Question about RaidMax (ATX-612WBP) ATX Mid-Tower Case
Doesn't power up anymore
I have a raidmax atx mid-tower case and was working fine for about 2 weeks, that is until i purchased a surge protector/batter backup device. I checked all the specks of the computer and it fits within the range of that of the surge protector. However, I followed the instructions of how to correctly connect the surge protector to the computer, when i hit the power button on the RaidMax case, i heard a short "click" noise, and now the computer doesn't power up at all...even if I plug it directly into the wall outlet. just a little sidenote, when i have everything plugged in, the ethernet light attached to the motherboard lights up, but nothing else seems to get power to it
  • rollingchris Oct 13, 2008
    I have the same problem it wont power up.
Same problem
Posted on Oct 13, 2008
  • 461 Answers
Use a test pen and check if any power coming out from the power supply cable e.g. to hard drive, motherboard and so on.. this will help to to find out if it is actually power supply issue or components issue....
Posted on Aug 30, 2007
Power button switch
Send a request to the following email address. Mention the exact model number like you did in your question and request a replacement front panel on/off switch.
Nov 19, 2013 | RaidMax AURA ATX-927WB Black SECC Steel...
Brand new case, just bought it from new egg, power light not working!
sounds like u didnt install the connector on the right the mother board very closely it has a diagram usually in tiny letters
Dec 23, 2010 | RaidMax Tornado ATX238WRP Black SECC Steel...
Installed a GA H55M USB3 motherboard in a Raidmax Tornado case. When I go to turn it on their is power for about for about a 1sec and the fans turn a couple of times and a couple of seconds later their is...
I once had something similar happen to me. Triple check to see that all connections are secure to the motherboard - a loose 20 pin ATX cable was the culprit in my case.
Hope that helps. Good luck!
Dec 09, 2010 | RaidMax Tornado ATX238WRP Black SECC Steel...
I need a motherboard that will fit in a Raidmax ATX1072BP Mid Tower ATX Computer Case!
Most desktop computer cases have a range of standard mount holes, standard offs.
I suggest you select a motherboard that suits your requirements.
To be sure that the motherboard will fit your case, take the motherboard mount base with you to the computer shop and place the motherboard of your choice on the base to see if the mounting holes line up.
You may need to upgrade the switch mode power supply to a higher power unit if the total power requirements is near the maximum the existing unit can deliver.
Dec 03, 2010 | RaidMax ATX1072BP MID TOWER ATX COMPUTER...
Raidmax Sirius case not turning on
Recheck the wiring. Make sure the fans are all plugged into the proper place. Then try reseating the RAM, video card, & cpu. Make sure you have applied a good thermal paste between cpu & heatsink as overheating can cause the system not to boot. Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower...
Raidmax 500w power slowly died, then wont turn back on.
1.-Your CPU fan is working?
2.-Your Power supply fan is working?
If not and following your description I think that you have to replace your power supply.
If you have the light on in the motherboard doesn't mean that your power supply is good.
Check the first to points above and if 1 and 2 are not working
Replace your power supply.
Let me know how it is going!
Thank you for using FIXYA!
Don't forget to rate my help
Pablo :-)
Oct 13, 2008 | RaidMax (ATX-612WBP) ATX Mid-Tower Case
I broke my temp probe on my raidmax
if by the probe you understand front fan controller,yes,there are controlers to replace yours..just pay attention to fit in the bay..
Jan 21, 2008 | RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower...
Raidmax Scorpio ATX Mid-Tower Case
The on/off connector is the power labelled one. The one thing you may have to do is (if you have'nt already)connect the power connector from the PSU to the processor power supply, close by to it as it may not just run off the motherboard ZIF socket for it's power up.
Feb 07, 2007 | RaidMax Scorpio 868W ATX Mid-Tower Case
RaidMax (ATX-612WBP) ATX Mid-Tower Case Logo
155 people viewed this question
Top RaidMax Computers & Internet Experts
Mohammad Abumuailek
Mohammad Abumuailek
Are you a RaidMax Computer and Internet Expert? Answer questions, earn points and help others
