Question about Technics SL-MC50 CD Player
String ??? I have a Technics SL-MC50 and i have this string that came off of it from some where and the part that takes the CD out will not move does anyone know where this part goes? i have taken it to an Electronics Repair shop and they cant seem to figure it out either Any help appreciated Aaron
Yes, I have a soloution to this "String" problem.
Only because I have repaired mine twice already.
Unscrew the unit and take cover off,you will see the mangled "sting" wich is actually more like aviation cable takes some skill and a pair of steady small hands to fix.
you have to re-thread the wire back into position by hand on the left hand side you will see small wheels where the cable sit's in then rethread the changer post with 4 wheels thred it inside left bottom to outside left top, to over right top to inside bottom right.
I have temporarily fixed it. if you shake or mis handle the unit somehow it will fall off again!!
The reason for this is when the disc's change the guide wire will get looser with age and fall off.
the proper way to fix this is to take a pair of pliers and pull the string out the side where it is fastened pull it tighter to reduce the slack in the cable DO NOT over tighten or it wont change discs at all!!
keep playing around with the cable till it's re-threaded properly, you'll know when it's threaded right and be carfull not to bump it back off while screwing the cover back on. It's almost like re-threading an old movie projector.and if you feel daring you can try my permanant fix suggestion to tighten it some how with pliers to reduce the slack.
I almost threw my CD changer out when that happened i thought it could'nt be fixed but it is possible and it works fine.
I have not permanantly fixed it myself with pliers, but i'm pretty sure it would work, that way you wont have to rethread it everytime it falls off.
Posted on Aug 06, 2008
Power it on and just get an off reading
Technics SL-MC4 61-Disc CD Changer Not reading ... - Fixya
www.fixya.com > ... > Technics > Technics SL-MC4 61-Disc CD Changer
Technics SL-MC4 61-Disc CD Changer, not reading cd related issues. Get free ... IHave A Tascam CC-222Mkll Will Not Read CD-R Or CD-RW But Will Read Store Bought CD's. I Have A ... I have just spent $69 for the software to convert it the way I wanted into mp3 format, being a format that I figured . ... Power the unit off.
Technics SL-MC4 61-Disc CD Changer Message center ...
Dec 29, 2015 | Technics SL-MC4 61-Disc CD Changer
Turntable drive belt slips off?
If you measured the worn belt, it might have stretched by 5-8% from the original length. Thus the new belt could be too large. I can't find a reference to the original Technics SG2500L belt. However one site, http://www.turntablebelts.com/panatech.htm , suggests that the appropriate belt may be the FBM 23.6" (60 cm). This is the generic belt for a range of Technics turntables. If they list a turntable model, then they know a different belt is needed.
The best way to measure the belt length is to wrap a string or wire around the belt path on the turntable. Follow that path exactly. Mark the point where you overlap the string or wire. (In case you keep your fingers on the end of the string, mark both the start and end points by drawing your line across both sections of the overlapping string.) Remove the string or wire and lay it flat. Measure the length from one mark to the other. That's your true belt length.
I hope this helps.
Jan 05, 2018 | Audio Players & Recorders
Hi i have a techniqka hi fi MC-208 when i put a cd in it plays for a bit then 0P shows on the wee window so i cnt play cd... How can i resolve this... Thanks Kerry
try to turn it off an on while holding the play button. try 2 go online an look for the meaning of your (op). type in .technics sl-mc-208 cd player 0P problem
Mar 15, 2011 | Technics SL-MC50 CD Player
Im not geting any sound out of the left side. Its not the speakers or receiver. I ve changed all the wire testing it. It is the left side of the cd player.
the channels burn out its a common fault the quick fix is to buy a rca adaptor to run 1 output to 2 or replace the cd player it will cost a lot less to replace than fix
Jan 02, 2011 | Technics SL-MC50 CD Player
Drive belt problem
You can go to a local electronic store with your belt.
He has a replacement which is smaller.
Don't buy the original (expensive) belt.
Regards,
Gerard
Feb 01, 2010 | Technics SL-MC50 CD Player
NEED A BELT FOR MY DC SERVO AUTOMATIC TURNTABLE SYSTEMS SL-B210
You have to check an electronic store. If it does not have old one get a piece of string and measure around where the belt goes so you can know how big it is. Or you would have to order online, russell electronics sells all type of electronic belts you would have to search for a radioshack or another electronic store in your area.
Aug 20, 2009 | Technics SL-1210 Turntable
Need Manual for Technics SL-PD827
Go to http;//audio.manualsonline.com
Jun 24, 2008 | Technics SL-PD8 5-Disc CD Changer
Technics SL-PD9,SL-PD7A
Ouch, you should not have disconnected the front door.
Unplug.
Take the lid off.
take all CD's out.
Figure out where the plastic bit goes.
Good luck.
Sep 23, 2007 | Technics SL-MC6 CD Player
Won't stop playing.
In the Carousel on the far left there is a slot marked single. Place your favourite CD in that slot and when it's bed time press the single button to the left of the Direct & Program buttons on the front of the unit. Then press play, only the CD in the single slot will be played. Enjoy. Always, Alvin T.
Nov 10, 2006 | Technics SL-MC50 CD Player
Technics SL-MC50 CD Player Logo
240 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
