SOURCE: Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
SOURCE: Ceiling fan replacement parts
Here is the link for SOME parts for Minka Aire Fans. They don't necassarily need the model number, just the balde dimensions for replacement. Hope this helps you.
SOURCE: Dryer will not start
yeah, I'd say your motor is locked up. They go for about $50 on flea bay to about $100 on other sites.
http://cgi.ebay.com/NEW-Frigidaire-Dryer-Main-Drive-Motor-131560100_W0QQitemZ350113672233QQihZ022QQcategoryZ20714QQcmdZViewItemQQ_trksidZp1742.m153.l1262
http://midwestapplianceparts.com/index.php?main_page=product_info&products_id=5015&cPath=733&m1track=googlebase&utm_source=googlebase&utm_medium=cse&utm_campaign=export_feed
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
SOURCE: Hunter Douglas Ceiling Fan Does Not Work
Try Cheyenne Lamps 2000 E. 17th Street Little Rock AR
501-374-2829
