Question about Sony Ericsson K610i Cellular Phone
Cant charge Sony Ericsson k610i
The last pin of the 12 pin connector where the charger connects is missing. I have found a diagram on the web (http://pinouts.ru/CellularPhones-P-W/se_k750i_pinout.shtml) that shows this to be the charging pin. I have been able to disassemble the phone and remove the connector easily. The prob is that I can't find anywhere to purchase a replacement. help!
    Brigadier General:
  • 7,752 Answers
Take the phone and ahve teh charging port replaced
Posted on Oct 25, 2008
My t715 sony ericsson device has a charging problem. every time i plug it in it seems to charge for about 5 seconds and then it displays "charging problem please remove charger" message and stops...
i have ah problem my t715 sony ericsson the problem i removed this charging pin the leg broken so i need solution my unit... can any one to give me solution charging jumper or diagram this charging pin!.....
Jan 30, 2011 | Sony Ericsson T715 Cell Phone
K700i NOT CHARGING
the mains charger may be dead or the charging connector broken, the tiny pins on the connector break easy, common fault on sony ericsson chargers, try using the usb cable if you have one with your pc, when you plug it in, select 'media transfer' and the fone should start charging, if it charges then fone is ok but mains charger is bad, if you cant get it to charge either way then battery may be worn out and needs replacing.
Jan 14, 2011 | Sony Ericsson K700
Why won't my sony ericsson t707 charge when the charger is plugged in???
first check whether your charger is ok, if it is working on another mobile, look for corrossion on the charging connector of your phone, if you see it corroded or clogged, power off your handset , remove battery and then clean the contacts with a pin or a small blade.
reinsert battery and try charging.
it should be working now.in a rare case if on connecting charger there is red light blinking and your set is not turning on you have a software crash and need to be updated at a service center.
regards
please comment
Jan 01, 2011 | Sony Ericsson T707 Cell Phone
My sony ericson k610i phone will not charge
I have a Sony Ericsson k-610i. It cannot charge when phone on, but i turn off the cell phone then will start charging. please send me this solution.
Jan 24, 2010 | Sony Ericsson K610i Cellular Phone
Unlock k610i
i have sony ericsson K610i i am not able to view the dailed calls , received calls and missed calls, i want to know what settings i have to change
Oct 18, 2009 | Sony Ericsson K610i Cellular Phone
Software problem in handphone
how do i use the usb connector..it been connected but i do not where is it?i need to upload photos.thanks.
May 18, 2009 | Sony Ericsson K610i Cellular Phone
Charging error
Charging error means that the phone charger is sending an incorrect voltage to the phone, or that there had been a contact on phone charger connector.
You can temporarily restart charging by unplugging and plugging back the charger, but on the long run this can damage the phone.
To start check the connector at the base of the phone, where you hook up the charger.
If there is dirt or oxide in there remove it, you can clean it using cotton buds and isopropyl alcohol.
If that does not solve the problem, go to any phone shop and buy a replacement AC charger for $10 or less.
Nov 09, 2008 | Sony Ericsson K600i Cellular Phone
Charging problem
maybe is the charger te one that have the failure
try changing it if not, maybe the cellphone terminals are damaged and you need reparation
Nov 08, 2008 | Sony Ericsson K610i Cellular Phone
K610i PROBLEM
You should be able to down load the latest softwear off the Sony Ericsson website. Otherwise the phone should have a 12 month manufactues warranty and can have it done for free at an authorised Sony Ericsson repair centre.
Apr 11, 2008 | Sony Ericsson K610i Cellular Phone
K610i
I have the same problem.
My opinion is that you have to flashing your phone. I'm still looking for good program to resolve this.
cheeer
Oct 04, 2007 | Sony Ericsson K610i Cellular Phone
Sony Ericsson K610i Cellular Phone Logo
336 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
