Question about Biostar : NF4ST-A9 Socket939/nForce4/DDR400/SATA/ATX Motherboard (MOTBI15)
Possibly an overheating problem...
I have a biostar NF4ST-A9 with a AMD64 3200 and 2.5 gigs of ram. This system has worked fine for the last eight months, but only recently have I had some major problem with the setup. When I turn on my computer it will begin to boot up, but sometimes while detecting the ram it will just turn itself off. After about 4-5 times of turning off, it will finally begin to load up and stay on until the next time I boot. I got so sick of this problem that I took apart my computer and when I did, I saw that the RAM in my computer had been damaged along the connectors. Not only had they corroded, but they also have burn marks that stop them from connecting correctly. The RAM is only from Christmas, so its not like its really old. I am just wondering if anyone knows of issues with biostar boards burning or damaging RAM, and what I should do to solve this.
  • 231 Answers
Hi clean out the dimm slots with compressed air, if you do not have access to a compressor then you can buy a compressed can of propellent at a computer shop.Fit new RAM making absolutely sure that it is seated properly in the dimm slots. A problem like you have described is normaly caused by the RAM working loose or not properly installed in the first place. Regards mistyman
Posted on Aug 30, 2007
  • 461 Answers
Very rarely motherboard can cause burn to RAM unless most likely the RMA quality itself had the relibility issue... change the RAM unless the burn is very severe.. you may need to change the DIMM connectors (if you have the right tools) like HOt air machine..
I've bought a biostar M6TWG, version 2.6. can i upgrade it?
Go to this link
and download the motherboard manual. It gives you all the information you require.
Jun 08, 2009 | Biostar NF4UL-A9 Motherboard
Ati radeon hd3800 conflicts with ram
just a shot in the dark here maybe you're power supply needs a little more power to support that video card + 8 gigs of ram + all other peripherals you use
Feb 24, 2009 | Intel DX48BT2 Motherboard - X48, Socket...
The mixer is disable .
Go to biostar website look in support then drivers for the exact model of board that you have. Then download all audio drivers & save them where you know where they are on your computer. Then unpack the drivers & follow directions. After install restart the computer. If it ask for drivers, check the box for automaticaly install drivers.
Dec 31, 2008 | Biostar : NF4ST-A9...
Blue screen
In that case, please see the following for instructions on how to resolve this issue; Reference of original post for others reading this:
May 26, 2008 | Biostar : NF4ST-A9...
Bios setting
Does the blue screen only occur when trying an over-install (e.g. without having setup wipe the hard drive first)?
May 25, 2008 | Biostar : NF4ST-A9...
Computer will not boot with 2 gigs of ram.
yaa viz eagle is right, its really seems like frequency mismatch. The both RAM must of same size, same type, and same frequency.
Mar 24, 2008 | Biostar P4M80-M4 Motherboard
Double boot
almost anything is possible, but in general a 430 watt P/S should be able to run 2 gigs of ram, however that doesn't mean that the ram you purchased is the correct ram for the motherboard or that you have so many other added perpherials i.e. dual or tripe CD drives, hard drives, USB perpherials that the load is simply to great for your P/S. A rule of thumb is find out what your system ' will ' run with and then work from there. For example if a person was serous about this problem he might disconnect all power connectors to all other equipment other then his hard drive, monitor/video card, and his motherboard just to see if the system could then boot normally. If it did, chances are the memory is okay for the motherboard in normal circumstances. However if the system did not boot normally, it might be an incompatibility with the 2 gigs of memory on that particular motherboard. Memory is not a generic add-on. A person needs to make sure the memory is correct for a motherboard before installing. Also you indicate the present P/S is only 4 months old, any particular reason why you had it changed out to begin with??
Feb 27, 2008 | Biostar P4M80-M4 Motherboard
Audio ports
If you click on the link you can download your motherboard manual and save for future reference.
May 02, 2007 | Biostar NF4ST-A9 nVidia nForce4 AMD Socket...
Biostar : NF4ST-A9 Socket939/nForce4/DDR400/SATA/ATX Motherboard (MOTBI15) Logo
66 people viewed this question
Top Biostar Computers & Internet Experts
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
