Question about FAIP Vertical Shaft Pump MTPV93519
Craftsman power washer
How to change the oil and how much to put in.... also what is the best oil to use.
Location of pump oil input valve
Hi
Im surprised that this model pump has a oil refill. Most pumps of this size arent refillable. This looks to be a pump made by FAIP. Its an ok pump but I would recommend using it until it fails and then replace with an AR RMW pump. Much easier to get parts for. Here is a diagram of your pump...The oil refill plug is on the side of the pump...that is located under your engine. You want to get the recommended oil for your pump. Most pump oils are 30 weight non-detergent but these small pumps take an oil specific to only them. So follow your specs...your diagram is here http www searspartsdirect com Craftsman Power washer Parts Model 580752330...
and your manual is here 580752330 CRAFTSMAN PRESSURE WASHER Manual
Hope this helps
Sep 20, 2014 | Craftsman Garden
Engine lockup
Sounds like the intake or exhaust valve is not opening.
Jun 08, 2013 | Craftsman 2700 PSI Briggs Stratton...
Oops! I put my son's weed-eater gas in the pressure washer. Now, I can't get it to start. I have emptied out the mixed, put in new... still no luck. is there a way I can prime it?
take out the spark plug and put just a couple drops of gas in the cyllinder head, and maybe one drop of oil, it will smoke a bit, but should **** new fuel in to carb
Aug 22, 2011 | Craftsman 2500 PSI Briggs & Stratton...
Can I Use 10w-30 or sae30 motor oil in my 2700psi 2.3 craftsman power washer?
10w30 will work fine. you also can use 15w40 depending on how hot your summers are. you can stay with 10w30 just check it depending on how long at one time you use it. if your just occasional, check twice throught the summer and add or change if needed if commercial go with 15w40 and check every day.
Jul 06, 2011 | Craftsman Garden
I bought a new craftsman pressure washer 2700psi. Put oil and gas in it. Cranked on the first try. It worked for about 15 minutes and then cut off. Now the pull start is very hard to pull and will not...
Hello
Take out the spark plug and try pulling,if it is still hard then then there is a problem with the pull start mechanism.
Check the plug for oil fouling or fresh oil.If there is excessive oil you may have bad rings.
If in doubt, craftsman will honor the 1 year warranty no questions asked,for a new unit.
Jun 25, 2011 | Craftsman 2700 Max Psi Pressure Washer 23...
Started by Craftsman 2700 PSI , 2.3 GPM Briggs & Stratton Powered Pressure Washer for first time in 9 months. Added new oil, and gas. started but is smoking from muffler and is dripping what appears to...
The first thing I would check would be the oil level, to make sure you didn't put in too much oil. If the oil level is correct, it could be a stuck piston ring, letting oil blow by the piston, and out the exhaust. If this is the case, you are going to have to tear down the engine.
Hope this helps!
May 09, 2011 | Craftsman 2700 PSI,2.3 GPM Briggs &...
How much oil does it take to change the oil in the lt1000 17.5 hp craftsman riding mower?
The best way to do this is to check that the unit is full of oil. Then measure what comes out when you drain it. Put this amount back in and you should read about a pint less than you need. That is because that is what is in the filter that you changed when you drained the oil. You are going to change the filter, right?
Fine tune the top up and you are good to go.
Feb 23, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Oil to gas mixture for a craftsman 3.75 hp pressure washer
There is universal 2 cycle oil available (pro-mix at Lowe's for example) that is good for all ratios from 16:1 to 50:1. With this oil you add the same amount of oil to the gas independent of ratio required. One gas can, no ratio worries. Hope this helps.
Oct 03, 2009 | Briggs & Stratton Garden
How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Aug 25, 2009 | Briggs & Stratton Garden
FAIP Vertical Shaft Pump MTPV93519 Logo
Top FAIP Garden Experts
 Bob Oppenheimer
Bob Oppenheimer
Level 1 Expert
Mister Danger
Greg P
Greg P
Are you a FAIP Garden Expert? Answer questions, earn points and help others
