Question about Dacor Microwave Ovens
Microwave fan not turn off - Dacor Microwave Ovens
My microwave oven model 721.85033111 vent fan stays on
You probably have a bad fan thermostat. This thermostat is supposed to turn on the vent fan if the microwave oven gets too hot (caused by cooking too much or having too many burners turned on on the range beneath the microwave oven). It should shut off in about 15 minutes after your turn off the range burners. But if it comes on for no reason, or won't turn off, then You probably have a bad fan thermostat.
Aug 10, 2014 | Kenmore Microwave Ovens
We have a kenmore ultra wave microwave and the fan has stopped working and now the microwave won't operate. Any suggestions?
see this causes and fix it .God bless you
Exhaust Fan Motor If the exhaust fan does not run the fan motor might be bad. Remove the fan motor from the microwave oven and see if the blades can be turned by hand. They should turn very freely, if they're stiff the fan motor will need to be replaced. The fan motor can also burn out. To test this use an Ohm meter. The motor should have continuity. If it does
Thermostat If the microwave exhaust fan is not working the thermostat might be defective. The thermostat senses the air temperature and turns on the fan as needed, if it's defective it won't turn on the fan. Watch our video on testing thermostats.
Main Control Board If the microwave exhaust fan is not working check the exhaust fan motor and wiring. If they are good the main control board might be defective.
Oct 02, 2012 | Microwave Ovens
What causes a Samsung Microwave exhaust fan to turn on by itself?
mine turned exhaust fan on automatically... i couldnt shut it off... had to unplug it.... no buttons worked.
Aug 29, 2012 | Samsung 1.8 Cu. Ft. Over-the-Range...
The microwave does't make any noise ,,,but the count down on clock is working ...light is working but no fan ...or huming noise ...what could it be
HELLO.
The likely thing to be is that the microwave fan is faulty.the solution is to replace the fan.
Needed instrument:Phillips-head screwdriver.
Instructions on how to replace the fan is detailed given below.
    • 1. Unplug the microwave from the wall outlet to prevent an electrical shock while
    • working on the microwave oven.
    • 2 .Remove the screws holding the fan shroud to the top of the microwave oven. Using a Phillips-head screwdriver, turn the screws counterclockwise to back them out of the panel. Set the screws in a safe place so they will be available for installing the new fan.
    • 3.Slide the fan shroud--also referred to as a damper plate--forward, toward the front of the microwave, to remove it. Set the shroud to the side.
    • 4. Lift the fan assembly out of the microwave. An electrical cable and plug is accessible once the fan assembly is out of the way.
    • 5. Unplug the electrical connector from the fan and fully remove the fan assembly.
    • 6. Set the new fan assembly close to the top of the microwave to facilitate plugging the new fan into the microwave's connector. Plug in the fan assembly.
    • 7. Position the new fan in the same orientation as the old fan's before its removal. Lower the fan assembly into position.
    • 8. Slide the fan shroud in place and install the screws to secure the shroud.
    • 9. Tighten the screws with the Phillips-head screwdriver by turning the clockwise.
    • 10. Plug the microwave oven into the wall outlet and test the new fan installation.
Thanks
Sep 20, 2011 | Haier Microwave Microwave Oven
Frigidaire Microwave Fan won't shut off plmv169dcd
Had the same issue, leave Microwave unplugged for 30 minutes and then plug back in. My fax stopped blowing and now fucntions 100% normal again HI/LO / OFF
Best of Luck!!! :)
Jan 17, 2010 | Frigidaire PLMV169DC Microwave Oven
Cooling fan hums and turns slow.
You will need to replace the cooling fan motor. Remove it and check the numbers on the fan and then do an online search for the motor. you can also contact a website called the repairclinic.
Oct 20, 2017 | Whirlpool MH1170XS Microwave Oven
Cannot turn off fan
the fan has to stay on,thats the way they are made
Nov 30, 2008 | Kenmore 60654 Microwave Oven
FAN!!!
Oh, it turns out the the microwave was over heated and the fan was cooling it. The fan will automatically turn on and stay on until your microwave reaches normal temp. just unplug your microwave and let it cool off. then plug it in and everything should be just fine.
May 25, 2008 | Frigidaire GLMB209D Microwave Oven
Goldstar microwave exhaust fan will not turn off
We had this happen to us tonight. We unplugged the microwave oven for 15 seconds and then plugged it in, but it the fan was still running. We then unplugged it for 30 minutes and the fan worked properly when we plugged it in again.
Jan 09, 2008 | Microwave Ovens
Ge Spacemaker XL 1800
SOME BUT NOT ALL OVENS HAVE RELAYS TO TURN THINGS ON AND OFF CHECK THE OVEN TO SEE IF YOU HAVE ANY
RELAYS AND SEE WHAT THEY DO.
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
15 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
