, and wear an ESD wrist strap. (Electro Static Discharge)
Connect the alligator clip to a good ground source.
I connect to the metal frame of an empty desktop computer case.
(Average cost is around $3 to $8. Look online for reference. Visit computer repair shops, and stores like Radio Shack for purchase)
Your body carries Static electricity. Static will fry out (Short Circuit) the hardware components inside a computer. Especially a Processor.
With wearing an ESD wrist strap, and connecting to a good ground source, your laptop is safe.
3) There may be as many as 60+ screws. There may be 12, or more different types of screws. DO NOT mix them up! Use a multi-compartment container, and label the compartments for the area the screws came out of.
You can use a clean egg container, (Or two) in a pinch. label each egg holder.
4) You may want to take photos, and make notes as you disassemble. Makes a real handy guide for reassembling. Also nice to have if you get interrupted in the middle.
Obtaining a motherboard:
You might check Ebay. Sounds like advertising, but it isn't. Just one of my sources.
Also check Laptops for Parts on Ebay.
Some sell a laptop that has a broken LCD screen as the only fault.
Post questions in a Comment.
This is what the motherboard looks like, (Gateway Support),
http://support.gateway.com/s/Mobile/Q106/BladeK8F/4001199R/4001199Rmv.shtml
Oct 13, 2010 | Gateway Computers & Internet
NEED TO REPLACE THE dc CONNECTOR ON A MA7 GATEWAY LAPTOP
You will need to First Order/Receive a New Replacement DC Jack...
Then The Laptop Needs To Be Disassembled Down To The Motherboard.. let me know if you need full instructions on the steps involved in the DC Jack Repair..
Nov 24, 2009 | Gateway Computers & Internet
Intermittent dc jack connection for Gateway mx3215
Here is how to disassemble Gateway laptop,
Here is replacement DC socket (needs soldering),
Here is DC board (no need soldering, but expensive).
Hope this helps.
Mar 17, 2009 | Gateway MX3215 Notebook
Power Cord Slot Repair for a Gateway ML6230
First Of All.... STOP WIGGLING IT!!!!!!!!
WHat Your Doing is Shorting Out The DC JAck And Causing Further Damage Every Time You Wiggle It For A Connection....
Which Could End Up Ruining Your Motherboard....
Your Problem Is The DC Jack You Need To Have Yours Replaced... THis Involves Complete Disassembly Of the Laptop Down To The Motherboard, Then The Old-Bad DC Jack Needs To Be Desoldered and removed and a new one Soldered Into Place....
http://www.ifixlaptops.com
Nov 18, 2008 | Gateway ML6230 Notebook
Gateway mt6707
This link shows you step by step with PICTURES and awesome instructions how to completely disassemble and repair keyboard, motherboard, dc power jack and more.
There are links within the instructions for other repairs.
AWESOME site and AWESOME instructions!!!!
http://www.insidemylaptop.com/take-apart-gateway-nx570x-laptop-disassembly-guide/
May 21, 2008 | Gateway MT6707 Notebook PC
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
