Fas256r2a control panel lights all flashing
A/C running fine. I clean filter at least 2x per week. Tonight it just started beeping and all the lights on the control panel started flashing all at once. I turned it off, waited, then turned it back on. It sounded like it was struggling to work. It finally kicked in and started up again and ran for about a half hour, then did the same thing. Now it won't start back up even after unplugging, resetting the breaker in the plug and just letting it sit for a while. No error codes, just all the lights continuously blinking and beeping unless I shut off at the circuit breaker. Help! It's only 2 yrs. old and only been used for 5 mo each year.
SOURCE: oven failed to work; F5 error message
please tell about the make & serial no. of oven.
Posted on Sep 30, 2007
SOURCE: haier HDP18PA
On another site, someone posted this: "I called (website), where it was purchased from, and they gave me the number for the manufacturer. Some standard troubleshooting did the trick and my dishwasher is working perfectly again. The troubleshooting involved tilting the dishwasher backwards at a 45-degree angle and letting any excess water drain out. They said ocassionally the water intake will be blocked and this process helps move anything that may have gotten in the way"
I was having the beeping problem too, and decided to give it a try, tipped it for a few, and found it to work!!! Hope this maybe helps!
Posted on Oct 17, 2007
bobotfel
  • 236 Answers
SOURCE: Sanyo 12KS71 Split Air Conditioner
Check your remote control the timer may be activated. Or try to push the reset button on your remote control to set it to default setting or just pull out the battery then insert it again then try. If problem persist then qualified technician is needed.
Posted on Jan 15, 2008
  • 1257 Answers
SOURCE: E1 error code
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Posted on Jun 05, 2008
  • 3 Answers
SOURCE: Temp control moves on it's own
Mine was doing the same thing and it was really frustrating! I would come home and it would be 88* inside. I found out that this model air conditoner has had problems with moisture getting in the control panel and shorting it out when it's humid outside. I have the part number if anyone wants it. It cost me about $45 from Sears Parts.
Posted on Jul 08, 2008
Green light flashing on first alert smoke detector
Remove the covers and give good clean with coton and meths sensors and covers and resit the alarm good luck.
Feb 06, 2017 | Home
My new hot point vented dryer is beeping 3 times when I hit start with the lights flashing, the red clean filter light is staying lit although it is clean??? It's only 6 weeks old
Check the vent system behind the unit, or disconnect it and run the unit. Either way sounds like the vent system is obstructed somehow. Good Luck
Mar 30, 2016 | Dryers
Frigidaire electric dryer (FEQ1442CES) keep flashing and beeping even after cleaning lint filter.
Good Afternoon Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, keeps beeping and flashing lights. I also see that you have cleaned all the lint out and your appliance will not run more than about 10 seconds. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the lights to flash and the beeping, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire FEQ1442ES Electric Dryer
Dsxh47eg0ww
I would replace parts. It still is cheaper than a new unit. So get the new control panel and do it yourself and save money. The average life of a dyer is dependant only on when the owner gives up. I just serviced on last week that was 25 years old.
Jul 08, 2013 | GE DSXH47EGWW Electric Dryer
F4 message on the top drawer, fisher paykel. I clean the filters and arm every week or two.
There 2 possibilities with this error:
1)
  • Fault with water fill (only on machines with level-controlled fill)
  • Note: Lights blinking, pump running and controls dead indicates an over fill fault
2)--4 Flashes--Draining failure. Drain pump, control board OWI or water indicator defect
God bless you
May 14, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
Our dishwasher has started leaving cloudy film on silverwar, glassware etc. Used Finish in washer per instructiuons. Have cleaned with white vingar per owners manual. Spray arms, filters all clean. ...
Run 2x bottles of Dishwasher Magic 1x per each wash. You can pick this up at your supermarket. Run on normal cycle without any dishes. Kills 99.9 bacteria and cleans out dishwasher.
Also make sure your not using rise aid and detergent with rise aid in it. To much rise aid will cloud the dishes as well.
Have a great day!
Dec 08, 2010 | KitchenAid Dishwashers
Beeping Sound in Ford Escort
there is a malfunction in the srs system.
the flashing airbag light is indicating a failurein the system and it is flashing a code.
the beeping is coming from the controll module, if the controller detects a malfunction in the airbag warning light than it will beep in place of flashing the light, this is to inform the driver of a air bag malfunction.
the light bulb may be bad or it may have a poor connection even if you saw the light on, the controller said there is a resistance issue in that circuit.
but you still need to have that system check to find out what started the malfunction and commanded the light on.
good luck
wesleyschacht@hotmail.com
Jun 14, 2009 | 1999 Ford Escort
All lights Flashing On
A low voltage issue will cause all these symptoms. You should have the alternator checked as well as the battery. Good Luck
May 20, 2009 | 2002 Chevrolet TrailBlazer
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
